Old 02-07-2011, 11:02 PM   #1
GM Reveals 2012 Buick Regal w/ eAssist: 37 MPG Highway
2012 Regal to Offer New eAssist™ Fuel-Saving Technology
Link to Press Release
Link to Article at GMInsideNews
February 8, 2011
CHICAGO – Buick announced the 2012 Regal with eAssist™ fuel-saving technology, which improves overall fuel economy by 25 percent over the 2011 four-cylinder/six-speed powertrain. Estimated fuel economy is 26 mpg city and 37 mpg on the highway (pending EPA certification).
Regal with eAssist joins the 2012 LaCrosse as the second Buick to feature the efficiency-enhancing technology. The system uses a state-of-the-art lithium-ion battery system, electric induction motor-generator and regenerative braking capability to improve fuel economy. Its fuel economy tops competitors such as the Acura TSX, rated at 22 mpg city and 31 mpg highway. Regal’s estimated 37 mpg on the highway is 20 percent greater and the TSX doesn’t offer a six-speed automatic transmission, which is standard on the Buick.
“Buick’s eAssist technology means customers don’t have to trade a premium driving experience for efficiency,” said Tony DiSalle, vice president of Buick marketing. “We believe Regal and LaCrosse with eAssist provide more logical and affordable choices, compared to other hybrid midsize and full-size luxury sedans.”
Regal with eAssist goes on sale this fall. It joins an expanding lineup that also includes 2.4L and 2.0L Turbo (with manual transmission) models, as well as the upcoming Regal GS. Regal with eAssist offers the range of luxury and convenience packages offered in the other models, along with unique features that include:
• Lightweight 17-inch alloy wheels and tires with lower rolling resistance
• A driver-selectable, fuel economy-optimizing mode for the air conditioning system, which enables more frequent and longer-duration engine stop periods
• An ECO gauge on the instrument panel that continuously responds to driving behavior, enabling the driver to drive with greater efficiency
• A powerflow readout in the 7-inch infotainment screen, which shows the flow of energy through the electric assist system, such as battery charging from regeneration and electric power directed to the engine.
eAssist details
Mated to Regal’s 2.4L Ecotec direct injection four-cylinder engine and next-generation six-speed automatic transmission, the eAssist system uses power stored in the battery to provide needed electrical boost in various driving scenarios, optimizing engine and transmission operation. An advanced 115V lithium-ion battery and latest-generation 15-kW induction motor-generator unit help increase fuel economy through:
• Regenerative braking, which provides up to 15 kW of electricity to charge the battery
• Providing up to 11 kW (15 hp) of electric power assistance during acceleration
• Automatic engine shut-off when the vehicle is stopped
• Aggressive fuel cut-off during deceleration down to zero vehicle speed, enabled by the torque smoothing provided by the induction motor-generator unit
• Intelligent charge/discharge of the high-voltage battery.
“The capability to deliver electric boost to the powertrain system during heavy acceleration and grade driving enables the engine and transmission to operate more efficiently,” said Steve Poulos, global chief engineer of the eAssist system. “Full fuel shutoff at stops and during deceleration complements electric boost and regenerative braking with additional fuel savings.”
Regal with eAssist technology also features improved underbody aerodynamics and tires optimized for performance and fuel economy. It also features a hill-assist system that captures brake pressure to help the driver more comfortably accelerate from a stop on a moderate or steep grade. It does this by greatly reducing the tendency of the vehicle to roll backward with the engine in shut-down mode.
The eAssist system’s 115V air-cooled lithium-ion battery bolsters the 2.4L Ecotec four-cylinder engine with approximately 11 kW (15 hp) of electric power assist during heavy acceleration and 15 kW of regenerative braking power. The system also enables the Ecotec engine to shut down fuel delivery in certain deceleration conditions, which saves additional fuel. While in fuel shut-off mode, the induction motor-generator unit continues spinning along with the engine to provide immediate and smooth take-off power when the driver presses on the accelerator. Then, as the vehicle comes to a stop, the induction motor-generator unit spins the engine, bringing it to a smooth stop – properly positioned for a smooth restart.
