Old 12-04-2008, 03:00 PM   #1
Wm Holden
Yes, that's my real name.
Wm Holden's Avatar
Drives: 2005 LS2 600hp GTO
What is the Singularity?
Cliff notes:
Once we make an artificial brain that is smarter then human...it will get much smarter much faster then we may ever be able to be....?
What is the Singularity?The Singularity is the technological creation of smarter-than-human intelligence. There are several technologies that are often mentioned as heading in this direction. The most commonly mentioned is probably Artificial Intelligence, but there are others: direct brain-computer interfaces, biological augmentation of the brain, genetic engineering, ultra-high-resolution scans of the brain followed by computer emulation. Some of these technologies seem likely to arrive much earlier than the others, but there are nonetheless several independent technologies all heading in the direction of the Singularity – several different technologies which, if they reached a threshold level of sophistication, would enable the creation of smarter-than-human intelligence.
A future that contains smarter-than-human minds is genuinely different in a way that goes beyond the usual visions of a future filled with bigger and better gadgets. Vernor Vinge originally coined the term "Singularity" in observing that, just as our model of physics breaks down when it tries to model the singularity at the center of a black hole, our model of the world breaks down when it tries to model a future that contains entities smarter than human.
Human intelligence is the foundation of human technology; all technology is ultimately the product of intelligence. If technology can turn around and enhance intelligence, this closes the loop, creating a positive feedback effect. Smarter minds will be more effective at building still smarter minds. This loop appears most clearly in the example of an Artificial Intelligence improving its own source code, but it would also arise, albeit initially on a slower timescale, from humans with direct brain-computer interfaces creating the next generation of brain-computer interfaces, or biologically augmented humans working on an Artificial Intelligence project.
Some of the stronger Singularity technologies, such as Artificial Intelligence and brain-computer interfaces, offer the possibility of faster intelligence as well as smarter intelligence. Ultimately, speeding up intelligence is probably comparatively unimportant next to creating better intelligence; nonetheless the potential differences in speed are worth mentioning because they are so huge. Human neurons operate by sending electrochemical signals that propagate at a top speed of 150 meters per second along the fastest neurons. By comparison, the speed of light is 300,000,000 meters per second, two million times greater. Similarly, most human neurons can spike a maximum of 200 times per second; even this may overstate the information-processing capability of neurons, since most modern theories of neural information-processing call for information to be carried by the frequency of the spike train rather than individual signals. By comparison, speeds in modern computer chips are currently at around 2GHz – a ten millionfold difference – and still increasing exponentially. At the very least it should be physically possible to achieve a million-to-one speedup in thinking, at which rate a subjective year would pass in 31 physical seconds. At this rate the entire subjective timespan from Socrates in ancient Greece to modern-day humanity would pass in under twenty-two hours.
Humans also face an upper limit on the size of their brains. The current estimate is that the typical human brain contains something like a hundred billion neurons and a hundred trillion synapses. That's an enormous amount of sheer brute computational force by comparison with today's computers – although if we had to write programs that ran on 200Hz CPUs we'd also need massive parallelism to do anything in realtime. However, in the computing industry, benchmarks increase exponentially, typically with a doubling time of one to two years. The original Moore's Law says that the number of transistors in a given area of silicon doubles every eighteen months; today there is Moore's Law for chip speeds, Moore's Law for computer memory, Moore's Law for disk storage per dollar, Moore's Law for Internet connectivity, and a dozen other variants.
By contrast, the entire five-million-year evolution of modern humans from primates involved a threefold increase in brain capacity and a sixfold increase in prefrontal cortex. We currently cannot increase our brainpower beyond this; in fact, we gradually lose neurons as we age. (You may have heard that humans only use 10% of their brains. Unfortunately, this is a complete urban legend; not just unsupported, but flatly contradicted by neuroscience.) An Artificial Intelligence would be different. Some discussions of the Singularity suppose that the critical moment in history is not when human-equivalent AI first comes into existence but a few years later when the continued grinding of Moore's Law produces AI minds twice or four times as fast as human. This ignores the possibility that the first invention of Artificial Intelligence will be followed by the purchase, rental, or less formal absorption of a substantial proportion of all the computing power on the then-current Internet – perhaps hundreds or thousands of times as much computing power as went into the original Artificial Intelligence.
