Old 07-13-2007, 02:02 PM   #1
LSxcellent
Drives: MINI Cooper S
C&D Test Drive of new BMW M3
From C&D Online....
Maybe you’ve been following the trickle of information flowing out of Munich ever since BMW showed the concept of the fourth-gen M3 at the Geneva auto show in March? We certainly have, and lately we’ve been getting downright fidgety waiting for a turn behind the wheel of the new version of the most popular M, now sporting a first-ever V-8: a 414-hp, 4.0-liter, 8400-rpm screamer.
Now it’s time to hear it, see it in action; to feel it. On that front, make sure to come back soon to check out video (that we’re frantically processing) on the roads of southern Spain and on the beautiful, 26 turn, 3.4-mile Ascari racetrack, where you’ll see a spectacular high-speed slide for life that we were sure was going to end badly (but somehow didn’t) and plenty of delicious engine noises.
What’s the Verdict?
When we’re talking about new 3-series BMWs, expectations run high, particularly so for M versions, and we arrived hoping for full-on fabulous which the M3 mostly delivered. The surprising exception was in the steering department. The M3’s hydraulic rack has a much quicker, 12.5:1 ratio than regular 3-series and features two settings, normal and sport. In its normal setting, the steering is feather light, far lighter than regular 3-series’, and, according to BMW, “enables the driver to park the car much more easily.” Come on, is this what we really need on the M3? At 100-plus-mph speeds on the highway the steering borders on scary light in its regular setting. It’s certainly accurate, however, and the sport setting clears up much of the lightness problem, but it still has a larger-than-we’d-like dead spot on-center and could use even more heft, in our opinion. Worse is that the level of tingly, tactile feedback coming through that thick-rimmed wheel seems to be dialed back a bit compared with the last M3 or even a current-gen 328i or 335i.
Bring the Noise
We’ve already spent plenty of time with the 4.0-liter V-8’s big brother, the 5.0-liter V-10 found in the M5 and the M6 so we pretty much knew it was going to scream. But the M3’s breath-through-the-driver’s-side-mesh-hood-vent V-8 version is even better. Down low, it doesn’t sound all that happy, grumbling its way past 2000 rpm, but once you reach about 3000 revs, that meaty growling V-8 noise comes in and it really starts to pull, and pull, and pull—it doesn’t quit—showcasing a torque curve much broader than that of the V-10 and quickly hurdling the M3 to ridiculous speeds.
Check out the torque peak differences: the V-10, 6100 rpm; the V-8, 3900. This makes the M3’s engine feel far more flexible and it often doesn’t even need a downshift for passing, responding so strongly on the highway that a couple times we mistakenly thought we were in fourth gear when we were still comfortably in sixth. Throttle blips under heel-and-toe downshifting are spectacular and happen almost naturally. But, not surprisingly, the best part is the shrieking crescendo from 6000 rpm all the way up to the 8400-rpm sweet spot. Sorry, 420-hp Audi RS 4; this one sounds better and pulls harder.
Dropping the hammer from a standstill, we blasted to 60 mph in 4.4 seconds, 0.4 second quicker than the previous car, with the quarter-mile dispatched in 12.9 seconds at 111 mph, an even larger, 0.7-second gain. The surface wasn’t ideal, however, and we expect even better numbers once we get one to our usual test track. Even so, that’s already enough to outrun the $69,785 Audi RS 4.
The six-speed manual (for now it’s the only transmission, although a dual-clutch automated manual is rumored to be on the way) has all new ratios, but the shift effort feels very similar to the previous M3’s—a touch imprecise, but willing enough with shorter and stiffer throws than the regular 3-series units.
Amazing Chassis
The heavily massaged M chassis, on the other hand, is brilliant; even better than we expected. The rather brittle ride from the last-generation M3 is replaced by one that is amazingly supple considering the M3’s ever-planted suspension and utter lack of body roll, squat, and dive. We spent a couple hundred miles in the M3’s comfortable and supportive saddles, tearing up the tangled mountain roads in Spain—many of which have 50 km/h (31 mph) speed limits that we may or may not have exceeded by large factors—in a fruitless search for imperfections.
There is a catch, however. To get this excellence, you must opt for the adjustable shocks, called EDC, which is the way all the cars we drove were equipped. BMW says the default conventional setup has a much-less-forgiving ride. At first, we were a bit skeptical about the usefulness of the three settings (comfort, normal, sport) and we couldn’t feel much difference between them. The reason for that is due to the system’s constant shock-valve-preload adjustment at each corner based on a number of inputs, including steering angle and lateral g’s when in either comfort or sport mode. That means when you turn in aggressively for a corner, you effectively get the stiffest “sport” setting and then the shocks soften up afterwards. We don’t know what EDC will cost, but it works so well it’s worth whatever BMW charges.
Other electronic gimmickry includes M Drive, which is handed down from the M5 and M6 and allows you to configure all the settings (throttle mapping, steering effort, EDC suspension setting, stability control mode) with one memory button on the steering wheel. By the way, that Power button you see next to the shifter doesn’t have anything to do with power as with the M5 and M6. It merely adjusts the throttle mapping between normal (which is plenty quick) and the over-the-top, bet-you-can’t-drive-smooth sport setting.
