Old 04-27-2011, 01:41 PM   #1
IrocJack
IrocJack's Avatar
Drives: 2010 2LT/RS RJT
EGR cleaning
Any you guys had any luck cleaning a EGR valve?
2004 Galant with Service Engine Soon light, showing a code for EGR valve.
I'm guessing some carb. cleaner ?
Thanks,
IrocJack is offline   Reply With Quote
Old 04-28-2011, 10:58 AM   #2
IrocJack
IrocJack's Avatar
Any suggestions, anyone?
Clean or replace?
Thanks,
Old 04-28-2011, 12:07 PM   #3
ffrcobra_65
Drives: SuperCharged 2SS/RS IOM MN6
definitely replace.
ffrcobra_65 is offline   Reply With Quote
Old 04-28-2011, 02:02 PM   #4
cab2g
love. my. car.
cab2g's Avatar
Drives: 2011 2SS/RS
btw, your sensor may be broken not your valve. My truck had a broken EGR valve position sensor. They replaced the valve itself only to find out that my check engine light came on again a month later due to the faulty sensor. So see if you can have the mechanic test the sensor before actually replacing the valve.
cab2g is offline   Reply With Quote
What do all the abbreviations mean? CrzyGamr2 5th Gen Camaro SS LS LT General Discussions 77 12-07-2012 04:34 AM
Acronyms? KEEP RT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 03-11-2011 08:57 PM
EGR Valve Replacement - Help Appreciated ss ZHO 4th Generation Camaros 4 07-26-2010 08:31 PM
Fuel Injection cleaning Dentyneice Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 2 06-04-2010 12:16 PM
Best Cleaning Supplies GoldFire Cosmetics and Lighting Modification Discussions 52 02-06-2009 11:50 AM
