BeckyD @ James Martin Chevy
Old 04-30-2024, 02:26 PM   #1
Zracer
Drives: 1999 Z28, 2011 2SS VERT, 2016 1SS
New Dyno numbers/ gained power from valve springs
Long story short I put conical springs (supposed to be good for .650 lift)on my heads when I rebuilt the engine because my oil pump came apart.
I ported the heads, done Gpi drop in rods and pistons and cam motion stage 2 PD blower cam, katech oil pump.
My car made 487 rwhp n/a with an msd intake on it.
I put it on the Dyno again back in September last year and it made the same number.
I recently developed a skip and it ended up being a broke valve spring. They have 10k miles on them. I replaced them with cam motion .660 dual springs. I gained 18 hpw and 9 torque peaked but most importantly it gained through the whole rpm range plus carried further. I was pleasantly surprised. I think I had bad springs from the start.
Zracer is offline   Reply With Quote
Old 05-01-2024, 09:13 AM   #2
Katech_Mike
Drives: 2015 Camaro ZL1
A great example of why you should buy proven parts from vendors that actually own a Spintron and validate entire valvetrain combinations.
It's amazing what certain vendors tout as being "good" parts but when you actually test them on a Spintron the results are poor.
Katech_Mike is offline   Reply With Quote
Old 05-01-2024, 11:10 AM   #3
Zracer
I'm very lucky I didn't drop a valve and destroy my engine. It was never noisy and I assumed it was a plug wire and drove it home.
Old 05-02-2024, 08:33 AM   #4
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Wow that is crazy... I would have assumed the Conical springs would be a great match with the Cam Motion stage 2.
2016 NFG 1SS A8
Options-2SS Leather/NPP
