04-08-2024, 08:35 AM | #1 |
Drives: 2019 Chevrolet Camaro SS Join Date: Apr 2021
AN line blew off
So one of the 8AN lines running to my fuel rails for my port injection blew off and pushed out like 3 gallons of fuel in the engine bay. thank god it hit the firewall and not the header/motor. There was a lot of pressure behind it to shoot it back to the firewall.
What the f*** could have caused it? I built the AN line 100% to a t. exactly how it was supposed to be built. I made sure it was seated properly, i double and triple checked everything, and the line has been in use for months for tuning purposes. I don’t like that something i did could have hurt somebody. But i’m not sure what else i could have done differently. I am genuinely confused. It was a -8AN pro flow fragola fitting
'19 Camaro SS | LT4 High Side and LT4 injectors | Fore Innovations Triple 525 In-tank pumps | Too High PSI Secondary Port injection | E85 | Holley Low Ram | BTR Stage 3 S/C Cam | Circle D 3600 Stall | Forged pistons and rods | D1X procharger, 3.5 pulley making 18-20 PSI
04-08-2024, 08:52 AM | #2 |
Drives: 2024Camaro 2SS CE Convertible Join Date: Jul 2013
I had a boss with a chipped Dodge that kept blowing injector lines because he was over charging the injectors. Just saying.
04-08-2024, 08:57 AM | #3 |
well shoot i wouldn’t imagine anything should be getting over charged. i have 16 injectors and i’m only running 2 pumps at 60 psi. i wouldn’t think 60 psi would blow off a line like that. we haven’t even turned the 3rd pump on yet. we aren’t turning anything on until we figure out what causes the issue. the tuner thinks it might be a faulty fitting or that the regulator went bad and didn’t relieve enough pressure
04-09-2024, 05:59 AM | #4 |
Sorry to hear that, I've not heard of that happening and with such low fuel pressure at the rail I'd think it was a fitting failure. Amazing how much it can pump out even under low pressure compared to the high side. Hope you get it figured out, I ran that set up for over a year with no issues.
04-09-2024, 09:21 AM | #5 | |
04-09-2024, 09:36 AM | #6 |
Maybe pressure test with air, if you are not already doing that:
https://www.amazon.com/Lines-Fitting.../dp/B00MEMIJ1E |
04-09-2024, 10:19 PM | #7 | |
04-10-2024, 06:20 AM | #8 |
advice or opinions, fitting, fuel, fuel system, help me |
