Old 10-05-2011, 09:52 AM   #1
xTHExxFALLENx
xTHExxFALLENx's Avatar
Drives: 2010 RS / 2017 SS
Quick stupid question
Hey guys I know this is not a dodge forum, but my moms dodge grand caravan just overheated and I'm a car noob and don't know how or where to put water in it. Can u guys please help me thank you!!
xTHExxFALLENx is offline   Reply With Quote
Old 10-05-2011, 09:53 AM   #2
Caspers2SSRS
Caspers2SSRS
Drives: Summit White 2010 2SS/RS Camaro
Radiator overfill bottle.........................
Caspers2SSRS is offline   Reply With Quote
Old 10-05-2011, 09:54 AM   #3
xTHExxFALLENx
Huh?
Old 10-05-2011, 09:55 AM   #4
xTHExxFALLENx
Ohh never mind thanx a lot man!!!!
Old 10-05-2011, 09:57 AM   #5
Caspers2SSRS
Caspers2SSRS
Under the hood, screw on cap, squarish in shape..........marked.............."Do not Open While Hot"
Old 10-05-2011, 10:01 AM   #6
xTHExxFALLENx
Thanx very much!!
Old 10-05-2011, 10:04 AM   #7
canadian ss
Psycho on day pass
canadian ss's Avatar
Drives: 2010 yellow 1ss m6 -GM tech
Find the source of the leak while you're at it. You've lost coolant somewhere and unless you fix it, you're just wasting your money literally down the drain.
canadian ss is offline   Reply With Quote
Old 10-05-2011, 10:07 AM   #8
Caspers2SSRS
Caspers2SSRS
Originally Posted by xTHExxFALLENx View Post
Thanx very much!!
My Pleasure! Helping another Gen5 family member.......
Old 10-05-2011, 10:08 AM   #9
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
you may want to check if the thermostat is still good and is not sticking close.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs
rberns is offline   Reply With Quote
Old 10-05-2011, 10:13 AM   #10
Willt1984
Bowtie 'til I Die!
Willt1984's Avatar
Drives: 2011 Camaro CGM LS M6
Send a message via Yahoo to Willt1984
To OP:
You can google/youtube the radiator, follow the hoses or lines and check all the seals, also depending on the model year check the water pump (google/youtube) to be sure there's no leak there. I had a problem of overheating on my 04 Monte Carlo and I had a leak at the water pump, the thermostat needed to be replaced, believe it was stuck closed. All told I repaired the car myself by buying a used water pump from a salvage shop for 30 bucks that was warrantied by the shop, thermostat was 7 or 8 bucks from advanced autoparts, the haynes manual showing me how to get 'er done was 15. Anything I wasn't clear on I looked up on youtube since the impala and a potiac had the same motor.
Good luck
Willt1984 is offline   Reply With Quote
Old 08-31-2014, 09:29 PM   #11
KJS
KJS's Avatar
Drives: '10 RJT,'95&'14 Vette
Check to make sure there's no leaks, wiki or others.
"As ye sow, so shall ye reap" - Me
Mine at sunset
KJS is offline   Reply With Quote
Hellow new to the forums, and quick question Ahaftman 5th Gen Camaro SS LS LT General Discussions 17 09-02-2011 05:15 PM
Quick Question abt ARH with American Thunder Cat Back BlackMambaSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 07-03-2011 06:07 PM
quick question BiG_TiMe Cosmetics and Lighting Modification Discussions 3 04-28-2011 10:00 PM
quick question spruce26 4th Generation Camaros 7 02-14-2010 02:10 AM
Quick Question About upgraded wheels LSX-80MM Wheels and Tires Talk Sponsored by The Tire Rack 2 11-02-2009 04:07 PM
