Go Back   CAMARO6 > Technical Camaro Topics > Cosmetic modifications (exterior and interior)
Old 03-31-2024, 06:29 PM   #1
TadeLT1
Drives: 2016 Camaro 2SS coupe, 6-speed
Coupe and convertible door panels. Will they interchange?
Hello. I was wondering if anyone had any info or can point me in the right direction for possible info. I have just got the adrenalin red leather SS interior that came out of a convertible. I know the rear seats are mounted different and will not fasten in place without some work. And I found the thread in here about the front seats. My car is a 2SS so hopefully that won't be a problem. But I am searching for info about the door panels. Does anyone know if the door panels from a convertible will fit in a coupe? I am picking them up next week. If they are different, I am hoping I can at least use the red leather middle pieces and upper red stitched piece to fit into my door panels. Any info would be much appreciated. Thanks
TadeLT1 is offline   Reply With Quote
Old 03-31-2024, 07:01 PM   #2
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
From a cursory look (because I never owned a 6th gen convertible), only the window switches are different between the coupe and the vert. Even then the overall dimensions of the switch blocks are probably the same, at least that's how I would do it if I were in charge of the design, because having separate door cards for each body style would be more costly for no good reason.
Hopefully someone who owns or owned both can help you more, though
735 rwhp | 665 rwtq
3000 - 2/06/18 TPW 2/26/18
Old 04-01-2024, 12:00 PM   #3
TadeLT1
Thumbs up
thanks a lot!
