05-03-2024, 12:48 PM | #1 |
Drives: 2019 Camaro 1SS1LE Join Date: Jan 2024
GM Engineering
If you’ve never had a psychotic break or wanted to prevent stupidity by way of genocide, try removing a GM manual transmission shifter pins. The most retarded feat of engineering ever conceived. What the **** was wrong with good old bolts and threads? No let’s use a spring loaded retaining pin that can never be uninstalled without some form of telekinesis. One day when I am over this car, I will cheer its sale and happily go back to a Mustang. GM’s manual driveline is terrible to work on.
Thanks for letting me rant. What a pile.
2019 1SS1LE M6 Shadow Grey Metallic
4/2/2024 "Under the Knife..." Build in progress Previous Rides: 1996 Ford Thunderbird V8 - PI Swapped & Comp Cammed 310whp/330wtq (SOLD 2003) 1991 Ford Thunderbird SC - Ported & Tuned (CEF 2005, SOLD 2005) 2001 Mustang V6 (SOLD 2006) 2008 Mustang GT M5 - Procharger D1SC 440whp/480wtq @8psi (SOLD 2013) 2013 WRX M5 - Cobb Tuned (SOLD 2017) 2014 Focus ST - Cobb Tuned & Re-piped Hot Side (SOLD 2019) |
05-03-2024, 04:33 PM | #2 |
Drives: Chevrolet Camaro Join Date: Feb 2020
Those things are definitely not made with the intention of service. Most likely a cost saving/assembly choice for the factory.
That said, I'd rather deal with those pins than have anything to do with an MT82 trans in a mustang gt again. |
05-04-2024, 01:17 AM | #3 | |
05-04-2024, 08:38 AM | #4 | |
I did have to deal with the pin when installing the hurst. I can see it being frustrating when you need to breeze through those steps with a job as big as the one you got there. Dam
05-05-2024, 10:14 AM | #5 |
Did you go at the pins from the inside of the car?
05-06-2024, 11:23 AM | #6 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
OP we all got to vent from time to time, even me- LOL.
Hopefully you were doing this work to upgrade to a Hurst short throw shifter. If that's the case, in a couple weeks you'll be back in love with your Camaro and the PIA pins will be a distant memory. |
