Old 11-30-2008, 04:29 PM   #1
TRIXXTERR
TRIXXTERR's Avatar
Drives: 96 Z28(sold)
Talking The right tool for the job...
A friend of mine posted this on a local board. Dunno if it's been posted before, I Did Search, but..............
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly-stained heirloom piece you were drying.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned guitar calluses from fingers in about the time it takes you to say, "YEOWW."
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age.
SKIL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters. The most often tool used by all women.
BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub you want the bearing race out of.
TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill bit that snaps neatly off in bolt holes thereby ending any possible future use.
RADIAL ARM SAW: A large stationary power saw primarily used by most shops to scare neophytes into choosing another line of work.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids and for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads. Women excel at using this tool.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts which were last over tightened 30 years ago by someone at Ford, and instantly rounds off their heads. Also used to quickly snap off lug nuts.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit. Women often use it to make gaping holes in walls when hanging pictures.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. It’s especially useful for slicing work clothes but only while in use.
BLEEPITY-BLEEP TOOL: Any handy tool that you grab and throw across the garage while yelling "BLEEPITY-BLEEP!" at the top of your lungs. It is also, most often, the next tool that you will need.
Remember- "It ain't ready 'til it's ready!" Just because we show it to you early, doesn’t mean it’s ready.
TRIXXTERR is offline   Reply With Quote
Old 11-30-2008, 04:35 PM   #2
ucla1ove3
Drives: soon to be 2010 CAMARO :]
LMAO
ucla1ove3 is offline   Reply With Quote
Old 11-30-2008, 04:45 PM   #3
Mr Twisty
Mr Twisty's Avatar
That's good stuff
-- Benjamin Franklin
lib·er·ty
/ˈlibərdē/
noun
1.
Old 11-30-2008, 05:02 PM   #4
TRIXXTERR
TRIXXTERR's Avatar
Glad You Enjoyed..
Old 11-30-2008, 06:23 PM   #5
ljustin293
ljustin293's Avatar
Drives: 2010 VR CAMARO 2SS/RS
those were good
ljustin293 is offline   Reply With Quote
Old 11-30-2008, 06:29 PM   #6
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
Very funny.
EZ outs - hee hee - I'm SO glad I don't work on cars anymore.
camaro5 is offline   Reply With Quote
Old 11-30-2008, 06:39 PM   #7
09'Z28
The "Mad Hamster"
09'Z28's Avatar
i was just using that tool...
Old 11-30-2008, 06:52 PM   #8
Chewy
My boredom isn't safe
Chewy's Avatar
Drives: 2010 SS Camaro
Send a message via AIM to Chewy Send a message via MSN to Chewy
too true LOL
Chewy is offline   Reply With Quote
Old 11-30-2008, 07:30 PM   #9
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Drives: 2010 1SS:RS:LS3:SW
wow... so much of that is sooooo true...
I can vouch for this one personally
A.K.A - Diarmadhi (old handle) - So much to do.. So little money
Owner : Fast-Stache Industries LLC
The_Stache is offline   Reply With Quote
Old 12-01-2008, 01:01 AM   #10
ChevyNut
ChevyNut's Avatar
Drives: 2010 SS Camaro Black on Black
Ya over half of those have been proven facts and theories in my dads shop by both of us.
Only you can see this!
<a href="http://www.danasoft.com"><img src="http://www.danasoft.com/vipersig.jpg" border="0"></a><p><div style="font-family:Arial,sans-serif;font-size:11px;">Sign by Danasoft - <a href="http://www.danasoft.com">Get Your Free Sign</a></p></div>
Kinda scary isnt it!
ChevyNut is offline   Reply With Quote
Old 12-01-2008, 01:24 AM   #11
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
GREAT!
Old 12-01-2008, 12:07 PM   #12
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
So along these lines,
I spent all Sunday afternoon and evening helping my Brother In Law (whom I like very much in spite of the fact that he is a die hard ford guy) replace the clutch in his 91 Bronco.....
In the rain, on rain soaked grass, with no jack, only flashlights and one work light, and it's a 4wd so we had to R/R the transfer case also.... We didn't get done until 1230 midnight cold, tired, wet and grumpy. But we got it running again....
I won't bore you with all the problems we had but, I will say removing the pilot bearing with the bleepity bleep tool was the most fun part of the evening.......
We we're lucky enough that my Mother-In-Law was able to bring my air compressor and impact wrench over to his house to help us out.....
Very thankful that we avoided this.... Very thankful.
Old 12-03-2010, 05:21 PM   #13
JMS
Drives: IOM Black stripes, A6, IO interior.
These are pretty cool descriptions of these tools and in some cases very on the mark.
JMS is offline   Reply With Quote
Old 12-03-2010, 05:40 PM   #14
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
HackSaw is so true, that was the big test in tech school. you had to be very zen to get a machine cut from one.
from experience
Wood Rasp: Used on aluminum and steel until dull.
Carbide Masonry Drill Bits : Great for hogging out large holes in aluminum and steel.
Used the last one just a week ago when I did a dual bolt pattern by drilling some Dodge bolts rims with a Buick pattern too and use one to counter sink / bevel the holes for the GM lug nuts. Worked like a charm and beat buying new rims.
Bumblebee Paint Job Tom Henry Racing Cosmetics and Lighting Modification Discussions 85 11-29-2012 08:39 AM
How valuable is your job? Foster26 Off-topic Discussions 30 11-15-2008 10:53 AM
Can't decide on a paint job Knuckles Cosmetics and Lighting Modification Discussions 6 10-22-2008 08:45 PM
New Job Openings at GM (Fuel Economy Research) TAG UR IT General Automotive + Other Cars Discussion 3 04-14-2007 11:18 AM
