12-29-2023, 08:20 PM | #1 |
VERITAS AEQUITAS
Drives: 2012 IOM SS Join Date: Jul 2009
Leveling or without Leveling System?
I am trying to replace the housing on my 2012 Camaro SS and the parts place is asking whether I want Leveling or Non-leveling System. I had never heard of this before. How do I know which I need? Any help would be greatly appreciated. (I fear I am not as car mechanic savy as many of you.) ***(Sorry, as pointed out below...This refers to the HID Headlights.)
12-29-2023, 09:00 PM | #2 |
Drives: 2010 Camaro 1SS Join Date: Aug 2022
housing for what? why arent you specifying??
12-29-2023, 09:15 PM | #3 |
VERITAS AEQUITAS
My humblest apologies, I am embarassed I forgot to mention what it is...It is for the front headlights which are HID.
12-30-2023, 08:41 AM | #4 |
im pretty sure you are referring to the allen head screw located in back of the headlight bucket.takes a 6mm allen wrench and you can adjust the headlights on each side up or down independently.its on the end of a stalk in back of the headlight
12-30-2023, 10:08 AM | #5 |
Quick search says that auto/self leveling was available on some export Camaros.
12-30-2023, 11:48 AM | #6 |
Check the rpo sticker in the trunk under the carpet on the left. As gtstorey stated it looks like the exports only got the self leveling system.
TR7: Auto headlamp leveling system (european requirement) TB8: RH Rule of the Road T94: LH Rule of the road
12-30-2023, 06:07 PM | #7 |
^^^ This...
12-30-2023, 07:08 PM | #8 |
VERITAS AEQUITAS
Thank you guys so much for such a concise and quick answer! I greatly appreciate all of your help!
12-30-2023, 07:13 PM | #9 |
Hey, you're welcome!! If we know, we share... Good luck..
