Old 02-08-2011, 09:01 AM   #1
IrocJack
IrocJack's Avatar
Drives: 2010 2LT/RS RJT
2002 Silverado check engine light
I have codes po171, po420, po440 and po174 anyone have a good idea where to start? I have researched all these and it could be anything from MAF being dirty to a o2 sensor to the evap. hoses. I did replace the gas cap.
Any ideas?
Truck is hard to start in the mornings when it's cold but runs fine afterward.
Thanks,
IrocJack is offline   Reply With Quote
Old 02-08-2011, 10:08 AM   #2
Russell James
Russell James's Avatar
Drives: '15 SS 1LE, '69 Z28 drag car
Start with the P0440. Fix the large evap leak first. Could be as simple as the gas cap or a large vacuum leak. Fix it, clear it, make sure it doesn't come back.
Then I'd move on to P0171. Follow the service manual diagnosis for that one and determine why the air/fuel is out of whack. It's too lean for some reason. It will have you monitor the front O2's, check for vacuum leaks. Vacuum leak very possible on an older vehicle, also lazy 02's if they are the original ones. Clogged injectors possible... that often gives very poor cold start, and hesitation problems.
Dig into P0420 last. That is for the cat converter efficiency. I'd get it running correctly first so P0171 and P0174 don't come back. Something is making it way too lean. Once it's running right, clear everything and see if P0420 comes back. Then you'll have to determine if the cat conv. is actually bad or just a bad rear 02 sensor.
Clogged injectors are possible on something that old. Some injector cleaner like Chevron w/Techron in a tank full of premium wouldn't hurt. GM top engine/injector cleaner is also good stuff, has the same Techron cleaner. Change the oil after that tank of gas and cleaner.
Russell James is offline   Reply With Quote
Old 02-08-2011, 10:55 AM   #3
IrocJack
IrocJack's Avatar
Cold air intake/ Check Engine light. Need Help! edcamaro29 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 64 02-17-2024 04:40 PM
CHECK ENGINE LIGHT... Camaro10LT 5th Gen Camaro SS LS LT General Discussions 9 11-22-2010 04:49 PM
GM Reveals 2011 Chevrolet Silverado HD FenwickHockey65 General Automotive + Other Cars Discussion 55 03-04-2010 01:56 PM
P0300 Misfire Code Help black-knight 4th Generation Camaros 4 02-08-2010 01:45 PM
Voice Your Comments/Suggestions/Input for Focus Group on 2010 Camaro Mr. Wyndham 5th Gen Camaro SS LS LT General Discussions 235 04-22-2008 12:43 AM
