#1 |
![]() Drives: 2010 CAMARO BLK 2SS/L99 Join Date: May 2009
How does the GT500 get past the gas guzzling tax?
I was just curious as to how the 2013 GT500 gets away with not having the gas guzzling tax and the 2012 ZL1 gets stuck with it. Is it that the GT500 engine is that much more efficient?....or are they going to get stuck with it once the smoke clears from the hype?
#2 |
![]() Drives: 2016 Z06, 2015 Hellcat Challenger, Join Date: Mar 2009
Superb engineering I would guess..........
#3 |
![]() Drives: 2012 ZL1 Join Date: Jun 2009
My dealer told me this morning he does'nt know how they will get by not having one and as you pointed out, it may happen after all the hype and marketing smoke clears.
#4 |
By certing the car's mpg with a "standard" set of numerically lower rear gears, then sending the optional gear equipped cars to the magazines for performance testing.
#5 |
San Diego Head Tuners
Drives: 2016 Camaro 1SS ,NPP,MagRide, A8 Join Date: May 2009
Yep, that's it
2016 1SS A8, NPP, MagRide, Black Rims
My 5th Camaro (3 Gen5, 1 Gen4) Member of San Diego Head Tuners https://www.youtube.com/c/MojaveKY https://www.instagram.com/mojaveky/ https://twitter.com/MojaveKY http://dinowax.refr.cc/bryanm 15% off DinoWax orders |
#6 |
![]() Drives: 2SSRS manual yellow black stripes Join Date: Nov 2009
That and using a modern engine design with overhead cams etc
Surely pushrods should be in the museums now??!!! |
#7 |
![]() Drives: CTS-V Coupe and GT500 Join Date: Nov 2011
Lighter weight guys. TVS require little power in bypass mode to turn. Way better than the stander m122 the old gt500 had. 3:31 gears help too. Doubt they will have Peformance gear. Why would u need it with 650 hp and 600 trq
#8 |
Yeah, that was what I was thinking because we have not seen any price details from them yet.
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 ZL1 Join Date: Oct 2011
As a former mustang owner it is not cams and newer technology. My 4.6 got worse milage than my C6 vette. My musuem pushrod Z06 gets 24mpg on the freeway. 3.42 gears and lighter which is better the the exotic overhead cam current gt 500.
My .02 would be 3.31 gears and 400lbs of wieght advantage. Weight is a huge factor that people forget. They have not avoided it yet though. I think they could though. Big torque and tall gears helps. That is why the Z06 avoids it.
2016 2SS
2020 super duty on 37's |
#10 |
Drives: SuperCharged 2SS/RS IOM MN6 Join Date: May 2009
Obviously, the main benefit to using aluminum block was lighter weight at the front which was Ford's way of improving the handling which has been burdened but a heavy front end in the past. But as a side benefit, the aluminum block is more efficient, mileage increased by 1mpg, enough to avoid the GG tax.
#11 | |
Just a car guy
Drives: 2016 Durango R/T AWD Join Date: Oct 2011
So, your 3100-3200lb car only gets 24 MPG? My 05 GT with 4.10's, about 500lbs more weight gets 22-23 MPG on the highway and nearly 18-19 on the street. Pretty sure it has to do with the efficiency of the motor, all of the cooling mods, the difference in weight between the ZL1, etc.
2014 5.0 - Ported CobraJet Manifold - SCJ Mono-Blade TB - Kooks 1-3/4" LT Headers - Kooks O/R H-pipe - Custom Intake - McLeod clutch line - Borla S-Type Axle Backs - AED Tuned - 443 RWHP / 388 RWTQ - GONE 05 GT - Sold 03 Cobra - Gone (Never Forgotten) |
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2005 STi corn fed Join Date: Jul 2008
Weight.
#13 |
Dealers are clueless. They have no idea what makes a car pass or not for being applicable to the GGT. Ford worked extreamly hard for the 2011-12 gt500 to miss he tax. I see no reason why the new car won't be he same. Its only 55lbs more plus the gear went from a 3:73 down to a 3:31 plus a more efficent engine.
#14 |
ZL1 #140
Drives: Camaros: 68 SS, 10 2SS/RS, 12 ZL1 Join Date: Mar 2008
| AHHHH!!! Time to PANIC $5.39 gas is here!! | VTXrider | General Automotive + Other Cars Discussion | 46 | 03-11-2011 04:13 AM |
| gas prices. | Congoman775 | General Automotive + Other Cars Discussion | 65 | 05-28-2008 12:20 PM |
| Gas Guzzler Tax | Roflmao | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 11 | 02-29-2008 05:29 PM |
| gas guzzler tax | Mike88 | Canada | 15 | 01-08-2008 12:54 AM |
