Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Road Course/Track and Autocross
Old 03-07-2018, 10:31 AM   #127
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
285 squared is the route i believe now for road course/autox is the best and safest for these wheels 19x10 ccw on route 15mm and 21 mm offsets my thoughts now are on which tire dia for fender clearance as my ridetech coil overs are still on a 10" spring which requires a 6.1 back space(15mm offset)
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow catsLocks@7.5 degrees castor and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings
Bretts is offline   Reply With Quote
Old 03-07-2018, 10:58 AM   #128
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
Originally Posted by JusticePete View Post
Guinea Pig??? We have been running 305/30/19 RE-11s since 2009. We are running 325/30/19 RE-11s as well. I seriously doubt the 305/30/19 RE-71 will rub ;-)
325s
305s on these two...
Pete, you can't be posting pictures of a camaro losing to a mustang on here.
Old 03-20-2018, 02:44 PM   #129
600hp-lpe
Drives: 2010
I have 19X10 CCW's with 285 bridgestone RE-71's. Car is lowered over an inch - no issues with fender clearance. These are my street setup.
Plenty of Issues with clearing speed bumps however... I avoid them like the plague.
600hp-lpe is offline   Reply With Quote
Old 03-23-2018, 09:46 PM   #130
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
My wheels arrived so light!,offsets are different for the better CCW 10" 15 and 33 offsets.
i need to polish the rears to match the front sets highly polished finsih but they are new
and with a 10mm spacer up front I can run the 305 30 19 set up and will probably after my 285 35 19 re-71s are worn, my wheel calculator actually specd 9.5" wheel minimum for that tire not that it is correct over the manufacturer
Old 03-28-2018, 11:32 AM   #131
94boosted
94boosted's Avatar
Drives: ‘17 1LE, ‘17 BMW 340, ‘18 F-150
My tire shop is having a heck of a time mounting 305/30/19 RE71R's onto my front 19x10 Forgestar CF5's, they just can't get the bead to seal but I know for a fact they fit as these are the exact wheels that came off of an autocrossed SS 1LE running the same tires.
Bretts are you in Calgary or Edmonton? Any plans on autocrossing with the SASC this year?
Originally Posted by nilfinite View Post
Gotcha. Interesting info!
Has anyone tried custom-valved Koni shocks before? Still need to read up on shock construction... So we want max gas pressure to get some extra spring rate from the shocks and then what else?
I had my Koni's custom valved by TrueChoice and they actually run a lower N2 pressure than you'd think, arguably just enough to prevent cavitation of the oil. I spoke with their engineer as I too was surprised by this decision as I thought in a street class car you'd want to do anything you can to increase spring rate and running high N2 pressure is one way of doing that, but in their testing on the Koni twin tube's that the best set up and it does result in a slight reduction in ride height.
2017 - SS 1LE
2015 - 2SS, RS, NPP, 1LE - Sold
94boosted is offline   Reply With Quote
Old 03-28-2018, 06:55 PM   #132
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
94 boosted I am on the Sask Alberta border 3 hrs from the badlands site underway 2.5 hrs to Red Deer where i get a few runs in, definitely interested in doing some drop ins with you guys a buddy runs with you guys I believe. My tire guy has no problems with the 305 30 19 in terms of doing it for me, might have to as mid June currently for the 285 set up , will be a big step as would probably get new hubs for the extended studs that i would need to clear front suspension via spacers
Old 03-28-2018, 07:39 PM   #133
Synner
Drives: cars
Not every machine works well with low profile stiff sidewall tires. Shop around.
Synner is offline   Reply With Quote
Old 03-28-2018, 07:43 PM   #134
Retro69
Retro69's Avatar
Drives: 2018 Camaro ZL1
My tire guy had quite a bit of trouble with my RE71s on OEM Z/28 wheels. They specialize in high end Porsches, lambos, etc do they are no strangers to wide, low profile rubber.
Retro69 is offline   Reply With Quote
Old 03-28-2018, 10:21 PM   #135
94boosted
94boosted's Avatar
Hope to see you out at some of the Calgary events, my name is Tom.
2017 - SS 1LE
Old 03-28-2018, 11:31 PM   #136
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
Don has a charcoal 16 ss but broke something so year off and sounds good!
Old 03-30-2018, 07:05 PM   #137
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
The Camaro came from behind to beat out that other car by 1/10th of a second.
You need to find another tire shop.
It would be unusual for a car set of twin tubes to be high pressure N2. You'll find that more often in more performance oriented monotubes.
