Old 01-18-2011, 12:11 AM   #1
567234ta
567234ta's Avatar
Drives: 1996 gmc ecsb 408 ci SC 4l80e
Wider rear tires?
What options do i have? i would like to get something wider mainly for a more agressive look. Is there a downside to doing this? Is it even possible to get a wider tire on the stock wheel?
2010 2ss rs
567234ta is offline   Reply With Quote
Old 01-18-2011, 12:23 AM   #2
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
You can go wider on the tires for a slightly larger contact patch and aggressive look if you want, but not by much. Once you get to the 305 and 315's, you will actually loose performance among other things because the contact patch will change from the tires being squished onto the wheel.
IIRC, 295 tires are about the maximum width you can go before people have started having issues. If you stay at 295 or below, there isn't a downside that I know of, except for maybe tire prices might jump a little.
Old 01-18-2011, 02:46 AM   #3
567234ta
567234ta's Avatar
Great to know thank you.
Old 01-18-2011, 04:22 AM   #4
mickss
mickss's Avatar
Drives: 2010 Camaro LS-M6 67 Chevelle Wgn
2010 2ss rs
Give this thread a little more time and someone is going to tell you that you can run a 315`s on stock rims. DON`T DO IT!
Here`s the link to that discussion, I`m sure one of those who believe it`s OK to run 315`s on stock rims will also respond to this thread too.
http://www.camaro5.com/forums/showthread.php?t=119170
mickss is offline   Reply With Quote
Old 01-19-2011, 03:15 PM   #5
567234ta
567234ta's Avatar
So if i have the rims widened to 10.5 i can run the 315's safely? they wont rub? has anyone done this?
Old 01-19-2011, 06:56 PM   #6
Evotion
Warehouse 13 Survivor!!!!
Drives: '13 ZL1 - 69' Camaro
Im running 315's on an 11" wheel with no rubbing issues, closest it comes to rubbing is the inner liner but there is easily 3/4" to spare. I can't safely answer whether or not widening the wheel will make it possible since you would be changing the offset by widening it. Other people have had them widened though so do a search for it.
Evotion is offline   Reply With Quote
Old 01-19-2011, 07:09 PM   #7
Jcobra
Jcobra's Avatar
Drives: 2010 2ss/rs M6
What's the proper side wall to go with a 295/??/20?
Jcobra is offline   Reply With Quote
Old 01-19-2011, 08:24 PM   #8
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
There's a sticky up top from Nineball who has a table to figure out what size tires you want.
@567234ta, I am have 315/25/22's on my car with no issues and no fabrication at all. My car is also lowered, still with no issues.
Old 01-21-2011, 12:20 PM   #9
567234ta
567234ta's Avatar
Okay great, i know a place that does a great job at widening the wheels. Mindz- your car looks awesome!!
Old 01-21-2011, 06:59 PM   #10
jhmurphy
jhmurphy's Avatar
Drives: Grey Beast
I am running Pirelli 295/40ZR20 on stock rims and they look and perform great!!!
2SS/RS A6 and some go faster parts
jhmurphy is offline   Reply With Quote
Old 01-21-2011, 07:43 PM   #11
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
Thanks 567234ta!
Originally Posted by Nine Ball View Post
Recommended 20" tires for 2010 Camaro
245/45-20 = 28.7" tall, 8.0-8.5 wheel
255/45-20 = 29.0" tall, 8.0-8.5 wheel
265/40-20 = 28.4" tall, 8.5-9.0 wheel
275/40-20 = 28.7" tall, 9.0-9.5 wheel
285/40-20 = 28.9" tall, 9.0-10.0 wheel
295/35-20 = 28.1" tall, 9.5-10.5 wheel
305/35-20 = 28.4" tall, 10.0-10.5 wheel
315/35-20 = 28.7" tall, 10.5-11.0 wheel
Here you go if you're looking to retain the same height as the stock wheels/tires. This is the recommended tire sizes.
Old 01-21-2011, 08:20 PM   #12
Jcobra
Jcobra's Avatar
Can you post some pics.
Old 01-22-2011, 06:58 AM   #13
jhmurphy
jhmurphy's Avatar
Drives: Grey Beast
Sure here you go.
Old 01-23-2011, 02:50 PM   #14
peter b
Drives: 2010 camaro 2ss, blown
wider tires
I need a tire for the drags that I can also run on the street. Im hopping for 10 to 10.5 inch width. Any suggestions? I want to stay with stock rims if possible
peter b is offline   Reply With Quote
front tires on rear wheels TommyTSquared Wheels and Tires Talk Sponsored by The Tire Rack 14 01-01-2011 10:53 AM
WTB POLISHED 20" REAR WHEELS WITH TIRES JohnnyrSS Wheels / Tires 0 10-07-2010 10:32 AM
Can you put rear wheels and tires on the front? GQ4Life Wheels and Tires Talk Sponsored by The Tire Rack 14 09-01-2010 11:05 PM
11,000 miles and I need to replace rear tires! sewwhut Wheels and Tires Talk Sponsored by The Tire Rack 8 03-13-2010 05:00 AM
Any Body Want to Buy Me A Set of Rear Tires for 2SS? Scott@Bjorn3D Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 38 08-15-2009 08:07 AM
