TireRack
Old 07-24-2009, 10:48 PM   #1
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
Do you think that the car needs a separate Clutch Fluid reservoir
So like the Title said do you think that the Camaro needs a separate Clutch Fluid reservoir, Like the C6 and the G8 or are you happy with it the way it is?.
2SSRS@Gen5diy is offline   Reply With Quote
Old 07-24-2009, 10:57 PM   #2
Vash
Drives: 00 Blazer
I am curious why you think it does? Is it not working properly? It's an idea that's way overdue in my opinion. Fewer components are cheaper to make and maintain. Till it fails I don't see why it would be an issue.
Vash is offline   Reply With Quote
Old 07-24-2009, 11:09 PM   #3
2SSRS@Gen5diy
I for one do not like the mix of brake and Clutch Fluid in one reservoir, Think of the ABS on your car and if you drive it all the time what is going to happen to you big $ brakes, this pic is after 1 week in the brake and Clutch reservoir for the Fluid.
Old 07-24-2009, 11:15 PM   #4
Vash
Drives: 00 Blazer
Looks normal. With the dark background hard to tell.
The fluid system is sealed dust from the clutch won't get into the juice unless there is a defect. And if your temps are nominal for eng and tranny you should be fine.
Old 07-24-2009, 11:21 PM   #5
2SSRS@Gen5diy
So why do C6 and G8 come with a separate reservoir for those car but us Camaro guy's don't get one, and here you go.
This is what it will look like.
Old 07-25-2009, 03:10 AM   #6
shockandawe
shockandawe's Avatar
Drives: 2014 Z51 Corvette
Yes
shockandawe is offline   Reply With Quote
Old 07-25-2009, 06:35 AM   #7
GEN-IV
Right Cam
GEN-IV's Avatar
Drives: 2010 LS3 / 79 Z28
I'm satisfied with a common reservior, one less component to fail.
2010 2SS/RS M6 CGM E-Force + 2015 1LT V6/A6
GEN-IV is offline   Reply With Quote
Old 07-25-2009, 06:58 AM   #8
bbardo
bbardo's Avatar
Drives: "Modi" son of "Thor"
I would like to see the aftermarket offer this option.
Clutch dust can't be a good thing for the ABS to deal with IMO
2SS/rs named "Modi"
Adopted & signed by Scott 8/15/09
Officially "Son #2 of Thor"
bbardo is offline   Reply With Quote
Old 07-25-2009, 07:35 AM   #9
nards444
nards444's Avatar
Drives: 1SS/RS Black
i really dont care
2010 1SS/RS Black, CGM stripes, polished Rims, Tinted windows, Hurst shifter
nards444 is offline   Reply With Quote
Old 07-25-2009, 07:49 AM   #10
CatiaJockey
CatiaJockey's Avatar
Drives: 2010 2LT RS
Clutch dust cannot get in the fluid no more than brake dust can. Its a sealed system and the discoloration you see is completely normal. I have no issue with the combined system, works good lasts a long time.
CatiaJockey is offline   Reply With Quote
Old 07-25-2009, 08:05 AM   #11
WayneE
WayneE's Avatar
Drives: ZL1 A10
I don't think it would be too hard to separate the reservoirs, like other LSx-powered cars. For a car that's tracked, it would probably be a worthwhile investment.
17 ZL1 Convertible A10
WayneE is offline   Reply With Quote
Old 07-25-2009, 08:07 AM   #12
alrox
Drives: corvette
Read this
Clutch dust does get into the clutch fluid system in Corvettes and I see no reason why it won't happen on the same type of system in the Camaro. You will end up with clutch dust in your brake fluid if this system is like the Corvette's. This is a bad design.
Look for Chevy to change this soon because it appears to be a cost cutting measure.
alrox is offline   Reply With Quote
Old 07-25-2009, 08:32 AM   #13
2SSRS@Gen5diy
You ma be right, But for $22.00 and 1 1/2 hour of my time it's insurance.
Originally Posted by alrox View Post
Read this
who do you think i sent an e-mail to:
Upgrading to a DOT4 fluid sounds like a good idea. GM now is recommending DOT4 for all Corvettes, including those whose owner's manuals state DOT3.
There is a list of good DOT4 fluids on my website’s clutch care page. I use two different fluids interchangeably.
(1) GM Super DOT4 expensive and hard to find
(2) Prestone DOT4 cheaper, widely available, including Walmart
Only brand to avoid is Valvoline. It leeches to black almost immediately.
Good luck with your car.
Ranger
Hi i have been looking at your post's for a long time now on this forum, But I got the new camaro last month and noticed that the brake and clutch reservoir is combined into the brake reservoir. I am planning to split the two apart and give the clutch its own reservoir but am wondering if I can upgrade the fluid in the clutch to dot 4 instead of dot 3. Do you think that this would be a problem.
And i did this yesterday like i said in 1 1/2 hours and all the parts are $22.00
parts you need are:
#1 new reservoir from a GTO a Holden part # 92065790 list $19.33 but can get for $15.00
#2 a hose clamp, Range 1/4-5/8" less than $1.00
#3 a rubber plug for the brake master cylinder reservoir. $ 0.75
#4 2 self tapping metal screws for the new reservoir. $ 0.50
#5 And this is the end Dot 4 Brake fluid "Prestone" . $ 2.75
And that is it.
Old 07-25-2009, 08:48 AM   #14
RPO F55
Drives: 2005 C6 Corvette
Clutch dust getting into the fluid is a well known issue with the LS motors and manual transmissions.
Has been happening on C6 corvettes from some time - only on the C6 you can cycle the fluid with fresh stuff given the separate tank.
Not sure why they did this on the Camaro - I like being able to cycle out my fluid periodically with fresh DOT4. Easy process, only take a few minutes and I can have clean fluid.
Check your fluid after about 10k and you won't believe how black it looks. Definately clutch dust getting by.
RPO F55 is offline   Reply With Quote
Winner, winner - Jalopnik compares the Big 3 Number 3 5th Gen Camaro SS LS LT General Discussions 31 04-17-2011 03:24 PM
What's considered a Muscle Car? SyN General Automotive + Other Cars Discussion 125 09-25-2010 12:04 AM
MATRIX – 24HR REVIEW CAMARO 2SS/RS - NO BS!! Matrix 5th Gen Camaro SS LS LT General Discussions 54 06-14-2009 02:37 PM
The Camaro, what it has come to mean for me Number 3 5th Gen Camaro SS LS LT General Discussions 23 04-13-2009 09:31 PM
2010 SMS Mustang TFord General Automotive + Other Cars Discussion 19 01-22-2009 11:00 AM
