09-27-2023, 11:38 AM | #1 |
Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
What type of finish on SS 1LE wheels
Long story short I messed up one of my rear wheels doing something stupid. I figured out what the paint code is for the wheel but I wasn’t sure what kind of finish is on the wheels?
I’m taking the wheel in to get sanded and repainted but I wasn’t sure if the wheels have regular wheel clear coat in them or if they have a Matte clear coat/finish applied to them? Does anyone know what kind of finish is applied to the wheels after they get painted?
Current: 2023 2SS 1LE
Prior: 2016 Camaro 1SS 2007 Mustang GT 2008 Civic Si |
09-27-2023, 12:02 PM | #2 |
Drives: 2021 Camaro SS 1LE Join Date: May 2009
I believe they are Matte or a "Satin" type finish. They are for sure not gloss or flat. A good shop should be able to adjust the finish to match the other wheels.
2021 Camaro 1SS 1LE - Red Hot
2015 Camaro Z/28 - Red Hot 2001 Mecham Trans Am #3 - 7.0L LS1 |
09-27-2023, 02:14 PM | #3 |
Thank you. Yep the shop owner and I thought they were a satin/matte type of finish. Just was looking for confirmation that it wasn’t clear coat.
09-27-2023, 05:43 PM | #4 |
Drives: 2014 Ford F-350 Join Date: Sep 2023
I’m interested to know what you did.
2024 Red Hot 2SS 1LE w/BCD, PDR
2014 F-350 Crew Cab Cassis Cab Dually 6.2L w/4.30 2014 Hyundai Elantra GT 1995 Buick Roadmaster Estate |
09-28-2023, 05:28 AM | #5 |
Faster!!!
Drives: 2020 Camaro 1SS 1LE Join Date: Mar 2020
There was a thread here some time ago where someone posted the actual paint code for 1LE wheels. I can't seem to find it, but it exists!
09-28-2023, 06:54 AM | #6 |
WA784U is as close a match any one has found. I used it a few times and was happy with the match.
I had a 1LE for years and I'd be hard pressed to be convinced of anything but a gloss clear coat. |
09-28-2023, 06:54 AM | #7 |
OP says he already knows the base paint code (784U Satin Graphite Metallic). The finish itself looks like satin clearcoat to me, similar to this, but it could be a single stage paint, too, a bit hard to tell. I have a touch-up pen in this color and it does not dry to the exact same sheen.
09-28-2023, 07:34 AM | #8 | |
09-28-2023, 09:40 AM | #9 | |
Drives: 2023 Summit White Camaro ZL1 M6 Join Date: Dec 2021
I recently repaired the wheel from my car that was damaged in the accident I was involved in back in March. Insurance paid to replace the wheel with a new one, but I wanted to keep the old one and fix it so I would have a spare. I purchased a spray can of Satin Graphite Metallic paint, which appears to be really close to the OEM color of the wheels. However, it also has a bit more metallic flake in it and it lays down more matte than the wheels. So after I painted the wheel I put a couple of coats of gloss clearcoat on the wheel and it turned out really close to the OEM finish. If I had some satin clearcoat I would have probably used it instead In my opinion small touchups are fine just using the Satin Graphite Metallic paint, but a larger area probably needs some clear to make the paint look more like OEM. Here are pictures of the wheel I repaired. I think it turned out pretty good.
2023 Summit White ZL1 M6 (delivered 10/15/23)
2019 Dodge Durango R/T (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) Last edited by ZPirate; 09-28-2023 at 09:51 AM. |
09-28-2023, 01:29 PM | #10 | |
Yeah, so look at the picture below I just took, you can see the ton of metallic in the paint, which my touch-up stick matches perfectly, but there is a sheen on top that I'm leaning towards coming from satin clear coat. That's what I would do if I messed up my wheel, spray paint with clear coat, just like ZPirate did, but I'd use the satin 2K clear. Someone here sanded down their ZL1 carbon fiber dash panel with 600 grit, then re-cleared it with satin, and it came out better than stock, not as glossy and very high end.
09-28-2023, 06:00 PM | #11 | |
