Old 11-18-2023, 07:33 AM   #1
Spartant2112
Drives: Camaro ZL1
Brembo Brake Rubbing on Tire Counterweights
So I got some Forgestar D5 17x10 and Mickey Thompson street r 305/45/17s. The counterweights the shop installed seems to rub on the brembo brakes and was wondering if I can bend the part that's rubbing. Saw a video of a guy reviewing a different rim, think they were 17x11s, and he said he got those sizes cause he didn't want to bend the brakes like other people. I didnt know if this is what he was talking about. I'm gonna take it back to the shop today and see if they can move them. I read forums saying these rims and tires fits stock Zl1 setups so maybe the counterweight are just put in a bad spot.
Spartant2112 is offline   Reply With Quote
Old 11-18-2023, 08:16 AM   #2
Vigilante375
Drives: 2018 Camaro ZL1
Pretty sure you can ask a shop to balance the tires so that the weights are on the other side and explain that the weights are running against the caliper.
Vigilante375 is offline   Reply With Quote
Old 11-18-2023, 12:11 PM   #3
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
If he road force balanced them then the machine will specify if it wants the weights in the inner barrel or closer to the face.
I ended up having to run some small hub centric spacers to make mine work (and I don’t even have wheel weights lol).
Old 11-18-2023, 01:40 PM   #4
2004YZFR1
Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE
Scrape those weights off before they wear a hole in your calipers hard piped brake line.
2004YZFR1 is offline   Reply With Quote
Old 11-18-2023, 02:54 PM   #5
IMCWORTH
IMCWORTH's Avatar
Drives: 2023 Camaro Convertible ZL1 A10
I use this in all my motorcycles (Way better then weights) and have used it in a couple cars that had balancing issues. maybe look into it if the weights continue to be a problem.
https://www.ride-on.com/us/home
IMCWORTH is offline   Reply With Quote
Old 11-19-2023, 06:51 AM   #6
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
get your shop to shift the weights away from that exact spot where contact will be made...not a difficult task for any tire shop
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 11-19-2023, 10:04 AM   #7
Spartant2112
Drives: Camaro ZL1
Thanks, everyone. I was able to just get the shop to move the weights. It seems to be good now.
