Go Back   CAMARO6 > Technical Camaro Topics > Audio, Video, Bluetooth, Nav, Radar, Electronics
BeckyD @ James Martin Chevy
Old 03-20-2024, 12:30 AM   #1
D2SS1LE
Drives: 2022 Camaro 2SS 1LE
Adding shock sensor to factory alarm
Hi all, anyone attempt adding shock sensor to factory alarm? I an interested in adding DEI-504D. Anyone here have the factory wiring for the door trigger and factory alarm wiring?
D2SS1LE is offline   Reply With Quote
Old 03-20-2024, 02:59 PM   #2
Midblues
Drives: Chevy Camaro 2019 Turbo 4 LT 6sp
There's an easier way.
http://addshocksensor.com/shop-now.html
Check there web site email them they send you an install video for you car and instruction plus a toll free tech support # They guarantee you will be able to install and set it up as close to plug and play as possible to work with your OEM car alarm and key fob.
Midblues is offline   Reply With Quote
Old 03-20-2024, 03:29 PM   #3
Deacon Blues
Drives: 2024 Camaro 1SS M6
I'd be intrigued to try it if I could see an actual installation video. They seem to be deliberately obfuscating the install process other than telling you that you'll need wire cutters and maybe some crimpers...
Deacon Blues is offline   Reply With Quote
Old 03-20-2024, 03:34 PM   #4
keep_hope_alive
Electrical Engineer
keep_hope_alive's Avatar
Drives: 2023 1SS A10 Black
I imagine you only get an actual video after you buy the product. I understand why they wouldn't give away the install videos for free.
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair.
1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22
Daily Driver mileage update: 22k mi. @ April 2024
New Engine @ 22,600
Build Log: https://www.camaro6.com/forums/showt...6#post11353116
keep_hope_alive is offline   Reply With Quote
Old 03-20-2024, 03:43 PM   #5
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Drives: 2020 2SS - A10, NPP, MRC, CAI
I contacted them, $155.00 for the system (free shipping), said it takes 40 minutes to install and claim they have never had anyone not be able to complete the installation successfully.
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Fender Badge, Footwell Lighting
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires
Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... BOTH are a lot of fun to operate...
2SS Capt is offline   Reply With Quote
Old 03-20-2024, 05:06 PM   #6
fj5gtx
fj5gtx's Avatar
Drives: 70 GTX, 06 Mustang, 22 Camaro LT1
Likely you can take off the door panel, look at the latch mechanism and figure out the wire that grounds when the latch opens, then you'll know which color to look for in the kick panel. BTW you don't have to connect in at the door, you could go after the trunk or hood as well - might be easier to access dependent on your install.
I would bench test that sensor to ensure that it's output goes to ground when triggered. Or you'll have to add something that converts the output.
2022 CAMARO LT1 COUPE AT10
fj5gtx is offline   Reply With Quote
Old 03-20-2024, 05:07 PM   #7
Deacon Blues
Sure, understandable. But I'd like to know what I'm getting into before I buy... Especially if wiring is involved.
Old 03-20-2024, 05:20 PM   #8
fj5gtx
fj5gtx's Avatar
It may be more about security of how its installed, they only want to publicize their installation to actual purchasers... otherwise everyone with internet access will know how you wired yours up.
I can tell you what you'll need to do... you will need source power and ground, and the output will Tee into your door sensor wire, likely in the driver kick panel.
If they're quick thinkers, they'll just pop the hood and cut the horn wire or pull its fuse and continue the theft.
One counter measure is better than none, but the more the better... they call that layering.
Old 03-21-2024, 11:49 AM   #9
D2SS1LE
Thanks all for you answers and feedback!
Old 03-24-2024, 05:09 PM   #10
Caerus
Caerus's Avatar
Drives: 2023 Camaro ZL1
Thanks for posting this car alarm addition. I think this would be a great extra line of defense.
2023 Camaro ZL1 6MT Summit White
Caerus is offline   Reply With Quote
Old 03-24-2024, 10:21 PM   #11
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
I’ve definitely seen many cases where the thieves cut the horn through the grille or cut the grille to get to the horn, if it’s not too intrusive of an install I’d still like to get one of these. Too many times I’ve had a window broken into and the car alarm doesn’t go off, rather know it happens especially if it starts to rain through the night (actually close to happening once, thankfully caught it before the rain really started pouring)
2022 2SS 1LE - Window Sticker - Cold Air Inductions Elite Carbon CAI
2016 1LT v6
- Totaled
Happiness: Infinite
Bumbleboy92 is offline   Reply With Quote
