Old 01-19-2009, 04:01 AM   #1
tvfreakazoid
tvfreakazoid's Avatar
Drives: 98 saturn manual
Question Engine oil sludge!
i was reading the car maintenance bible and it stated not to use additives. Well I my car burns oil through it's exhaust, I assume the seal is getting bad. I use an additive that helps slow down the process. In the maintenance bible it stated using additives could cause to have sludge build up. Should I be worried or is it other additives that can cause these build ups?
You must watch when it comes out or else:slice:
tvfreakazoid is offline   Reply With Quote
Old 01-19-2009, 08:57 AM   #2
Moose
Moderator
Moose's Avatar
Drives: '99 Camaro SS #1392
I'm sorry I can't be more specific regarding your problems with oil burning, but I've followed the manuals as well as the advice from the service technicians, and have never used any type of additives in my vehicles.
Moose is offline   Reply With Quote
Old 01-19-2009, 03:47 PM   #3
CaptianSam
Car Garage
CaptianSam's Avatar
Drives: 350z,A4,SRT8...see sig
additives generally = bad...
i only use lucas oil stabilyzer... cuz i believe in it...
2012 2SS RS Ordered
Black on Black 6 speed Coupe Artic Lid Stripes
Yes I Supercharge Everything
On My Ipad
Xbox McLovin1515
Ps3 McLovin1555
Current Autos:68z28,03viperSRT10,04escalade,05RangeRoverSport SC
Project Autos:80corvette350-500hp 6speed,06charger S'C 6-speed posi,74Firebird400blue,69chevelle572 707
New Autos:2012CamaroSSRS,09ChallengerSRT8
Past Autos:....too many to list
"i told you it was gettin' an LS3"
Go down deep enough into anything and you will find mathematics. Dean Schlicter
B.Sc. Hons. Mathematics
CaptianSam is offline   Reply With Quote
Old 01-19-2009, 03:47 PM   #4
CaptianSam
Car Garage
CaptianSam's Avatar
burning oil isnt a bad thing either... just top up every 2000 kms
2012 2SS RS Ordered
On My Ipad
Xbox McLovin1515
Ps3 McLovin1555
Old 01-19-2009, 04:03 PM   #5
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
i dont ever use lucas oil stabilizer in anything. in regular dino oil, its one thing but not in synthetics. reason being is that synthetics and blends already have stabilizers in them that can be counteracted by the lucas stuff and actually cause degredation of your oils protective properties.
http://www.bobistheoilguy.com/images/lucas/lucas.htm
what kind of oil are you using? what filter? what kind of vehicle? how much oil is burning thru the exhaust?
I piss excellence
and fart awesomeness
Old 01-19-2009, 04:17 PM   #6
dieseldave24v
PowerStroke this Ford boy
dieseldave24v's Avatar
Drives: Like Don Garlits "Big Daddy"
There are two major posibilities here. Either your piston rings are badley worn allowing engine oil to seep up into the combustion chamber and burn with the fuel/air mix. This would push the burned oil out the exhaust valve and ultimatly out the pipe. Usually a faint blue color with a unmistakable smell. The other posibility would be that you valve guide seals are leaking oil from the top of the head down into the combustion chamber. The difference can usualy be told by if it smokes all the time "Rings" or just after leaving a light "valve guide seals" If it is the rings causing blow by then you will be in need of a total engine rebuild. Valave guide seals can be changed easily by a experianced mechanic. In either situation I dont recomend any engine addiditives, how ever. If it is the rings going to a thicker weight oil can help slow the problem down. IE 15W40 instead of a 10w30. Using the thicker oil makes it harder to seep past the rings and seals. In the event that it is your rings sludge build up should be the least of your worries. If you choose to use a additive I would not use anything with teflon."Slick Fifty" uses teflon. Teflon is a great lubricant, however it is not oil soluble, so it will clog oil gallies over time. This will starve vital parts of your engine for oil.
Hey big man let me hold a dollar
dieseldave24v is offline   Reply With Quote
Old 01-21-2009, 02:58 AM   #7
tvfreakazoid
Question
I drive a 98 saturn sc1 with about 137k miles on it. The additive I use is called "Rislone", a ring seal product. Here's the website http://www.barsproducts.com/4416.htm Ever since I've been putting that additive, the oil doesn't burn as much. I it doesn't give you what the kind of ingredient it has. Thanks to everyone for the feedback. Let me know if this product is ok to use. I really don't want to spend to much money on this car. Hell it's only a saturn, but it get me around. As long as the problem doesn't too bad.
L99 AFM -- It's REALLY a tough choice, for some. Step Inside. 2KZ28_For_Now 5th Gen Camaro SS LS LT General Discussions 128 04-03-2009 05:03 PM
The 3,000 Mile Oil Change Myth KILLER74Z28 General Automotive + Other Cars Discussion 35 07-20-2008 10:02 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
Major U.S. oil source is tapped KILLER74Z28 Off-topic Discussions 32 10-30-2007 10:47 AM
