12-20-2023, 03:51 PM | #1 |
Drives: 2017 Camaro 2SS Redline Join Date: Dec 2023
2017 2SS Electrical Nightmare
1 dealership in Key West with a month wait. Car hass 20k on it amn kep under cover. Car was running fine I went to Tennessee for Thanksgiving to see family and when I came back it was dead I've never changed the battery and it's the 17 so I immediately changed the battery which died overnight got another battery because it was under warranty thinking maybe it was a bad one swap that one out too used to jump box because it would not jump with cables still have the battery drain issue all fuses check good I change the three relays that are the same in the front fuse box checked all the grounds that I could find my trunk is currently torn apart because of that everything in it looks brand new but I'm popping two codes on Startup that once I clear them they don't come back one for transmission and one for fuel pump I also have random electrical issues that come and go like heated or cooled seats don't work my rear view camera didn't work for two days and now it's fine. I can't find anything wrong except I did pull my amp out of my trunk and I realized that there was a whole lot of grease on the one port and the other ports just had a little bit around the edges curious if that left Port if all the pins were covered with grease if that would cause an issue it was like that from the factory or a previous owner I did not do that. For the moment I'm stuck disconnecting my battery every time I stop for any period of time and leaving my truck really pop so that I can access it when I'm not crawling through the back.
12-20-2023, 04:42 PM | #2 |
A bad battery can cause various random different things not to work, and various random codes to be thrown. I'm sure you bought the correct battery for the car. Have you checked the new battery to make sure it's operating properly, that's it's properly charged? Your fuse box in the trunk didn't get wet while you were gone, did it?
2020 Camaro 2SS - Riverside Blue, NPP, Magnetic Ride, Sunroof
RUXIFEY Smoked LED Side Marker Lights / Black SS emblem on rear bumper / Blue SS vinyl overlay on front bumper emblem / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint RE Audio RFX10D4 10" Sub / Hand-made sub enclosure / Hifonics Zeus ZRX1200.1D amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
12-20-2023, 05:03 PM | #3 |
376 cubic inches of fun
Why the hell is there grease over all the connectors? That is not from her factory. How long have you owned this car?
12-20-2023, 07:38 PM | #4 |
Drives: 2023 Camaro 1SS 1LE 6MT Join Date: Nov 2023
Dielectric grease maybe? Not sure why the amp should need it, shouldn't be water getting there..
12-20-2023, 11:31 PM | #5 |
Battery was changed and the new battery died overnight. It was under warranty so swapped it again in case I got a bad one. The car I've owned 2 years and no issues till now. I just took the amp out after seeing posts about water in the trunk. Fuse box looks good. Amp has slight corrosion on the outside but opened it up and was clean. Removed the grease. Well see if that changes anything. I never put it there. I didn't know if they came with that grease on there or not. Car stays under cover but it's South Florida so we do have alot of rain.
12-20-2023, 11:34 PM | #6 |
I have read the MRC is in the trunk but I can't find it to check. Found 1 place that showed it was by the amp but not in my car. Looking for it to eliminate that component.
12-20-2023, 11:48 PM | #7 |
Electrical Engineer
Drives: 2023 1SS A10 Black Join Date: Apr 2022
Time to figure out what component is associated with all of the items (what do they have in common) and replace that component. Likely the BCM.
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair. 1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 22k mi. @ April 2024 New Engine @ 22,600 Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
12-21-2023, 08:26 AM | #8 |
Drives: 2016 2SS Convertible Join Date: Dec 2019
I think the new battery he bought was "under warranty", not the car. The car is a 2017 so unless he has 3rd party coverage the B2B ran out in 2020. This isn't PTW, but that's likely expired as well.
Hyper Blue/Ash Gray A8 Magnetic Ride Control Dual Mode Exhaust 2019+ version Split Spoke Silver Wheels Navigation Silver Rally Stripes |
12-21-2023, 08:31 AM | #9 |
Drives: Chevy Camaro Join Date: Nov 2021
12-21-2023, 08:42 AM | #10 |
Drives: 2023 Camaro 2SS Join Date: Aug 2023
Have you connected a DC Amp Meter in line with the battery to see what the actual current draw on the battery at rest is? After turning the key off it should be in the milliamp range (.00x) after a few seconds. Anything higher (like .5 amps) is too high. Dialectric grease or No-Ox-ID grease on connectors is not a big deal and may help. You can try removing fuses to see if the Amp reading drops.
I had an issue with my Granddaughters 2004 Silverado and could not find the issue until I did a Google search. In her case it was a bad instrument panel circuit board. Seems the solder GM was using on the circuit board components was cracking and the resistors were opening at the contact points. I was able to resolder them, and it fixed the battery drain problem. Hopefully your problem will be easier to solve but electrical gremlins are the worst. |
12-21-2023, 10:32 AM | #11 | |
Based on photos others have posted, it does not appear you have corrosion related to water in the trunk, which is a real disaster. I do like the idea of measuring the amp draw, but this will require putting a meter in series between the battery and the car as it is DC. |
12-21-2023, 02:20 PM | #12 | |
Drives: 2017 1SS 6spd Join Date: Jan 2011
A little more detective work will turn up the corroded ground or component. And perhaps a little better car cover in the future? I expect your climate is one of the best around for rust! Good luck! |
