Old 09-20-2011, 10:39 AM   #1
baranowski
baranowski's Avatar
Drives: 1968 Bronco,2001 Fatboy,2010 SS
Engine Builders please help!!!!!! Question....
OK, lets say that you are buying and old muscle car and the car comes with a "new crate motor" that has never been installed or even turned over in approx. 3-4 years.
1) What would you look for as it is out of the car and on a stand?
2) And if you bought that car what would you do to the engine to make sure that you will not have to take it back out of the car?
EX: take it to an engine builder to look it over and re lube and re touque it? if so ... cost?
Thank you for the information,
Bill Baranowski
baranowski is offline   Reply With Quote
Old 09-20-2011, 11:56 AM   #2
wylde1
I am the Stig
wylde1's Avatar
Drives: Black w/ IOM stripe 1SS
The only thing I would be worried about is surface corrosion anywhere that oil hasn't been able to rest like cylinder walls. Is there oil in it? or has it sat dry?
- flip it over and pull the pan off, look at the cylinder walls. If you don't see any surface rust, or can wipe it off easily, bolt it up and go.
-if it looks like theres some corrosion going on depending how bad it is you might want to tear it down and investigate further. Maybe take off a main cap and see how the main bearings look (looking for pitting or abrasions).
Otherwise pop that baby in the car.
Once you get it in the car
- unplug the power to the distributor. use the starter to spin the motor for a couple intervals of 10 sec's or so. This will get the oil pump distributing oil to your valvetrain and get the bearings good and lubed up.
- Plug in the power to the dizzy and start it up. Get it good and warm, maybe even drive it a few miles. Then do an oil change. That should get any built up gunk outta there.
Hopefully that helps a bit!
What are ya buyin'?
2010 Camaro - 1SS, Black w/ Orange stripes
Last edited by wylde1; 09-20-2011 at 12:00 PM. Reason: Re-read the post and realized some of my questions were already answered haha
wylde1 is offline   Reply With Quote
Old 09-20-2011, 12:33 PM   #3
baranowski
baranowski's Avatar
1966 busting flashback. 302 crate motor with three duces on it. and it is a maybe. apparently all the parts are there just needs to be put together. i am gardedly optimistic. we will see. thanks....
Old 09-20-2011, 12:34 PM   #4
baranowski
baranowski's Avatar
err damn quick word on the phone. it is a 1966 mustang fastback.
Old 09-20-2011, 12:40 PM   #5
wylde1
I am the Stig
wylde1's Avatar
Haha I thought you were making up some sort of new nickname or something.
If it's not a fully assembled motor give all the mating surfaces a good thorough check/cleaning. Particularly cylinder deck where the heads mate, and bearing surfaces.
realistically, if it was oild before storage. In 3-4 years its probably just fine. Unless it was stored in a salt mine haha.
Old 09-20-2011, 12:57 PM   #6
baranowski
baranowski's Avatar
it is all together... thanks
Old 09-20-2011, 02:06 PM   #7
baranowski
baranowski's Avatar
any other opinions or anyone agree?
Old 09-20-2011, 04:10 PM   #8
baranowski
baranowski's Avatar
ttt
Old 09-20-2011, 06:26 PM   #9
assasinator
1 n the head,2 n da chest
assasinator's Avatar
Drives: 2002 cadillac deville
if its a crate motor it should be just fine. a few years in a junk yard wont hurt it. as long as it hasnt gotten rained on, just use it. there should be assembly lube in it.
pre oil it with a drill and turn it over as few times. then start it.
if it makes you feel better put a teaspoon of oil in each cylinder and turn it over with the starter.
2011GT E85, Kooks 1-7/8", 3" offroad X, 2-7/8" overaxles, Roush mufflers, CobraJet intake, SCJ monoblade throttle body, drew 4.5" CAI, Boss302S exhaust valve springs, Baby CobraJet exhaust cams. 3.73 gears, lightweight 300A. 455rwhp @7800/410rwtq SAE 5000lb roller dynojet
assasinator is offline   Reply With Quote
Old 09-20-2011, 07:19 PM   #10
baranowski
baranowski's Avatar
thanks
Old 09-21-2011, 10:27 AM   #11
baranowski
baranowski's Avatar
tat
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 273 08-15-2023 04:44 PM
g5cr cai system anybody install or looking at one "pics" camarossrs2150 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 07-14-2011 08:26 PM
Pfadt Race Engineering releases new Camaro V8 Engine Mounts PfadtRacing Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 43 06-07-2011 12:09 PM
Acronyms? KEEP RT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 03-11-2011 08:57 PM
LS9 SC old news. Here comes the LSX. 850HP, 840 lb-ft of Torgue 13F20 5th Gen Camaro SS LS LT General Discussions 15 09-22-2008 04:35 PM
