Old 10-11-2010, 06:47 PM   #1
Synyster
Synyster's Avatar
Drives: 2006 F150 Lariat
2004 F250 6.0L
Worth it to swap in a Cummins? Heard horror stories about the 6.0 Powerstroke.
What all would have to be done to make the swap? Transmission swap needed too?
Synyster is offline   Reply With Quote
Old 10-11-2010, 07:39 PM   #2
SC2150
Drives: 2012 Camaro RS, RX supercharged
Only issue is the OEM head bols strech & cause compression to leak into the cooling system pushing out coolant & causing overheating and eventual failure. Get a GOOD diesel shop, or competent performance shop to swap out for ARP studs and your good to go unless it has been seriously overheated. Ford put several sets of OEM's in mine while under warranty and it always did the same thing.
It's a good motor otherwise and the fix is not expensive.
We have done Cummins conversions w/good results though but the cost is high in comparrison.
SC2150 is offline   Reply With Quote
Old 10-11-2010, 08:52 PM   #3
Synyster
Synyster's Avatar
Well I'd be trading my boat to the guy with the truck, straight up trade. I'm having to get rid of the boat no matter what so I figure why not get another truck lol. As long as a proper swap would be under $15k or so, money isn't an issue. Do you know what a decent price would be?
Old 10-11-2010, 08:53 PM   #4
shank0668
shank0668's Avatar
A swap would be very pricey. Wait till it breaks if you HAVE to do it.
Old 10-11-2010, 08:54 PM   #5
shank0668
shank0668's Avatar
If money isn't an issue, go with a Cummins and an Allison transmission.
Old 10-11-2010, 09:10 PM   #6
Synyster
Synyster's Avatar
Oh I wasn't planning on swapping it immediately, only when or if something horrid happens to the motor lol. I'd like to at least drive around with the 6.0 for a bit so I can give a real opinion on it ya know?
Old 10-14-2010, 08:28 PM   #7
SC2150
The ideal truck would be the Ford chassis, the Cummins engine, and the Allison trans.....
But if the truck runs good now just do the head stud swap and you will go 500k plus miles w/out issue.
It's only a couple hundred to swap the head bolts.
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 08:51 AM
GM Heritage Collection - sale Moose 5th Gen Camaro SS LS LT General Discussions 65 06-27-2013 02:28 PM
Superchips now offering multi vin apps and more. See inside for more details! Scott@Superchips Tuning / Diagnostics -- engine and transmission 11 04-26-2010 06:46 PM
Forza 3 update - full car list & new trailer Sean@Phastek Off-topic Discussions 7 10-09-2009 11:00 AM
