Old 11-07-2010, 07:47 PM   #1
Chevyg1rl
Chevyg1rl's Avatar
Drives: Chevys
Help - BMW Z3 - blown head gasket?
My brother-in-law has a 1997 BMW Z3. Yesterday, the altenator went out. He replaced it and the battery, by the time he was done it was dark and he didn't see the tear in the lower radiator hose caused by the serpentine belt snapping and flying off.
Today, the car overheated and shut down. He fixed the hose and the engine cranks but won't turn over. He says it feels like there's no compression. When the car was being pulled up on to the tow truck, coolant was coming out of the exhaust pipe. The tow driver told him he probably blew a head gasket but there's no water on the oil dipstick and this doesn't make sense to him.
Any suggestions you have will be greatly appreciated. He loves that car like we love our Camaros. I loned him my '01 in the hopes to convert him.
Chevyg1rl is offline   Reply With Quote
Old 11-07-2010, 09:34 PM   #2
69Z/28Camaro
Red Big Block Camaro
69Z/28Camaro's Avatar
Drives: 93 C1500, VR Big Block 70 Camaro RS
the head gasket could be blown and i would think that with the very small amount of space between thepiston and cylinder that its very possible that there isnt any oil in the oil pan
my 1970 Camaro RS. Frame off restoration. 600 HP 454 Naturally Aspirated. GM Performance Heads, Comp Mechanical cam, Weiand Stealth Intake, Holley 750 Carb. Hooker and Flowmaster exhaust system. Victory Red paint, True Rally Sport.
69Z/28Camaro is offline   Reply With Quote
Old 11-07-2010, 09:44 PM   #3
Chevyg1rl
Chevyg1rl's Avatar
Drives: Chevys
but there's oil on the stick? Would that still be the case if there's no oil in the pan?
Old 11-07-2010, 10:09 PM   #4
8cd03gro
Drives: 2005 STi corn fed
Definitely a blown head gasket, but possibly more. IIRC that's an inline 4? That's an easy fix you two could to yourselves and from there you can assess other damages.
8cd03gro is offline   Reply With Quote
Old 11-07-2010, 10:28 PM   #5
Chevyg1rl
Chevyg1rl's Avatar
Drives: Chevys
8cd03gro - thanks, that's good news. I'll let him know. It's a 4 cyl motor but other than that, I don't know much about BMWs. hopefully there won't be too much $ in the way of other damages
Old 11-07-2010, 11:21 PM   #6
8cd03gro
Just to clarify, it's an easy fix for someone that has some experience. You don't need to be a mechanic, but you need to at least know what you're looking at when you pop the hood and you're going to need the torque-specs for the head studs. I'm sure if you checked out some BMW forums there would be someone in your area happy to help for the cost of a 6-pack of budweiser.
Old 11-08-2010, 08:35 AM   #7
mad@gm
Drives: was a 2010 2SS/RS
The problem is not the head gasket! I have fixed these before, the problem is the threads in the engine block for the head bolts are aluminum and crack causing the head to come loose enough to act like its a gasket problem, remove the head and replace the threads with steel (gaskets too) and the problem will be solved, you can use heli coils with green loc-tite or bmw also sells a repair kit for this problem, if you are not a qualified mechanic do not attempt there are lots of timing settings (3 chains and a vanos sys) that if you are even a slight bit off you will bend the valves and possible blow a piston or two, good luck!
mad@gm is offline   Reply With Quote
Old 11-08-2010, 11:04 AM   #8
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
9/26/09 Took delivery!
Old 11-10-2010, 12:36 PM   #9
Chevyg1rl
Chevyg1rl's Avatar
Drives: Chevys
Ahhh, thank you!! I will pass this info along.
A mobile mechanic (MM) we've used in the past stopped by last night to look at it because (thankfully) my b-i-l is not too stupid to attempt to work on this car without guidance. The MM said it was definitely a blown head gasket when he pulled the plugs and saw water in the pistons. Fortunately, we don't have the proper tools to repair it so it will be done correctly and with a warranty.
Thank you all for your info, it's much appreciated!
btw, b-i-l did post on his BMW site, but got bs instead of help. I laughed when the MM told him if he were driving a Chevy, he'd still be driving.
'07 BMW 335i or '10 Camaro 2LT RS KingArthur Chevy Camaro vs... 55 04-29-2010 11:36 PM
10 Camaro SS vs C6 ZO6 VS Bmw M5 vs Ram SRT10 vs Benz E55 AMG vs Bmw M6 vs GT500 GEIST LS9 Chevy Camaro vs... 84 12-08-2009 10:55 PM
Bad news for anyone thinking of installing an aftermarket head unit fastball Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 26 05-26-2009 10:18 PM
head gasket change hard or just ok? D1BADZ 4th Generation Camaros 4 11-21-2008 07:42 PM
The BMW Gina concept... Chevyrocker General Automotive + Other Cars Discussion 12 06-16-2008 10:54 PM
