Old 08-24-2006, 07:41 PM   #1
KILLER74Z28
MOD SQUAD
KILLER74Z28's Avatar
Drives: 2G1FT1EW9A9100666
2007 GT500
2007 FORD SHELBY COBRA GT500
Vehicle type: front-engine, rear-wheel-drive, 4-passenger, 2-door coupe
Estimated base price: $39,000
Major standard accessories: power windows, driver seat, and locks; remote locking; A/C; cruise control; tilting steering wheel; rear defroster
Sound system: Shaker 500 AM-FM radio/CD changer, 8 speakers
ENGINE
Type: supercharged and intercooled V-8, iron block and aluminum heads
Bore x stroke: 3.55 x 4.17 in, 90.2 x 105.8mm
Displacement: 330 cu in, 5409cc
Compression ratio: 8.4:1
Fuel-delivery system: port injection Supercharger Eaton R122, Roots type
Maximum boost pressure: 10.0 psi
Valve gear: chain-driven double overhead cams, 4 valves per cylinder, hydraulic lifters
Power (C/D est): 500 bhp @ 6000 rpm
Torque (C/D est): 450 lb-ft @ 3750 rpm
Redline: 6000 rpm
DRIVETRAIN
Transmission: 6-speed manual
Final-drive ratio: 3.31:1, limited slip
DIMENSIONS
Wheelbase: 107.1 in
Track, front/rear: 61.9/62.5 in
Length/width/height: 188.0/73.9/55.7 in
Ground clearance: 5.7 in
Curb weight: 3896 lb
Weight distribution, F/R: 57.7/42.3%
Curb weight per horsepower: 8.1 lb
Fuel capacity: 16.0 gal
CHASSIS/BODY
Type: unit construction
Body material: welded steel and aluminum stampings
INTERIOR
SAE volume, front seat: 53 cu ft
rear seat: 30 cu ft
luggage: 13 cu ft
Front-seat adjustments: fore-and-aft, seatback angle; driver only: front height, rear height, lumbar support
Restraint systems, front: manual 3-point belts, driver and passenger front and side airbags
rear: manual 3-point belts
SUSPENSION
Front: ind, strut located by a control arm, coil springs, anti-roll bar
Rear: rigid axle located by 2 lower trailing links, 1 upper;trailing link, and a Panhard rod; coil springs; anti-roll bar
STEERING
Type: rack-and-pinion with hydraulic power assist
Steering ratio: 15.7:1
Turns lock-to-lock: 2.6
Turning circle curb-to-curb: 39.0 ft
BRAKES
Type: hydraulic with vacuum power assist and anti-lock control
Front: 14.0 x 1.3-in vented disc
Rear: 11.8 x 0.8-in vented disc
WHEELS AND TIRES
Wheel size/type: 9.5 x 19 in/cast aluminum
Tires: Goodyear Eagle F1 Supercar
PERFORMANCE (C/D est)
Zero to 60 mph: 4.5 sec
Standing 1/4-mile: 12.9 sec @ 112 mph
Top speed (governor limited): 155 mph
PROJECTED FUEL ECONOMY (C/D est)
EPA city driving: 13 mpg
EPA highway driving: 21 mpg
KILLER74Z28 is offline   Reply With Quote
Old 08-25-2006, 04:07 AM   #2
jbynum69
God of thunder
jbynum69's Avatar
Drives: 95 Mustang GT
this is a good looking car but has problems:
1. what is with the cars made today with that lower body molding that seems to be always black(and plastic) , its even that way on the new vette.
2. 0-60 in 4.5 seconds with 500 hp and 450 trq with a supercharger on it ???
my 05 gto has 425 hp and 405 trq and does 0-60 in 4.5 seconds without a superdupercharger!!
3.the new shelby is also right at 4000 lbs(can we say f150 please) dang! with that much body weight it probably will be hard to modify because most of the wieght is in the front for the engine block is cast iron( this is a good thing though, no worry of over heating problems as much as do i with my aluminum block 6.0.
all around this a pretty good idea for a muscle car but I would never pay 42000 dollars for a crustang (wait, its a ford ,sorry, I would not buy it anyways) . the actual price will vary because of tax , title, shipping cost ,blah blah blah.
some might say: EPA city driving: 13 mpg
There is no way I would buy a car that gets this kind of gas milage (probably spelled wrong but it's friggin early for me 5:44am ok) .
Well this will settle this litte prob. right now . If you want a car that has 500 hp and also want to protect your wallet and the earth , MAKE ONE !!!
I am tired of this biatchin over gas crap and the earths demise crud, if you are this worried over the gas stop buying it and get a bicycle (also God gave you friigin legs ,and contrary to popular demand we use to walk to every where before the wheel and motor cart unless you had a horse) the earth will probably be offing us anyways ,because it is a planet. read up on other planets we don't live on and you will see the same kind of crud ,storms and all because it is a planet out of our control.
sorry ranting is funnnnnnn.
