Roto-Fab
Old 07-18-2011, 11:30 AM   #1
Nvincent4708
Drives: N/A
Guess my HP?
Okay as many of you know. I have an LSX376 in my car which is rated at 450HP out of the crate.
I'm curious to see what my car will lay down to the ground..
I have XS-Powers full kit.
I'm putting on granatelli's cold air intake here shortly.
And I have HPtuners, so tuning is no issue.
Any guesses on what I should be able to put down? BTW, I have the revised LSX376 which is 10.7:1 compression, not the original that was 9:1.
I'm hoping for atleast 400 wheel.
Old 07-18-2011, 11:38 AM   #2
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
Hmmm ... I say with headers, intake and tune = 425 RWHP / 430 RWTQ
Based on what I've seen LS3 do with the same setup ...
SlingShot is offline   Reply With Quote
Old 07-18-2011, 11:53 AM   #3
Nvincent4708
Drives: N/A
I'd be happy with that.
Old 07-18-2011, 12:52 PM   #4
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
nancygrl is offline   Reply With Quote
Old 07-18-2011, 01:35 PM   #5
Nvincent4708
Drives: N/A
I will be posting dyno sheets once i'm done..but that could be a month or two
Old 07-18-2011, 01:47 PM   #6
CamaroKid300
ace5.org
CamaroKid300's Avatar
Drives: 2017 ZL1 M6
You were the guy who threw a pushrod or something through the engine right? So you had to buy a new motor on your own?
Stock...For Now.
CamaroKid300 is offline   Reply With Quote
Old 07-18-2011, 02:30 PM   #7
Nvincent4708
Drives: N/A
Yeah through a connecting rod through the block.. yeah bought a new motor on my own.
Old 07-18-2011, 02:55 PM   #8
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
I read this over in the Vette forum. You might want to read it. The lower compression (made for forced induction) seems to be holding it back NA.
This guy made 403 rwhp with full bolt ons and tuning on his LSX 376.
Here's the quote:
So I purchased this engine, under the impression it made 450 hp (with a stock style setup (LS3)) Well I have mine set up that way, and after doing some thinking, tuining, and dynoing my car is where it should be with this engine. However, I think they should use their claimed HP numbers and lower them from the crate LS3. Because this motor was built for boost, and is essentially a LS3. Yet the compression ratio is 9:1. Making it have less power. Both have the same size cubic inches, heads, cam, the pistons are forged on the LSX 376 however, and the block is made of iron instead of aluminum. My setup consisted of:
99 FRC with a LSX 376
LSX 376 Long block
LS3 intake manifold
Kooks 1 7/8 long tubes
Kooks off road X pipe
Borla Straight pipe
Vararam Intake
LS3 Water Pump
LS3 Throttle Body
I did some "bench dynos" and with the claimed 450 HP the engine should have, I guestimated roughly 430 RWHP with the mods.These numbers would be correct if the compression ration was higher. But I believe my best numbers for today after tuning were
403 rwhp 396 rwtq
Which would be spot on for a lower compression LS3. Now I just wish GM would market that crate engine like that. Im a little disappointed because of the 450 HP claim. Not saying it is not true, it's just not true with the LS3 configuration or "Production Style" as they claim. Overall I'm happy though, because when I do throw a blower on it will be ready to handle it!
SGOS252382 is offline   Reply With Quote
Old 07-18-2011, 02:58 PM   #9
Texas2SS
Vroom
Texas2SS's Avatar
Drives: Rarely
With full exhaust and a Cold Air intake I'm guessing 415.
LSX, Boost, 9", TH400
xxxxhp - xxxtrq
Texas2SS is offline   Reply With Quote
Old 07-18-2011, 03:06 PM   #10
Nvincent4708
Drives: N/A
Here's the quote:
LSX 376 Long block
LS3 intake manifold
Borla Straight pipe
Vararam Intake
LS3 Water Pump
LS3 Throttle Body
403 rwhp 396 rwtq
Most educated guess yet... guess it's going to be the dyno that tells the truth. I mean I am doing a supercharger next year..so if i don't like the number, i'm sure i can make it something I like.
Old 07-18-2011, 03:08 PM   #11
SGOS252382
SGOS252382's Avatar
Yeah, with that lower compression you should be able to safely turn up the boost. So in the long run, you should be able to make more HP (safely) than if you were running a regular LS3.
Old 07-18-2011, 03:09 PM   #12
Nvincent4708
Drives: N/A
Yeah, with that low compression you can safely turn up the boost. So in the long run, you should be able to make more HP (safely) than if you were running a regular LS3.
Especially with the forged pistons.. I'm only going to put 6-8psi through it. I figure that'll be enough to make me smile all day.
Old 07-18-2011, 03:13 PM   #13
The Stig
knows 2 facts about ducks
The Stig's Avatar
I'm assuming we are doing this Price is Right style correct? Well if we are, I say 1 rwhp 1 rwtq
Click to view my build thread
Old 07-18-2011, 03:16 PM   #14
Nvincent4708
Drives: N/A
I think i'll do this on the "whoever is closest" scale.
guess what i saw at work today... Bumblebee Camaro from TF3 ! tmurphycardesign 5th Gen Camaro SS LS LT General Discussions 53 03-10-2011 08:39 AM
Well I guess Splash Guards are going on zerox 5th Gen Camaro SS LS LT General Discussions 16 12-04-2010 03:13 PM
Guess that car. shank0668 Off-topic Discussions 32 04-10-2010 01:53 AM
HEY, GUESS WHAT HAPPENED billmiller8 5th Gen Camaro SS LS LT General Discussions 4 02-20-2010 06:07 PM
2010 Camaro Engine Line-Up Guess camaro5 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 75 04-11-2008 02:25 PM
