#1 |
![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS RS M6 Join Date: Mar 2011
Spark plugs on 2002 Dodge Neon
As a small favor to a friend who's afraid of a wrench, I volunteered to swap out the spark plugs on his daughter's POS 2002 Dodge Neon yesterday. It has a 2.0 liter SOHC inline 4 cylinder engine in it. I had never run into this kind of engine before and was surprised to find that the spark plugs are recessed in "shafts" about six inches! I put an exclamation mark there just because I had never seen that set-up before and was lucky that I had an extension for my ratchet long enough to reach down in there.
BTW, at the bottom of the middle two and surrounding the spark plugs was a fair amount of oil, so that can't be a good thing. Any ideas what would be the cause of that on these engines??? |
#2 |
![]() ![]() ![]() ![]() Drives: 12 Boss 302 Join Date: Sep 2009
Recessed plugs are nothing new, and the oil is coming from the valve cover gasket where it seals around the tubes. Simple fix, but make sure the valve cover gasket set includes the O-rings for the tubes.
The biggest mistakes in life come when you know exactly what you are doing.
#3 |
![]() Drives: 2011 Mustang GT Join Date: Mar 2011
There is a reason why even Dodge now crushes these vehicles in their own commercials.
#4 |
Drives: SuperCharged 2SS/RS IOM MN6 Join Date: May 2009
nothing new...oil in there means leaky valve cover gasket. this reminds me I need to change the vc gasket on my 95 bmw. Pain!
#5 | |
| Best Spark Plugs? | Sarah | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 9 | 06-13-2011 04:10 PM |
| Changing spark plugs and wires - LS3? | IndeedSS1 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 11 | 01-09-2011 02:46 PM |
| E3 Spark Plugs | barking tires | Tuning / Diagnostics -- engine and transmission | 7 | 09-06-2010 10:31 AM |
| 2009 Dodge Challenger Press Release (introducing model lineup) | Tran | General Automotive + Other Cars Discussion | 8 | 03-20-2008 12:47 AM |
| Ontario to become home of the all-new 2008 Dodge Challenger | Mr. Wyndham | General Automotive + Other Cars Discussion | 3 | 08-09-2007 02:54 AM |
