Old 12-28-2011, 04:34 PM   #1
DoubleARS
DoubleARS's Avatar
Drives: 2010 Dodge Challenger
Truck Handling - Vibration
I have a 2005 Dodge Ram Quad cab. I haven't driven it much since getting my Camaro earlier this year. It has mostly been sitting my garage. I changed the oil today and took it for a drive.
What I noticed
  • About 35-45 miles per hour, there is a vibration. It's not uncomfortable but still unpleasant. Low frequency.
  • Around 45-65 mph, rides pretty smooth (like a truck).
  • Over 65, slight vibration. High frequency.
My uneducated thoughts and facts
  • I had new tires installed a few thousand miles before storing but never got an alignment. Would an alignment help?
  • Do these issues sound like the tires were flat-spotted and it will go away with driving? The tires were all down to about 20 psi and I filled them to 35 psi before driving.
Any other thoughts? I'm just trying to come up with a place to start.
DoubleARS is offline   Reply With Quote
Old 12-28-2011, 04:49 PM   #2
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
sounds like the tires could be off balance.
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
BigMatt is offline   Reply With Quote
Old 12-28-2011, 05:06 PM   #3
shank0668
shank0668's Avatar
Are the tires Goodyear 20 inch tires?
Old 12-28-2011, 05:54 PM   #4
bluetooth-ss
Drives: 2010 ABM 2SS/RS A6 and 2018 2500
Try getting the tires balanced and rotated and see if that helps.
bluetooth-ss is offline   Reply With Quote
Old 12-29-2011, 08:02 AM   #5
Number 3
Hail to the King baby!
Number 3's Avatar
Usually you won't feel tire imbalance at lower speeds (35 mph). That sounds like flat spotting. My Sky used to do that if it sat for more than a week, but went away after 5 or 10 miles, no big deal.
The 65 mph and up could be wheel imbalance. Did you drive it much after you had the new tires installed? You said you had them put on a few thousand miles before storing it so if they were balanced when you put it away, they pretty much don't unbalance while sitting.
So sitting with low tire pressure for a while likely led to flat spots. Just my guess.
Old 12-29-2011, 11:21 AM   #6
DoubleARS
DoubleARS's Avatar
Thanks. I will see about getting them balanced.
They are not. They are Cooper 20 inch.
I will rotate them tomorrow and see if that helps. Otherwise, off to balance.
I never really noticed the issue as bad as it is now. There was a slight vibration when I first got the tires but I assumed is was related to the deep tread. They did seem to wear a little and the issue went away. I have only put about 10 miles on since I first noticed this. I will drive a little more after I rotate and see if it goes away.
Thanks everyone!
MR HYDE IS COMING TO LIFE Dr Jkel General Automotive + Other Cars Discussion 538 03-18-2013 09:08 AM
Bakersfield Performance 69307 USA - California 13 11-21-2011 10:59 AM
Vibration from 58-68. Basenji Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 06-13-2010 10:35 AM
Low frequency vibration from 58 mph-68 mph Basenji 5th Gen Camaro SS LS LT General Discussions 5 05-06-2010 11:06 PM
Silverado 2007 Truck Of The Year KILLER74Z28 General Automotive + Other Cars Discussion 1 12-21-2006 12:59 AM
