#1 |
BAMF SS
The truth behind the birth of the LS motor....
Learned this from a friend... found it funny... and lame....
You can use a small block Ford Torque plate to hone an LS bore. You can bolt LS heads to a small block ford. The bore centers are only about .020 different. Firing order on the LS is Ford Symetricial ports just like Ford You can actually install a different timing chain cover and install a conventional dist in the front...just like a ford. SO basically GM just put 15 deg heads on a small block ford V8 and made power with them...
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
#2 |
Thread Killer
#3 |
BAMF SS
correct me if i'm wrong but a small block buick's distributer is front mounted but still goes through the intake
a small block ford's distributer is front mounted but goes through the timing cover.... just like a distributer converted ls motor
#4 | |
Thread Killer
That desing has lasted a long time, it went from the V8 into the 3.8 V6 and even used by Rover, which were used in allot of Jeeps. |
| Modifying for " Dummies" | Dr Jkel | Tuning / Diagnostics -- engine and transmission | 209 | 06-17-2012 11:24 PM |
| Anyone DD'ing a LS here? | nascarnate326 | 5th Gen Camaro SS LS LT General Discussions | 54 | 06-20-2010 10:08 PM |
| Got Pulled over... | TRSS2 | Cosmetics and Lighting Modification Discussions | 39 | 03-08-2010 11:57 AM |
| Holley LS Fest, September 10-12, 2010 | Pro Stock John | USA - Great Lakes | 1 | 01-28-2010 08:18 AM |
| Great Read and Info on Oil Weight | Banshee | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 1 | 11-23-2009 09:03 PM |
