01-07-2024, 09:12 AM | #1 |
Drives: Chevy Camaro Join Date: Dec 2019
Lift pads?
I've been looking for lift pads and it seems like the only ones available for the Convertibles are from ZL1 - which I am sure they are nice, but it's tough to spend $90 when the non-convertible ones are $35 on amazon
Any alternates/recomendations? |
01-07-2024, 10:36 AM | #2 |
Drives: 2023 2SS Convertible Join Date: May 2009
I bought those and the arms on my 2-post offset lift won't go narrow enough to use them. Waa waaa.
-Geoff
'12 2SS RS Convertible - Traded in.
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold! '23 2SS Convertible -Same as above except orange. |
01-08-2024, 06:14 AM | #3 |
Hot Camaro
01-08-2024, 06:23 AM | #4 |
Drives: 2022 Camaro ZL1 Join Date: Dec 2021
I have these:
https://www.ebay.com/itm/35494622978...Bk9SR6qpsZCdYw
Randy in Nashville
2022 Chevrolet Camaro ZL1 A10 2020 Ford Mustang Shelby GT500 2020 Genesis G90 Ultimate 2019 Mercedes-Benz SL450 2017 Corvette Grand Sport A8 2016 Hyundai Equus Ultimate 1971 Datsun 240Z |
01-08-2024, 06:37 AM | #5 | |
Hot Camaro
01-08-2024, 06:41 AM | #6 |
Sorry. Failure on my part to pay attention.
Randy in Nashville
01-08-2024, 07:53 AM | #7 | |
I was hoping to find a set that stayed with the car but that looks like a good Plan B option! Appreciate your recommendation - it's cheap enough that I may buy it in case I need to lift my Honda |
01-08-2024, 12:49 PM | #8 | |
Drives: 24 ZL1, 6.2L Denali, 73 SplitBumper Join Date: Jun 2023
I believe the convertible ones are just clearanced more. If you have access to a grinder or better yet a bridgeport or manual milling machine, you could make these ones work. (The ones for 39.99)
2024 ZL1 Radiant Red / Coupe / M6 / PDR / BCD / Carbon Scoop, Dash, Shifter / Red Seat Belts / Black Lugs
https://cws.gm.com/vs-cws/vehshop/v2...FJ1R60R0111531 |
01-23-2024, 10:21 AM | #9 |
Thank you Al Oppenheiser!
Correct. The rockers on the vert are thicker than the coupe for improved rigidity, reducing the depth of the pinch weld seam. Once side of the lift point must be milled to allow clearance, or it won't fit.
01-24-2024, 01:00 PM | #10 | |
I basically did it anyways on my lift pads just to have them fit better. Similar process for the conv. I bet, just might be different amount. https://www.camaro6.com/forums/showp...9&postcount=10
