Old 03-24-2010, 08:26 PM   #1
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
a little exhaust change
the situation: so, in preparation for my long tube headers, i decided to do a little exhaust work to Penny. for the past 3.5 years, i've just been running a 3" mid pipe to a dumped chambered muffler. i knew after the LTs, that was just gonna be way too much bed-rattling goodness for my taste, so i decided to add some tail pipes out the back. i've also heard the argument that with certain mufflers, you lose some low-end torque when it's dumped, so i was also eager to check the validity of that statement.
the new hardware: dual 2.25" 14 gauge aluminized steel tail pipes into 3.5"x22" t304 stainless tips
the difference: it's a little hard to tell in the video, but the exhaust note is now a little more defined & deeper. it also dropped the slight drone from ~2000rpm to ~1650rpm - which reduced highway noise @ 70mph (i can hear the radio & talk to people much easier now). it's generally much quieter in the cab - so much so that i stalled it a couple times because i couldn't hear as i was letting the clutch out. as for the torque difference, it did pick up a little in the low-end, but i believe it might've lost a little top-end because the comparisons you'll see at the end of the video still come out to the same time. the way i know the bottom of the curve is a little fatter is by the fact that i can shift at slightly lower RPMs without bogging the engine - perfect example is shifting to 3rd @ 2000rpm. before, it started bogging even with light throttle, but now i can perform the same shift with the same throttle pressure no problem.
now - for the picture show
http://s943.photobucket.com/albums/a...rrent=2010.flv
Eve ('00 FRC): hot-air intake
V8 Camaro Aftermarket Exhaust Video Clips Compilation tjbusa Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 591 07-06-2022 08:38 AM
DIY Noweeds exhaust diverter installation CanadianCamaro Camaro DIY & HOW-TO instructions & discussions 42 08-15-2016 11:11 AM
Custom Magnaflow Exhaust buddylok Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 49 05-16-2016 11:02 AM
axle back vs catback exhaust kozzmo49 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 43 03-28-2012 09:27 AM
Heard exhaust of L99 tonight - OMG!!! Hylton 5th Gen Camaro SS LS LT General Discussions 60 03-06-2010 05:03 PM
