Old 06-09-2011, 08:39 PM   #1
TOMS1SS
Drives: NA
13 story building tipped over
Apparently they were putting in a garage next to the building and a storm dug out the foundation:
Anyone who bought an apartment here sure has a problem. Talk about a collapsed market!
YES, IT'S An ENTIRE 13-STORY BUILDING IN CHINA LYING ON THE GROUND.
(1) An underground garage was being dug on the south side of the building, to a depth of 4.6 meters (15 ft).
(2) The excavated dirt was being piled up on the north side of the building, to a height of 10 meters (32 ft).
(3) They dug right up to the base of the building.
Then the rains came.
(4) The building experienced uneven lateral pressure from north to south.
(5) This resulted in a lateral pressure of 3,000 tonnes, which was greater than what the un-reinforced pilings could tolerate. Thus, the building completely toppled-over in a southerly direction.
*First, the apartment building was constructed.*
Then the plan called for an underground garage to be dug out. The excavated soil was piled up on the other side of the building.
*Heavy rains resulted in water seeping into the ground.*
The building began to tilt. Then it began to shift, and the "hollow" concrete pilings were snapped due to the uneven lateral pressures.
And thus was born the eighth wonder of the world.
If these buildings were closer together,
it would have resulted in a domino effect.
Notice that there's NO rebar in the pilings!
Just some wire mesh.
They built 13 stories on grade, with no basement,
and tied it all down to hollow pilings with no rebar.
Brought to you by the same folks that make your kids' toys
and want to build your next car.
Now that, folks, is a true snafu.
Don't you feel better now that these are the folks that
manufacture nearly EVERYTHING we buy and use today?
One more product "MADE IN CHINA "...!!
Old 06-09-2011, 08:59 PM   #2
4g63t
Drives: 1990 rs 3.1 v6
13 story 13 very unlucky number should never build just 13... thats why elevators dont have a floor 13 lmaoo
4g63t is offline   Reply With Quote
Old 06-09-2011, 09:03 PM   #3
Transfusion
Transfusion's Avatar
Drives: 1SS Summit White
i like how it managed to fall in one piece
Transfusion is offline   Reply With Quote
Old 06-09-2011, 09:05 PM   #4
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
DAMN CHINESE DRYWALL!!!
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 06-09-2011, 09:11 PM   #5
TOMS1SS
Drives: NA
Old 06-09-2011, 09:13 PM   #6
4g63t
the fact that its in one piece does say something about there work
Old 06-09-2011, 09:15 PM   #7
4g63t
just get a crane lift it back up and replace it lol
Old 06-09-2011, 09:21 PM   #8
TOMS1SS
Drives: NA
So much for building codes
Old 06-09-2011, 09:26 PM   #9
TOMS1SS
Drives: NA
Old 06-10-2011, 08:00 AM   #10
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
Overburden pressure + rain = bad news
My VIN = 2G1FK1EJ9A9105017
Old 06-12-2011, 06:57 PM   #11
Transfusion
Just dig another tunnel on the other side
Old 06-12-2011, 06:59 PM   #12
Transfusion
those damn crafty chinese
You won't believe this story folks. The HORROR! MacTruck 5th Gen Camaro SS LS LT General Discussions 152 01-30-2010 06:49 PM
My Camaro Story GSmithPharmD08 Member Car Journals 38 01-23-2010 08:10 AM
Camaro5 member feature story in the Providence Journal (R.I.) PAUL SS USA - New England 1 10-26-2009 01:32 PM
GM Building New GEN-5 V-8 in St. Catharines camaro5 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 47 09-22-2009 12:34 AM
Warning: long and boring story of how the camaro changed my life. byebyeImports 5th Gen Camaro SS LS LT General Discussions 15 08-28-2007 12:18 AM