Peace be with u all . I am smiling now.(thorazine please)
jbynum69 is offline   Reply With Quote
Old 08-26-2006, 12:59 AM   #3
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
I really don't like Fords and I will never buy one. But..............I saw this same Shelby Cobra GT 500 today passing me on the road (in the opposite dirction of course!!!). Well, it wasn't the same, but it was identical in color. I have to hand it to Ford, this was one good lookin Mustang. still wouldn't buy one though....hehe
Old 12-11-2006, 11:09 AM   #4
TAG UR IT
TAG UR IT's Avatar
This is funny as all hell!
Old 12-11-2006, 11:19 AM   #5
Moose
Moderator
Moose's Avatar
Drives: '99 Camaro SS #1392
There are 2 Shelby's around here. Not bad, but for what the dealers are charging, I'll take a C6 ZO6, and it'll smoke the Shelby.
On a related note, a local dealer somehow got a 'Hertz' Shelby with around 11 mi. on the odometer. So, I had to see how they got it, and what they were asking.
Ready??!! $90K! That is just STUPID!
Moose is offline   Reply With Quote
Old 12-11-2006, 11:19 AM   #6
LowRider
LowRider
LowRider's Avatar
Drives: 1992 Camaro Z28 & 1996 S-10
Send a message via AIM to LowRider Send a message via Yahoo to LowRider
That is funny I am a teachers aid right now setting in class and can't laugh to loud or he will kick me out. But inside I am laughing my ass off. But I still would not buy one.
LowRider is offline   Reply With Quote
Old 12-11-2006, 11:26 AM   #7
TAG UR IT
TAG UR IT's Avatar
Would I drive it? Hell yeah. I'll be honest. But, I sure as hell wouldn't dish out $90K. That is just nuts. That's what pisses me off about Ford. "Let's build some bad @ss cars that are special editions. Let's call them GT500 and Shelby GT. When we put them up for sale, we won't produce hardly any at all and we'll charge such a high price that only a few people could afford them. Yeah, that sounds like a good idea!" WTF are these people thinking?!?!?!?!?! Make more, make'em less expensive so more people can own them, more people can get into your product line, and you will keep more customers for life. Freakin morons...90K my @ss.
Old 12-11-2006, 11:27 AM   #8
TAG UR IT
TAG UR IT's Avatar
That one in the video looks like the Hertz, no?
Old 12-11-2006, 11:30 AM   #9
Moose
Moderator
Moose's Avatar
Here's the 'Hertz' Shelby
Old 12-12-2006, 12:56 AM   #10
KILLER74Z28
MOD SQUAD
Yes it is. I am shur we will never see it on Network TV. To Bold...
Old 12-12-2006, 01:35 AM   #11
KILLER74Z28
MOD SQUAD
I have to give it to Ford for their Commercials. GM better have something up their sleeves to top them. Here are some other good commercials from ford.
Old 12-12-2006, 02:25 AM   #12
TAG UR IT
TAG UR IT's Avatar
Love the Seve McQueen commercial. That was a good one. I don't know how many commercials GM will come out with seeing as though they are going to have a ton of publicity with the trasformers movie. They better have some good ones, though. Hopefully we see that war with Ford and Dodge.
Old 06-22-2007, 02:31 AM   #13
AFSNightrod
Back in Black
AFSNightrod's Avatar
Drives: 2005 Cadillac CTS-V
Send a message via AIM to AFSNightrod Send a message via Yahoo to AFSNightrod
Sorry to get off topic for a minute, but concerning the GT500: I went to Freedom Ford in Newport News, VA asking about the car in early 2006. They told me straight to my face that MSRP started at 42K, and that they would be marking it up to somewhere around 65K due to demand. What kind of work ethic is that? I hope the local Chevrolet dealerships are not like that.
AFSNightrod is offline   Reply With Quote
Old 06-22-2007, 05:38 PM   #14
EllwynX
EllwynX's Avatar
Drives: 2010 Camaro SS
I was actually going to mention something like this myself, but wasn't sure if it really fits since it's a Ford dealership.
I was out with a female friend the other day looking for a used truck for her. While at the dealership walking around with the dealer that came out to pester us, I commented that I myself was waiting for the Camaro. (He didn't really say much about it other than I heard something about $60,000 and I had to correct him that it should be in line with the Mustang's pricing.)
Anyway, he mentioned they had just sold a GT500 for $15,000 OVER MSRP.
I chuckled and told him I'd NEVER pay over MSRP for a vehicle. His response, of course, was that I will for that Camaro. I just told him I'd wait a while before getting one, because I refuse to pay over msrp. Conversation ended there pretty much. At least regarding the Camaro it did.
So don't use Lilliston Ford in Vineland, NJ if you don't want a markup on anything.
EllwynX is offline   Reply With Quote
Future Products—General Motors KILLER74Z28 General Automotive + Other Cars Discussion 5 11-14-2012 04:07 PM
2007 Ford Mustang Shelby GT500 Convertible KILLER74Z28 General Automotive + Other Cars Discussion 10 04-11-2008 04:11 PM
Out early 2008. pre-production 2007 ? boxmonkeyracing 5th Gen Camaro SS LS LT General Discussions 23 08-21-2007 10:46 PM
