Old 02-03-2011, 03:00 PM   #1
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
Truck Owners DIY roll on bed linner
Id like to do some of that roll on / brush on bed linner in a can but want one that will stay black for a long time. Not fade or change color from UV rays n such. Im parked in the sun 24/7 365 and want it to stay nice and black.
Anyone have any luck with that?
Or yours get so dirty at times ya never noticed?
Old 02-03-2011, 05:29 PM   #2
bigted83
They call me captain slow
bigted83's Avatar
Drives: 2010 camaro lt
I used herculiner inside my jeep on the floor, it's held up nice and is easy to apply and u can find it like autozone or those places, herculiner makes a chemical u just mix in to the can with the liquid liner that prevents fading. And if u do it u may want to add more then 2 coats. And with herculine it comes in more than one color
bigted83 is offline   Reply With Quote
Old 02-03-2011, 06:10 PM   #3
shank0668
shank0668's Avatar
My brother did the same in his jeep.
Old 02-03-2011, 06:40 PM   #4
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
found some review on herculiner, the tacky gooey part bothers me the most.
Says to bring it back to life you armorall it
Maybe I need a new approach, cause Im not doing a bed linner.
I want to use it to add texture to my wagons paint theme, I wanted to do the hood and most of the roof. Sort of a omage on the primer black hood done back in the day on performance cars. But with texture. Also since I don't have a roof rack when I carry wood or such on the roof it wouldn't slide all over. But if it got gooey in the heat, id be finger printed up in the summer months.
Pros
Helps to dampen some of the road noise.
Easy enough to do it yourself.
It's repairable, since it bonds to itself... just touch it up with more Herculiner!
Is so professional in appearance, that most people think it's a spray-on bedliner, and that you paid
Prevents things from sliding around in the back due to its slightly bumpy texture
Cons
Nearly impossible to remove from skin.
Red, gray and white kits cost more than black.
Has tendency to fade to grey with prolonged exposure to sunlight, but the luster can be restored.
May tend to get tacky (gooey) in the summer's heat.
Cannot let the liquid pool up too much in any spot or it will crack in those areas.
Old 02-03-2011, 07:01 PM   #5
bigted83
bigted83's Avatar
Once it's cured it won't get gooey in the sunlight, they also make a stiff u can spray but I have no idea how it will hold up
Old 02-03-2011, 07:03 PM   #6
bigted83
bigted83's Avatar
U could always wear those latex gloves like doctors wear, if u worry bout it getting on your hands
Old 02-03-2011, 07:15 PM   #7
IROCanSS
Drives: 89 IROC 350
I too used it on my jeep floor... no idea what brand... but it help up very well. Always black, never gooey.
IROCanSS is offline   Reply With Quote
Old 02-03-2011, 09:56 PM   #8
gotroost
gotroost's Avatar
Drives: 2021 Crush ZL1 1LE
I used Herculiner on my wood deck of my ATV trailer. Worked great for about a year. After that it was a peeled mess. I live in AZ so that may have had something to do with it. I have had sprayed in bed liners in both my trucks (02 and 05). Rhino liner has faded a bit but still looks great.
gotroost is offline   Reply With Quote
Old 02-03-2011, 10:27 PM   #9
RiCorvette
RiCorvette's Avatar
Drives: 2017 Corvette Grand Sport 3LT
I have this.
http://www.bed-rug.com/
RiCorvette is offline   Reply With Quote
Old 02-04-2011, 04:05 AM   #10
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
Did anyone have to do any tape masking when you used your bed liner of choice?
What kind of edge did your brand leave?
Nice sharp edge or ragged?
Old 02-04-2011, 10:09 AM   #11
gotroost
gotroost's Avatar
Both of mine are under the rail so there aren't too many edges. The ones that exist are straight and smooth.
Old 02-04-2011, 05:20 PM   #12
bigted83
bigted83's Avatar
I used the autobody masking tape, and it left a sharp line
C5 Owners Roll At Atlanta Motor Speedway musclecargirl USA - Southeast 48 10-18-2010 02:35 PM
Who manufactures the strongest and thickest front sway bar? 55Designs Suspension / Brakes / Chassis 36 10-01-2010 10:56 AM
Pfadt or Eibach DTS2SS Suspension / Brakes / Chassis 9 01-22-2010 12:07 PM
Sway Bars. Myths, Knowledge, Understanding Info@PeddersUSA.com Suspension / Brakes / Chassis 24 11-16-2009 07:48 PM
I want To See My Car Roll Off The Truck. camaro2011 5th Gen Camaro SS LS LT General Discussions 16 10-19-2009 07:45 AM