On the track, we appreciated the M3’s come-hither and forgiving limits; no matter how hard you push, it never makes you pay for your mistakes. It turns in like a champ, then puts all the power to the ground via the M-specific limited-slip differential (can we get one in the 335i, please?), ever resisting understeer, and transitioning surprisingly well considering its claimed 3650-pound heft. High-speed stability? Well, once our courage had swelled enough to stay in the throttle through a 130-mph kink at Ascari, as well as during high-speed straight-line driving, we say it’s got plenty. And the brakes—massive single-piston units with huge cross-drilled 14.2-inch front and 13.8-inch rear discs (significantly larger than even the brakes on the E46 Competition Package)—are phenomenal, with progressive feel and never once fading during our track time or extended mountain-road abuse. The trade-off is that they squeal. A lot. And this started even before we hit the track.
Equipped with Michelin Pilot Sport PS2 tires—some of the stickiest street tires known to man—in 245/40-18 front and 265/40R-18 rear sizes (19s are optional), the limits are upped significantly as well despite a roughly 250-pound weight gain. (We hope to never see the day of a two-ton M3, but now it doesn’t seem impossible.) An impromptu skidpad test showed 0.94 g, a whopping 0.07 g higher than the last E46 M3 we tested and about 0.04 g higher than a Sport package–equipped 335i. We didn’t get a chance to drive a car with the optional 19s, but we definitely prefer that design (an evolution of the E46’s double-spoke 18s) to the ones pictured here, which we think don’t stand out enough.
Of course, as with any 3500-plus-pound car on street tires, they start to get greasy after a couple hard laps on a track. At that point, the M3 starts to understeer more, a problem that can be remedied by the pedal on the right. And the car never snaps, happy to predictably slide its tail wide if you so desire.
With V-8 competitors like the upcoming 451-hp Mercedes-Benz C63 AMG and 400-plus-hp Lexus IS-F, and the 420-hp Audi RS 4, we’re leading up to one heck of a showdown—one that, based on our drive, the M3 has a very strong chance of winning.
A Problem: Can You Afford One? If So, Bring Gas Money
But the biggest problem with the new M3 is likely the price, which is expected to climb to about $62,000 when it goes on sale next spring. That’s some $7000 more than the outgoing model, nearly double what a base 328i starts at, and is getting steep for a 3-series-based car.
If you manage to overcome the price issue, be ready for a big fuel bill. The E46 M3 was rated at 16 mpg city, 24 highway which would drop to 14/22 under the new, 2008 test methods. Based on European numbers, the ’08 M3 will likely drop about five percent to a projected 13/21 for the new M3. That’s not terrible considering the 24-percent power increase and nearly 300-pound weight gain, but it’s a whopping 25-percent lower than the twin-turbo 300-hp 335i which is only about a half-second slower through the quarter-mile.
During our non-track driving, we averaged about 14 mpg. Yes, we were wringing it out, but wouldn’t you? With the ’08 M5 and M6 officially rated at 11/17, it’s clear this new family of high-revving M engines are a lot of things, but they ain’t that fuel conscious.
Then again, there aren’t many inexpensive habits, and owning an M3 is certainly not an exception. And with almost 180,000 indulgers worldwide since the M3 madness began in 1986, we expect the line to be a long one for this new model.
Don’t you want to experience first-hand the 8400-rpm shriek from BMW’s highest revving (and best) engine?
Some interesting facts highlighted in bold... mainly find it interesting that it gets such crappy mileage, and it _just_ gets into the 12's in the 1/4 mile. Not really as fast as I had expected! Oh, and bloody-hell-expensive!
~LSx
LSxcellent is offline   Reply With Quote
Old 10-14-2010, 12:43 AM   #2
Sax1031
Drives: 2000 Mustang GT
holy thread necro
Sax1031 is offline   Reply With Quote
Old 10-14-2010, 01:07 AM   #3
20Camaro11
20Camaro11's Avatar
Drives: SS
BMW makes very nice cars, but I can't afford to have a Bimmer and a Camaro, settled on a Mercury and a Camaro. Oh well.....
20Camaro11 is offline   Reply With Quote
Old 10-14-2010, 08:06 AM   #4
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Originally Posted by Sax1031 View Post
holy thread necro
LOL .. we need a zombie smiley for Necros like this
Crowley is offline   Reply With Quote
Old 10-14-2010, 06:14 PM   #5
ffrcobra_65
Drives: SuperCharged 2SS/RS IOM MN6
and nothing wrong with the Camaro.
ffrcobra_65 is offline   Reply With Quote
Old 10-15-2010, 01:00 AM   #6
20Camaro11
20Camaro11's Avatar
Drives: SS
well not exactly, taking her to the dealer this morning for some investigative work. I still like the car..looks bad ass and I lover her. I just hope the little things don't add up, I have been there and done that before with GM, I didn't like it.
What else do you drive? Urthman General Automotive + Other Cars Discussion 82 06-24-2008 12:11 AM
Anyone else see this - C&D Vert Drive LSxcellent 5th Gen Camaro SS LS LT General Discussions 17 05-27-2007 10:20 PM
