#1 |
COTW 5/27/13
Ok so i didnt know where i should post this( MODS move it if you see fit) ,but anways
Anyone know the what the blanket is there for? to protect the hood from heat? sound damping? heat sink?
622RWHP/512FTLBS on 91 octane 2.9l Whipple 4" pulley. Vengance VRSP3 cam. Lots of BMR & AAC. Body work by Gary's Customz. Nic D tuned My build thread |
#2 |
![]() Drives: Camaro LS M6, Fiero, Ford F100 Join Date: May 2010
Mainly sound dampening.
#3 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2 LT/RS YELLOW, AUTO., VIN NO. 602 Join Date: May 2010
Bump.
#4 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: SS,PaceCar,ZL1,1LE,C7Z51,Z06,17-ZL1 Join Date: Jun 2009
The underhood blanket is a safety item.
In the unlikely event of an underhood fire, the plastic clips will burn, and the blanket will drop and help smother the flames. although it does help as sound insulation also... Last edited by JoeP@TeamBeckyD; 08-17-2011 at 07:09 AM. |
#5 | |
![]() ![]() ![]() Drives: CGM 2SS/RS, 1987 & 2014 Silverado Join Date: Oct 2010
#6 |
![]() ![]() Drives: 2011 LS Join Date: Oct 2010
Too keep your engine warm in the winter. A warm motor is a happy motor.
#7 |
X SS
Drives: 2010 Camaro 2SSRSM6 1988 Sportside Join Date: Jan 2011
This.
MODS: PEDDERS XA COIL OVERS, STAGE 3 CAM, McLEOD CLUTCH, SKIP SHIFT, , HURST SHORT THROW, CAI INTAKE, SCOOP, WASHER RELO KIT, KOOKS HEADERS, KOOKS HI FLOW CATS, CUSTOM TUNE, QTP CUT OUTS, PAINTED STRIPES, PAINTED SS EMBLEMS, PAINTED FIN, PAINTED REAR TAIL LAMP BEZELS, HERITAGE GRILLE, DUCTS, AAC STUFF, BAER ROTORS, HAWK PADS, FUZZY DICE, LASER BEAMS, DISCO BALL, SYBIAN & 3 CHROME VALVE STEM CAPS................
#8 |
Drives: 2000 Camaro SS Join Date: Feb 2010
#9 |
Let's go Rangers!
Wow, great info.
#10 |
knows 2 facts about ducks
Drives: ...and they're both wrong Join Date: Aug 2009
and Becky saves the day again
#11 |
COTW 12/3/12
Drives: 2012 Ashen Gray ZL1 Join Date: Aug 2011
Wow, I never knew this! I thought is was there for looks and sound insulation. I guess I learned something new today. Can I go home now?
#12 |
![]() Drives: 2013 Volt Join Date: Sep 2010
If that info is true, let me tell you it never happens that way. I have fought many a car fires and not once have I ever had the under hood blanket fall and smoother the fire. Every car fire I have ever had, the blanket is still firmly attached to the hood, small fires, big fires, new cars, old cars, high end, low end, it has never worked that way.
It is a sound dampening material, plain and simple. By the time a fire would have gotten big enough to melt all the plastic tabs, the car is gone anyways. |
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '86 Monte Carlo SS Join Date: Nov 2010
Engine fires draw oxygen from underneath and through the grill. Engine fires are fed by burning fuel and combustibles such as plastics and rubber. Hard to understand how an insulation blanket falling down from under the hood would help smother a fire.
#14 |
![]() Drives: 2011 Black Camaro 2SS/RS Coupe Join Date: Jul 2011
I hate to tell anyone they are wrong, but I can tell you most sales people are misinformed about the hood blanket. It in no way is intended to smother a fire. This is something that was made up long ago and I even used this in my walk around presentations long ago until I finally learned what it is.
The blanket will dampen hood noise, but is intended to protect the paint on the hood from the engine heat. TIS.
"Being persistant and never giving up may not always get the job done, but it just may annoy someone else enough to make it worth your while." |
| Understanding Brake Fluid: DOT 3, DOT 4, DOT 5.1 | TAG UR IT | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 58 | 12-01-2019 09:54 PM |
| Hot air Intakes -By Kenne bell | ADM PERFORMANCE | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 66 | 02-08-2011 08:33 PM |
| BMR Front 2 and 4 Point Strut Tower Braces! FREE SHIPPING! | AJ@ECSMotorsports | Suspension / Chassis / Brakes | 8 | 11-13-2010 03:45 PM |
| Railcar unload point for Phoenix? | FrankN | Camaro Price | Ordering | Tracking | Dealers Discussions | 3 | 07-31-2010 07:51 PM |
| List of Intakes that will work with the TVS-2300 MagnaCharger | JJ2010 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 26 | 03-19-2010 02:11 AM |
