#1 |
Xbox 360 horrible red ring of death a scam? + fix rrod
My brothers friends 360 broke [rrod]red ring of death and he wanted to send it in to get fixed but its modded. He didnt know what to do. so my brotther heard you could wrap a towel around it and it would overheat and then after that it would work. My brothers friend said bs. Then he decided why not try it. He wrapped a towel around it and let it go for an hour. It overheated. So he let it cool down and he turned it on to find out it fixed it! So is the red ring of death just a scam to get microsoft money by getting it fixed from them? He didnt actually do anything.
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS Join Date: Sep 2008
The only way to really fix it is to increase the amount of cooling and air flow and to de-solder and then re-solder all connections with good solder so no it's not a scam by Microsoft. Plus for it to be a scam they have to have something to gain but they do it for free. In the 1st year alone didn't MS LOSE a lot of money fixing the RROD? |
#3 |
![]() ![]() ![]() ![]() Drives: V45 Join Date: Feb 2007
You probably shouldn't purposely overheat the system...
#4 | |
Drives: 2023 GMC Canyon, 2023 Expedition Join Date: Aug 2008
And tell him to send it back. Just get a new one.
2023 GMC Canyon Elevation 2023 Ford Expedition SSV (State-Issued) |
#5 |
Camaro➎ moderator
NO warranty when modded. After you break the seal you void the warranty.
#6 |
![]() Drives: 2010 CAMARO 2SS Red M6 Join Date: Oct 2008
Here is why it works...Really!
Wrapping it in a towel and leaving it like that for a while causes the game system to overheat, as no air can be circulated by the internal cooling fan. When the unit overheats it shuts down and restores all setting to the origianal factory specs. It is that simple nothing fancy! I have don it it is no biggie! |
#7 |
I read what I wrote above...And it sounds a little vague. Let me clarify. I don't know beyond a shadow of doubt exactly what Red Ring of Death is, but for lack of a better description it is like a virus, that is retained by the units' harddrive. The only way to remove it is to reset the unit. The only way to do that w/o sending it back to that factory is the overheating method. I have done it once and have freinds who have done it countless times. It will not harm your Xbox! Good Luck!
#8 |
![]() ![]() ![]() ![]() Drives: '12 Camaro ZL1 #1255 Join Date: Feb 2007
ill give ur buddies 360 2 months max before u see the rrod . the towel trick is a TEMPORARY fix. iv done that before and it lasted 2 months on me before my 360 was gonzo again and this time it didnt live to play again. my 360 was modded to so i had to buy a new one. good luck on ur buddies second 360.
#9 | ||
Camaro➎ moderator
This is the truth. vv Quote:
#10 |
E.B.A.H.
Drives: you wild... Join Date: Mar 2007
In order to not get a RROD, simply place your xbox in a space with open air. If you keep it in a confined space, it's cooling system can't work as intended. That's why it overheats.
Also, if you mod your xbox, TAKE CARE OF IT AND GIVE IT ROOM TO BREATHE. That's like getting some Louis Vitton/Prada/whatever designer interior for your convertible and leaving the top down on a cloudy day with storm warnings... |
#11 | |
Not That sad..considering
Drives: Man Join Date: Aug 2007
Location: the part of washington the capital forgot about.
Stop Whinging
#12 | |
#13 | |
![]() Drives: 2010 Black SS/RS Join Date: Nov 2008
as said before, the solder on the connection to the hard drive breaks, once it loses its connection the rrod comes up because theres no communication to the hard drive the towel trick works because, as stated already, the heat causes the solder to melt and if your lucky, reconnect the broken connection, but it doesnt always work and heat causes damage to other components which is why its no recommended or even advised the only way what you said would make sence would be if you changed some settings and the rrod came up right after. if you didnt change anything then your still at the default settings |
#14 | |
| [sale] Xbox 360 + games + accessories | diddiyo | Off-topic Discussions | 4 | 10-18-2008 11:35 AM |