But the real heart of the Singularity is the idea of better intelligence or smarter minds. Humans are not just bigger chimps; we are better chimps. This is the hardest part of the Singularity to discuss – it's easy to look at a neuron and a transistor and say that one is slow and one is fast, but the mind is harder to understand. Sometimes discussion of the Singularity tends to focus on faster brains or bigger brains because brains are relatively easy to argue about compared to minds; easier to visualize and easier to describe. This doesn't mean the subject is impossible to discuss; section III of our "Levels of Organization in General Intelligence" does take a stab at discussing some specific design improvements on human intelligence, but that involves a specific theory of intelligence, which we don't have room to go into here.
However, that smarter minds are harder to discuss than faster brains or bigger brains does not show that smarter minds are harder to build – deeper to ponder, certainly, but not necessarily more intractable as a problem. It may even be that genuine increases in smartness could be achieved just by adding more computing power to the existing human brain – although this is not currently known. What is known is that going from primates to humans did not require exponential increases in brain size or thousandfold improvements in processing speeds. Relative to chimps, humans have threefold larger brains, sixfold larger prefrontal areas, and 98. 4% similar DNA; given that the human genome has 3 billion base pairs, this implies that at most twelve million bytes of extra "software" transforms chimps into humans. And there is no suggestion in our evolutionary history that evolution found it more and more difficult to construct smarter and smarter brains; if anything, hominid evolution has appeared to speed up over time, with shorter intervals between larger developments.
But leave aside for the moment the question of how to build smarter minds, and ask what "smarter-than-human" really means. And as the basic definition of the Singularity points out, this is exactly the point at which our ability to extrapolate breaks down. We don't know because we're not that smart. We're trying to guess what it is to be a better-than-human guesser. Could a gathering of apes have predicted the rise of human intelligence, or understood it if it were explained? For that matter, could the 15th century have predicted the 20th century, let alone the 21st? Nothing has changed in the human brain since the 15th century; if the people of the 15th century could not predict five centuries ahead across constant minds, what makes us think we can outguess genuinely smarter-than-human intelligence?
Because we have a past history of people making failed predictions one century ahead, we've learned, culturally, to distrust such predictions – we know that ordinary human progress, given a century in which to work, creates a gap which human predictions cannot cross. We haven't learned this lesson with respect to genuine improvements in intelligence because the last genuine improvement to intelligence was a hundred thousand years ago. But the rise of modern humanity created a gap enormously larger than the gap between the 15th and 20th century. That improvement in intelligence created the entire milieu of human progress, including all the progress between the 15th and 20th century. It is a gap so large that on the other side we find, not failed predictions, but no predictions at all.
Smarter-than-human intelligence, faster-than-human intelligence, and self-improving intelligence are all interrelated. If you're smarter that makes it easier to figure out how to build fast brains or improve your own mind. In turn, being able to reshape your own mind isn't just a way of starting up a slope of recursive self-improvement; having full access to your own source code is, in itself, a kind of smartness that humans don't have. Self-improvement is far harder than optimizing code; nonetheless, a mind with the ability to rewrite its own source code can potentially make itself faster as well. And faster brains also relate to smarter minds; speeding up a whole mind doesn't make it smarter, but adding more processing power to the cognitive processes underlying intelligence is a different matter.
But despite the interrelation, the key moment is the rise of smarter-than-human intelligence, rather than recursively self-improving or faster-than-human intelligence, because it's this that makes the future genuinely unlike the past. That doesn't take minds a million times faster than human, or improvement after improvement piled up along a steep curve of recursive self-enhancement. One mind significantly beyond the humanly possible level would represent a Singularity. That we are not likely to be dealing with "only one" improvement does not make the impact of one improvement any less.
Combine faster intelligence, smarter intelligence, and recursively self-improving intelligence, and the result is an event so huge that there are no metaphors left. There's nothing remaining to compare it to.
The Singularity is beyond huge, but it can begin with something small. If one smarter-than-human intelligence exists, that mind will find it easier to create still smarter minds. In this respect the dynamic of the Singularity resembles other cases where small causes can have large effects; toppling the first domino in a chain, starting an avalanche with a pebble, perturbing an upright object balanced on its tip. (Human technological civilization occupies a metastable state in which the Singularity is an attractor; once the system starts to flip over to the new state, the flip accelerates.) All it takes is one technology – Artificial Intelligence, brain-computer interfaces, or perhaps something unforeseen – that advances to the point of creating smarter-than-human minds. That one technological advance is the equivalent of the first self-replicating chemical that gave rise to life on Earth.
source
http://www.singinst.org/overview/whatisthesingularity/
Speaking of brains.... now mine hurts....
discuss...please.
