Old 11-10-2010, 05:09 PM   #1
PB3
PB3's Avatar
Drives: 2010 CGM 2LT/RS/GFX/M6
Angry Microsoft Access Import problems!
Alright. A colleague of mine just emailed me a spreadsheet that he needs imported to access. I am usually good with this but I cannot get this to import correctly! I am f*cking loosing my mind!
Situation:
I copied and paste special his data onto an excel template I use. The query in access is set up to pull the data from this template and import it into access. I plug in all the data, hit the import button, and for some reason it will not pull in any numbers with letters next to it.
Example:
Here is the data. Try and picture it in an excel spreadsheet..
10000 12615
10000 12545
1502LO 56134
1504GR 56134
When I import the data into access this is what I get:
10000 12615
10000 12545
*BLANK*56134
*BLANK*56134
I have tried copying and paste special into a blank spread sheet then copying from there and paste special into my template and I still get blanks on numbers with letters next to them! It doesn't say "*BLANK*" as I described above. The cell is blank.HELP!!
"Reality is an illusion that occurs due to lack of alcohol" -W.C.Feilds
PB3 is offline   Reply With Quote
Old 11-10-2010, 05:18 PM   #2
brandotron
I am the internets.
brandotron's Avatar
Drives: dangerously
Situation:
Example:
10000 12615
10000 12545
1502LO 56134
1504GR 56134
10000 12615
10000 12545
*BLANK*56134
*BLANK*56134
If it's anything like SQL/mySQL, you need to specify that the left column is NVARCHAR, rather than NUMERIC
Old 11-10-2010, 05:30 PM   #3
PB3
PB3's Avatar
Well, I've just imported different spreadsheets I have with similar data to make sure no one f*cked with my access query. They import the data just fine. Could it be something with his excel spreadsheet?
Old 11-10-2010, 07:30 PM   #4
KMSRS2SS
I lurk
KMSRS2SS's Avatar
Drives: 2010 SS/RS
Is there any formatting going on in the excel column? Try just a general formatting see if that changes anything.
460 at the wheel so far...
VMS Stage 2.5 Camshaft Kit- Comp cam LSA 114,227/239, .613 .623, RotoFab CAI, VMS ported intake manifold,Kooks 1 3/4" headers with HF cats, Corsa Catback, VMS custom dyno tune,TechAFX engine hose relocation kit, DSS 1400 hp axles, BMR toe rods and links, LS9 Clutch, Hurst short throw with roll out, Liberty Gear built tremec 6060.
KMSRS2SS is offline   Reply With Quote
Automatic Transmission Problems Kyzer Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 30 07-13-2016 07:26 PM
Potential Solutions to Radio Problems The_Blur Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 17 11-10-2009 11:23 PM
Does an axle back have the same problems as a cat back? G.E. Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 09-15-2009 04:31 PM
Problems with Active Fuel Management ? 2SSRS@Gen5diy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 73 04-08-2009 04:15 AM
ordering problems at the dealer? pinkcamaro10 Camaro Price | Ordering | Tracking | Dealers Discussions 27 10-14-2008 12:43 AM
