TireRack
Old 09-30-2010, 05:41 PM   #1
rtkjadams
Drives: Red Jewel SS
clunking after bushings and lowering
Just lowered car and installed bushings.... Now i get clunking sound from rear end when going slow in 1st gear and pushing in clutch. clunk, clunk, clunk....
Ray
rtkjadams is offline   Reply With Quote
Old 09-30-2010, 05:54 PM   #2
Rod10269
Hot Rod
Rod10269's Avatar
Drives: 69 Z28,69 SS 396,67 Chevelle
Sounds like you might have something in contact with the wheel...I used the Eibach spring set and did not have any issues..did you do it yourself?
Rod10269 is offline   Reply With Quote
Old 09-30-2010, 05:54 PM   #3
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
How did you lower the car and what bushings did you install?
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 09-30-2010, 07:12 PM   #4
55Designs
Drives: 2010
check your sway bar end links
55Designs is offline   Reply With Quote
Old 09-30-2010, 08:34 PM   #5
rtkjadams
When I have the car on the lift, and grab the driveshaft and turn it back and forth, I get the clunking...... It's like the gears in the rear end have to much play.
Ray
Old 09-30-2010, 08:37 PM   #6
flyby
Drives: 2010 Silver SS
Not too much play. My bet is the clutches are bad. Mine did the same thing.
flyby is offline   Reply With Quote
Old 09-30-2010, 08:56 PM   #7
1977and2010
Tampa Gulf Coast Family
1977and2010's Avatar
Drives: 1977 Z28, 2SSRS 2010 M6
Could it be the harder bushings? Mine does the same thing and I think it is because the harder durometer bushings have taken out the cushion from the rubber bushings with voids. Let us know what you find out.
1977and2010 is offline   Reply With Quote
Old 09-30-2010, 09:19 PM   #8
thekid96
Drives: Z06, 69 Camaro
Bingo, excessive lash in the ring and pinion is your problem. I had the same problem which was greatly magnified when I installed solid bushings. I spent weeks trying to track it down, camera under the car, etc. I finally found almost 1/4 turn of slack in my diff by rotating the driveshaft.
I pulled the diff and had Unitrax set it up properly to spec and all noise/clunk is gone. This problem is common, GM has a lot of tolerance in the trans and diff set-up. I had my trans apart which was well outside of spec as well.
Ray
thekid96 is offline   Reply With Quote
Old 10-01-2010, 07:07 AM   #9
rtkjadams
The car only has 3400 miles on it...... So, you had the rear gears reset? Who did you have do it? A local speed shop?
Ray
Old 10-01-2010, 08:48 AM   #10
mdinferno
mdinferno's Avatar
Drives: 2010 IBM 2LT/RS
After i installed my eibach lowering spring i had the same noise.. it ended up being i forgot to bolt up the sway bar.
Old 10-01-2010, 09:51 AM   #11
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Good point. After doing any suspension work where the result is a noise the first thing to do is double check all of the bolts to verify there are tight to OE specification.
Old 10-01-2010, 10:15 AM   #12
thekid96
My car only had 800 miles on it, I am confident the issue is there from the factory but is masked by the soft rubber diff and sub-frame bushings. When you solid mount the diff and/or sub-frame the noise becomes more apparent. I took my diff to Unitrax, they are local to me and do excellent work. You might want to contact Janetty and have him do the posi upgrade while it is apart.
Ray
Old 10-01-2010, 10:56 AM   #13
rtkjadams
I will recheck all bolts, but I think its in the rear diff. I searched and saw that gm is suppose to be coming out with a spacer that will fix it.......
Ray
Pfadt Race Engineering's newest distributor is... Apex Motorsports Suspension / Chassis / Brakes 6 06-12-2011 10:53 AM
Eibach lowering kit on its way, anyone know a good installer? (montreal region) Ex-stang Canada 11 07-10-2010 08:08 PM
DSE lowering coils and swaybar kits NicKey Suspension / Chassis / Brakes 0 03-02-2010 03:53 PM
BWoody Lowering Springs and Swaybar Endlinks tbyrne Suspension / Chassis / Brakes 5 01-11-2010 02:12 PM