“The battery system is designed to provide power assistance to the internal combustion engine, rather than store energy for all-electric propulsion,” said Poulos. “It’s really an extension of the conventional internal combustion engine, not a replacement for it.”
The eAssist power pack contains the lithium-ion battery pack, the integrated power inverter and 12V power supply. It is located in a compartment between the rear seat and trunk; and it is surprisingly compact and lightweight, weighing only about 65 pounds (29 kg). Trunk space is slightly reduced when compared with 2011 models with the four-cylinder/six-speed powertrain, but still offers 11.1 cubic feet (314 liters) of storage. A quiet electric fan cools the power pack, drawing air from a vent located in the package tray, behind the rear seat.
The eAssist system’s electric induction motor-generator is mounted to the engine in place of the alternator to provide both motor assist and electric-generating functions through a unique engine belt-drive system. The induction motor-generator is a high-performance, compact induction motor that is liquid-cooled for increased performance and efficiency.
Next-generation six-speed
The eAssist system works with Regal’s direct injected 2.4L Ecotec four-cylinder and next-generation six-speed automatic powertrain combination. In the Regal with eAssist, the engine is rated at 182 horsepower (136 kW) and the next-generation Hydra-Matic 6T40 takes transmission technology to the next level with features designed to enhance powertrain efficiency.
Significant internal transmission changes to clutch controls and hardware provide reduced spin losses while improving shift response and time. The added electric power provided by the eAssist system allows for higher gearing to improve steady state efficiency without impacting acceleration performance or driveability. The system’s ability to provide some electric assistance at cruising speeds allows the driver to accelerate lightly or ascend mild grades without the transmission downshifting.
An auxiliary, electric-driven transmission oil pump is added to the 6T40, which keeps the transmission primed and the fluid flowing when the engine shuts down at a stop. That keeps the transmission ready to perform when the driver accelerates, for a seamless, uncompromised driving experience.
Photography
Old 02-07-2011, 11:20 PM   #2
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
very nice
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 02-07-2011, 11:26 PM   #3
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
NIiiiiiiice!!
Old 02-08-2011, 01:40 AM   #4
Revo1
Don't Like it? Suggit.
Drives: 2010 2SS/RS
This looks way too slick. How is my dad ever going to adjust? ;laugh:
Old 02-08-2011, 01:45 AM   #5
truth411
Drives: 2022 SS 1LE
Sweet. I wonder if the 2013 malibu will use a similar setup.
truth411 is offline   Reply With Quote
Old 02-08-2011, 07:14 AM   #6
Mr. Wyndham
From what I understand, Buick's eAssist system doesn't cost a whole lot, right?
Old 02-08-2011, 08:06 AM   #7
The system is fairly cost-effective.
Old 02-08-2011, 12:23 PM   #8
DGthe3
Moderator.ca
DGthe3's Avatar
I imagine that a lot of GM's larger vehicles (midsize and up) will get e-assist.
Old 02-08-2011, 04:42 PM   #9
This just in...
Touch-screen infotainment system and display are now standard on all 2012 Regals.
Verano may follow suit.
Hit 30.5 MPG Highway & secondary roads. TooCool5 5th Gen Camaro SS LS LT General Discussions 2 09-03-2009 08:13 PM
Saturn Vue going to Buick, Two-Mode Plug-In Available FenwickHockey65 General Automotive + Other Cars Discussion 3 08-06-2009 09:51 PM
GM Canada says 245 dealerships getting axed 321LATER Canada 26 05-23-2009 03:30 PM
Ready or not: 36 MPG by 2015 mandate from Feds Scotsman 5th Gen Camaro SS LS LT General Discussions 76 03-07-2009 03:19 PM
GM Reveals 2010 Buick LaCrosse! FenwickHockey65 General Automotive + Other Cars Discussion 49 01-11-2009 01:28 PM
