Old 12-08-2008, 07:32 PM   #1
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
Continued off topic discusions.
don't it help your rear traction if you fill the gas tank 1/2 way up with sand to make it heavier over the axle?
Eve ('00 FRC): hot-air intake
Old 12-08-2008, 09:03 PM   #2
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Sand in the gas tank to add weight over the axle. Hmm well, that would work. Can't say the same about the engine . . .
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 12-08-2008, 09:22 PM   #3
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
Zebra, thats the craziest thing i have ever heard.
This is the simplest method, okay, First of all check if the temperatures are below freezing or anywhere near it, if they are, expect ice. Now if you expect ice, now this is important, SLOW DOWN! Allow yourself extra space to slow down.
Just yesterday i was going 10 mph and i tried to stop at a stop sign, i started slowing down much earlier than usual and i still sailed through the stop sign. Thank god nobody was there cuz cross traffic didn't have to stop. i have never used chains on a car, nor would i even know where to get them. Add weight to the back of your stang, 100-150lbs should be good that will help a little. But the biggest tip i can giv eyou is to slow down.
Old 12-08-2008, 09:55 PM   #4
zebra
zebra's Avatar
that's why you fill it with just enough water to cover the sand & let it freeze. that holds the sand together. then top it off with gas.
zebra, thats the craziest thing i have ever heard.
i can keep going with this one. the next step is to drain the oil and run it with a water hose in the block to flush out the summer oil. replace with winter oil for best results
Old 12-08-2008, 10:10 PM   #5
DGthe3
Moderator.ca
DGthe3's Avatar
don't forget to route the exhaust back into the intake (DEI). Not only does that provide lots of boost, but it also keeps the engine nice and warm.
Back on topic . . .
Old 12-08-2008, 10:43 PM   #6
zebra
zebra's Avatar
Back on topic . . .
exactly! now i digress.
Old 12-09-2008, 12:15 AM   #7
EMB135Driver
Jedi Master
EMB135Driver's Avatar
Drives: Boeing 757/767+2010 IBM 2SS
Guys, I am not much of a mechanic, but am eager to learn. I was wondering if I should maybe use Spring Water to flush out my block....our water has high iron content in it and I dont want it to cause internal rust.
Would it be best to flush it out while the engine is running, or start it up after it's full of water? Do you think that adding some bleach would help to clean it out inside....I really want the inside of my engine to sparkle.
EMB135Driver is offline   Reply With Quote
Old 12-09-2008, 12:24 AM   #8
DGthe3
Moderator.ca
DGthe3's Avatar
The extra iron will help replenish metal that has been worn away. And you have to drain the oil first, then fill it with water, then start the engine. That will help ensure that all the oil will be removed. Don't add bleach. If anything, add some soap. Laundry detergent is best. Soap bonds oil to water allowing for things to get extra clean.
Old 12-09-2008, 12:28 AM   #9
DGthe3
Moderator.ca
DGthe3's Avatar
I, and other mods/admin, will periodically move off-topic discussions from other threads here. It saves on the 'back on topic' posts.
Old 12-09-2008, 12:36 AM   #10
TonytheTiger
TonytheTiger's Avatar
Drives: 1999 camaro rs
what the hell is going on here?
TonytheTiger is offline   Reply With Quote
Old 12-09-2008, 12:42 AM   #11
DGthe3
Moderator.ca
DGthe3's Avatar
oops. I made this thread after those posts were made. When I moved them from their original thread and merged with this one, I forgot that they get added in chronological order.
Old 12-09-2008, 12:55 AM   #12
zebra
zebra's Avatar
didn't mean to derail the winterizing discussion - people just went with it
Old 12-09-2008, 02:09 AM   #13
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
If anyone actually follows any of this advice...I'm gonna....
The topics and views expressed in this thread are not that of Camaro5. they are of Zebra & co. ...make sure I get that disclaimer in there!
Old 12-09-2008, 07:41 AM   #14
DGthe3
Moderator.ca
DGthe3's Avatar
Are you saying that putting sand in the gas tank won't help with traction?
Nissan's Continued GT-R Legendary Car Failure The_Blur General Automotive + Other Cars Discussion 41 11-29-2008 02:34 PM
OK my reason to vent.. VERY off topic... lordfriday2 Off-topic Discussions 21 11-27-2008 10:48 PM
Continued: Lutz mentions engine options for Camaro -- 4 cylinder turbo a possibility Tran Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 160 08-08-2008 05:16 PM
The off topic plane section... aston70 Off-topic Discussions 47 06-12-2008 10:32 AM
Alright, totally off topic, but I have to ask..... Silverado Off-topic Discussions 6 08-15-2007 01:23 PM