Magnuson 112HH supercharger at 7.5 psi (Virtual 9.0 liter) 600hp 1 of 2 torrid/red int /A4/05 555r 275/40/R17's Nitto Extreme Drags 1.7 60 ft Car runs high 11's No other mods. I got the first 112HH Magnuson blower ported for a GTO. Now it appears it was also one of the last....
http://www.ribbonprinting.com http://www.personalizedawarenessribbons.com
Wm Holden is offline   Reply With Quote
Old 12-04-2008, 03:08 PM   #2
The_Blur
Moderator
The_Blur's Avatar
I refuse to discuss this. What are you going to do about it?
warn 145:159 ban
Old 12-04-2008, 03:11 PM   #3
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
I don't want to read anymore.......
Old 12-04-2008, 03:16 PM   #4
jimbo57
jimbo57's Avatar
Drives: 2010 SS, '06 EQUINOX, 72 MONTE
was this a college term paper?
don't overstay your welcome, or you won't be welcome to stay over.
jimbo57 is offline   Reply With Quote
Old 12-04-2008, 03:32 PM   #5
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
I got a CDL book to read, and I complained about that. I havn't read this much since college. Then you hand me this. Is there cliffs notes for this. My head is starting to hurt. :bangdesk:
Old 12-04-2008, 03:44 PM   #6
Wm Holden
Wm Holden's Avatar
Old 12-04-2008, 03:54 PM   #7
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Drives: 2010 1SS:RS:LS3:SW
The difference lies not with intelligence but with the ability to affect ones environment. A pc that can think for itself is great.. but that doesn't mean it can go out and put more ram in its ram slot... or upgrade its cpu... software is only half of the problem. Even using networked resources will only get you so far..
This is also where the whole AI in the future will take over mankind is patently false physical resources will be exhausted before its possible for humankind to be subverted by a created intelligence.
A.K.A - Diarmadhi (old handle) - So much to do.. So little money
Owner : Fast-Stache Industries LLC
The_Stache is offline   Reply With Quote
Old 12-04-2008, 03:57 PM   #8
lalometalik
killer bAnana
lalometalik's Avatar
Drives: 1985 z28
Wow good read.
Edgar Allen Poe taps into this in "The power of words", but in terms of analysis, in retrograding.
Retrograding, they found no difficulty, from a given effect, under given conditions, in determining the value of the original impulse. Now the mathematicians who saw that the results of any given impulse were absolutely endless–and who saw that a portion of these results were accurately traceable through the agency of algebraic analysis–who saw, too, the facility of the retrogradation–these men saw, at the same time, that this species of analysis itself, had within itself a capacity for indefinite progress–that there were no bounds conceivable to its advancement and applicability, except within the intellect of him who advanced or applied it. But at this point our mathematicians paused.
check it out, its a good read (if your brain could stand any more, that is! )
http://classiclit.about.com/library/...apoe-power.htm
"Shut your noise tube, Taco Human!"
lalometalik is offline   Reply With Quote
Old 12-04-2008, 03:57 PM   #9
The_Blur
Moderator
The_Blur's Avatar
warn 145:159 ban
Old 12-04-2008, 04:14 PM   #10
lalometalik
killer bAnana
Drives: 1985 z28
H.A.R.D.A.C. AI and Brainiac
Old 12-04-2008, 04:15 PM   #11
Wm Holden
Wm Holden's Avatar
It seemed like this might be appreciated here....
Old 12-04-2008, 04:33 PM   #12
The_Blur
Moderator
The_Blur's Avatar
Stand by for me to post one of my political science papers. I might be laughing, but I am certainly not joking.
warn 145:159 ban
Old 12-04-2008, 04:36 PM   #13
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Oh I appreciate it and its thoughts.. it really is a decent paper... But its to extreme in its facts and neglects the real world. POTENTIALLY it is possible that it could happen.. BUT the chances of that are so ungodly slim its not funny... We would need thousands of manufacturing plants building parts linked remotely so that "physical" expansion could occur without human interaction on a massive rate.
And that rate would have to out pace human reproduction.
Old 12-04-2008, 04:38 PM   #14
MrIcky
MrIcky's Avatar
Drives: Dodge Ram Megacab & Cobalt SS
OK, I'm taking the OP here and the OP on the binary thread and I'm locking you both in the Octagon. Whoever emerges shall henceforth be the King of all Geekdom. All hail the King.
MrIcky is offline   Reply With Quote
