Old 02-20-2024, 12:29 AM   #1
lowflyinghawk
lowflyinghawk's Avatar
Drives: 2023 2SS 1LE M6
SS 1LE First oil change - Break in procedure
Hi everyone:
I'm approaching 500 miles and I'm planning on doing the first oil change. I was wondering what else fluids do I need to change besides oil change? Asking because I read the manual and hp supplement, I didn't find anything other than first oil change at 500 miles.
Based on what I read here, I listed a couple of things.
  1. rear differential fluid
  2. transmission fluid
Thanks!
lowflyinghawk is offline   Reply With Quote
Old 02-20-2024, 04:18 AM   #2
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
I would suggest doing rear differential with your first two engine oil changes, my 1st one looked quite yucky, my second one looked better. Now I just do it every season.
As far as your transmission, I am not sure what everybody’s doing with the m6 for break in , it’s easy enough to do so that’s a bonus.
CalgaryZL1 is offline   Reply With Quote
Old 02-20-2024, 07:45 AM   #3
CTRifecta
CTRifecta's Avatar
Drives: 2SS 1LE
Definitely the rear differential from what I've read, but I don't think the transmission fluid is required.
2024 2SS 1LE | 6MT | Riverside Blue
1100 - Order submitted - 7/12/23
2000 - Order accepted - 8/22/23
Vehicle Built (per chevy chat bot) - 10/10/23
Window sticker available online - 11/4/23
Arrived at dealership - 11/10/23
CTRifecta is offline   Reply With Quote
Old 02-20-2024, 08:21 AM   #4
WhyUMad1LE
Drives: 17 SS 1LE
I did the LSD (GM) and tranny (Tremec) at 500, 25k, and 50k. Seems to work well.
WhyUMad1LE is offline   Reply With Quote
Old 02-20-2024, 09:27 AM   #5
ZPirate
ZPirate's Avatar
Drives: 2023 Summit White Camaro ZL1 M6
Originally Posted by lowflyinghawk View Post
Hi everyone:
Thanks!
I recommend changing both the oil and the diff fluid at 500 miles. No need to change the transmission fluid then unless you absolutely want to. As others have said the diff fluid tends to be somewhat dirty looking. Plus changing it will help get rid of any remnants from breaking in the gears.
2023 Summit White ZL1 M6 (delivered 10/15/23)
2019 Dodge Durango R/T (daily driver)
2003 Nissan 350Z (modified)
2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold)
2009 BMW 135i (Sold)
ZPirate is offline   Reply With Quote
Old 02-20-2024, 08:48 PM   #6
db2022cs
I have seen some people do swap out the trans fluid to something else and it might help make shifting a bit smoother. My 1-2 and sometimes 2-3 shifting can feel a bit more notchy and crunchy than I like until it gets temperature into the fluid. I have read that a different fluid can help with that. I would definitely do the diff fluid with the oil at 500, and if you want, do so again at 1500, then I follow the oil life indicator. People always say this is a waste but it gave me more peace of mind. I found the magnetic drain plug had material on it both times. Also, make sure your coolant levels are correct. There are two tanks. A lot of people had the expansion tank below where it should be from the factory, myself included. Main tank filled all the way up and the expansion tank to the cold line. Procedure to fill is in the owners manual.
2023 Riverside Blue Metallic 2SS 1LE Camaro
2021 Black Hyundai Veloster N -Sold-
2016 Grey Chevy Volt -Sold-
2018 Blue AWD Kia Stinger GT2 -Sold-
db2022cs is offline   Reply With Quote
Old 02-21-2024, 01:08 PM   #7
lowflyinghawk
Thanks everyone for the info! Glad I didn't miss anything.
