#1 |
NCM-WINR
Drives: 2010 SS/RS IOM 2014 2LT Stingray Join Date: Mar 2009
Washer nozzles freezing
also drives a heavily modified Jeep Wrangler. It has LED headlights and wheel weights blacked out with Plasti Dip. It's Baller.
#2 |
Downright Upright
Drives: Daily Join Date: Apr 2009
Use arctic-rated fluid...-40 or better. The deep discount stuff will often freeze in the jug, let alone @ the nozzle in windchill. It was -10 windchill here this AM (before moving)...washers worked...
#3 |
![]() ![]() ![]() ![]() Drives: '18 Sierra Denali '05 GMC 2500HD Join Date: Jul 2011
Every vehicle I have ever driven in the winter suffers from the same problem no matter which design or routing the washer system has. Yes I use the cheap washer fluid, but I think the overall problem is, a drop of water gets in the end of the nozzle when turbulance has "sucked" the washer fluid out creating a void and freezes.
#4 | |
2016 Challenger Hellcat
Drives: 2016 Challenger Hellcat Join Date: Dec 2009
2016 Challenger Hellcat.....2016 Corvette Z06
2015 Corvette Z/51.....2014 Charger SRT 2013 Ford Mustang GT.....2009 Pontiac G8 GXP 2009 Corvette Coupe.....2005 Pontiac GTO 1995 Camaro.....1989 Mustang GT 1987 Mustang GT.....1985 Camaro 1976 455 Trans-Am.....1973 Mustang Mach 1 |
#5 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS RS, 1968 ragtop Join Date: Apr 2009
3 winters with a 5th gen and never had this problem! WHINER!
1968 Camaro Convertible LS1, T56
#6 |
I drive mine through the winter and haven't had this issue. That's what I was trying to say.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS LS3/6M Litho#190 Join Date: May 2010
I've had this issue too Jamie,on the '88 Corsica I had,that thing was terrible for the washer nozzles freezing up,I also considered it a major safety issue as well,I can't tell you how many times I would pull off the road on my way to work in morning just to try and clear the windshield off!
I don't have the issue now,as the Camaro is parked for the winter.....I don't drive my Silverado in the winter either,and even if I did it still has the heated washer fluid system (the system that should have been removed by the recall,but I refuse to let them take it!!!) the heated system eliminates any freezing issues.........my Saturn's washer system is great,the hose and nozzles are in the cowl,so I think it gets enough heat from the engine compartment to eliminate any freezing issue.
![]() '11 IOM 2SS/RS LS3/6M HURST - Roto-Fab CAI-Kook's LTs-CORSA-Black Bear tuned Proud Litho owner #190 - Homecoming Litho #120 '15 SILVERADO Z71 1500 LTZ Crew Cab - 6.2 "Midnight Edition" -Airaid intake-CORSA |
#8 |
knows 2 facts about ducks
Drives: ...and they're both wrong Join Date: Aug 2009
I'm in Erie PA and have yet to have a problem with my wiper fluid.
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro SS1LE 2000 Trans Am WS6 Join Date: Jul 2008
Aren't the sprayers on the bottom side of the hood?
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans 2002 Trans Am 2015 Ram Crew Cab Cummins |
#10 |
Drives: 2023 GMC Canyon, 2023 Expedition Join Date: Aug 2008
Malibu's spray nozzles are wiper mounted and we've never had a problem.
2023 GMC Canyon Elevation 2023 Ford Expedition SSV (State-Issued) |
#11 |
www.Camaro5store.com
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 F150 RCSB Abyss FX4 Join Date: Aug 2009
So when did Fbodfather become the wiper washer guy?
#13 |
Drives: 2010 Camaro 2SS/RS Join Date: Apr 2008
Wind chill numbers do not change the freezing point of liquids. You need the actual ambient temperature number for that.
#14 |
Downright Upright
Tell that to the fluid when you're marchin' down the highway @ 60 mph and it's 0, ambient, with a 15 mph wind besides...
| CAI or Roto-Fab + Scoop + APEX Washer Bottle Kit Now Available Only @ APEX | Apex Motorsports | V8 Bolt-Ons & Tunes | 129 | 05-13-2016 04:06 PM |
| DIY - ADM Scoop & Apex Washer Tank Installed with a CAI intake | ClutchKargo | Camaro DIY & HOW-TO instructions & discussions | 44 | 03-08-2016 05:52 PM |
| Apex Motorsports Washer Fluid Tank Replacement Kit Now Available: $69.99! IN STOCK!!! | Apex Motorsports | V8 Bolt-Ons & Tunes | 68 | 08-10-2012 06:32 PM |
| Windshield Washer Nozzles | TheHorse13 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 2 | 01-06-2012 01:05 PM |
| Headlamp washer nozzles? | dragon22 | 5th Gen Camaro SS LS LT General Discussions | 9 | 02-03-2011 06:59 PM |
