Old 09-07-2011, 11:00 AM   #1
PC HOTROD
PC HOTROD's Avatar
Drives: 2010 Camaro SS IOM 6M
FUSE PULL: Saturn Sky Redline????
We recenly picked up 2008 Saturn Sky Redline Roadster for the wife and I'm going thru the motions of ensuring it's running at its full potential.
The first thing that came to mind is; Does the Sky suffer from the same ailment as the Camaro where the ECU drops into the Low Octane MAP when less than Premium Fuel is used and does not switch MAPS when Premium Fuel is used?
Would the Sky benefit from a Fuse Pull as the Camaro does and what fuses need to be pulled?
I've attempted to find the same wealth of information for the Saturn Sky Redline as found on the www.Camaro5.com Forum but it does not exist.
I look forward to your input.
www.MotoDivaz.com
2010 Camaro SS IOM
PC HOTROD is offline   Reply With Quote
Old 09-17-2011, 08:48 PM   #2
PC HOTROD
PC HOTROD's Avatar
Anybody?
www.MotoDivaz.com
2010 Camaro SS IOM
Old 09-18-2011, 05:30 AM   #3
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Send a message via AIM to DietCoke
Yes, it does. I owned one for a long time. Just pull the main PCM fuse, or disconnect the battery for at least 10 minutes.
DietCoke is offline   Reply With Quote
Fuse Pull Still Needed? raider8654 5th Gen Camaro SS LS LT General Discussions 15 12-20-2010 01:34 PM
Fuse Pull or Not zerox 5th Gen Camaro SS LS LT General Discussions 30 07-14-2010 08:44 PM
Fuse pull or battery disconnect? wylde1 5th Gen Camaro SS LS LT General Discussions 9 07-06-2010 01:39 PM
Saturn just may survive! Silver Streak General Automotive + Other Cars Discussion 4 02-19-2009 09:46 AM
Saturn Sky Red Line GMPP cold air intake question 496BIGBLOCK General Automotive + Other Cars Discussion 8 12-29-2008 01:50 AM
