Old 06-11-2011, 12:53 PM   #1
Arachnyd
Master of all trades
Arachnyd's Avatar
Drives: 2many2count
carb Jeep: Drove great yesterday, won't start today. Gets spark and gas- any ideas?
Checked for spark, spark is good. Killed a battery and melted a starter solenoid trying to get it to start. replaced both. It has gas going to the carb- unhooked gas line and let it shoot at me. looking in from top of carb, gas is going in when I pump it.
If I hold down the gas when I try to start it (after pumping it a few times) it sounds like it wants to start, and will give me a few turns after the starter stops, but it never roars to life. My neighbor agrees that it sounds like its starving for fuel, but you can see the fuel going into the carb. I pulled apart the carb, cleaned everything, replaced gaskets and seals.
Wouldn't do anything more than normal when I tried starter fluid.
Any idea what I should try? should I replace plugs and stuff just in case?
It started up and ran perfectly until today though, so thats why I'm real confused.
Its an 80 CJ7 straight 6 5 spd manual . I asked this on the jeep forum and got no response??
Thanks!
2010 Camaro SS modified extensively. I stretched the body to make it a 4 door, but I swapped in the 3.6L DI V6 for fuel economy. Then I picked up a corvette body around the V8. I also swapped the body for a C2 Z28. (In short I traded it for three cars, a Corvette Z06r, a C2 Camaro Z28, and a Cadillac CTS Summer Performance package 3.6L DI with Aisin 6spd.)
Arachnyd is offline   Reply With Quote
Old 06-11-2011, 01:01 PM   #2
Cristoff
Cristoff's Avatar
Drives: 2011 Camaro 2LT RS in Red Jewel
Thanks!
Sounds almost like a timing issue to me but I haven't really worked on cars that much since 1987.
Perhaps the distributer came loose. I have actually had that happen on my 72 Nova. The bolt came loose and spun the distributer around.
Yes, this is my Camaro parked in front of the Infiniti Dealership that I run. No, my boss is not happy...
Cristoff is offline   Reply With Quote
Old 06-11-2011, 01:45 PM   #3
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Drives: '69 Z/28 LeMans Blue w/White
Pull the plugs! They will tell you what you need to know.
-Mark.
Stingr69 is offline   Reply With Quote
Old 06-11-2011, 02:11 PM   #4
Arachnyd
Arachnyd's Avatar
Drives: 2many2count
How does it sound like a timing issue? (not doubting, just curious). Distributor appears to be distributing spark OK , I tested a few plugs, each getting spark.
-Mark.
What should I look for? Pulled a few and they didn't look fouled or anything- no buildup. Getting spark at the plugs? No oil/liquid. they are dry?
Old 06-11-2011, 02:22 PM   #5
Cristoff
Cristoff's Avatar
Just throwing out possibilities for elimination based on my less than extensive knowledge of High School auto mechanics class.
The basics:
Fuel
Spark
Air
Timing
You already pretty much eliminated Fuel and Spark and air.
Old 06-11-2011, 02:26 PM   #6
Arachnyd
Arachnyd's Avatar
Drives: 2many2count
The basics:
Fuel
Spark
Air
Timing
Makes sense. Timing is the one part of cars I don't really get either. Maybe its time to call in a professional... haha...
I'm wondering if something crazy might be going on though... like a blockage in the intake manifold? I know its unlikely, but still. I guess I can further research the timing situation. its hard to comprehend what could be wrong with timing if you didn't change anything though, right?
Old 06-11-2011, 04:02 PM   #7
Cristoff
Cristoff's Avatar
Very true
Old 06-12-2011, 02:33 PM   #8
Arachnyd
Arachnyd's Avatar
Drives: 2many2count
Interesting... It looks like I jumped a tooth or two on the timing chain. Pat yourself on the back Cristoff!
Old 06-12-2011, 02:38 PM   #9
Cristoff
Cristoff's Avatar
Holy crap?!? I was actually right!
Glad as heck you found it! Good job and glad to help.
