08-20-2023, 10:08 PM | #1 |
Drives: 2011 Chevy Camaro 2SS/RS LS3 M6 Join Date: Mar 2019
Forward Lower Control Arm Removal
I've hit a snag trying to install poly bushings around my car and thought I'd turn to the experts here for any insight. Is there a trick to removing the forward lower control arms from the spindle on the front end of these cars? The rear lower control arms came out when I looked at them cross, but it feels like there's no force on this earth capable of moving the forward ones. I've tried a brass hammer numerous times to no avail.
Thank you all in advance for any help you can give!
2011 Camaro 2SS/RS LS3
Mods: Kooks 1 7/8" LT Headers, CAI Intake w/ APEX Race Scoop, Bo White Ported Throttle Body, MGW Short Throw Shifter, Powerbond 25% Underdrive Pulley, Borla ATAK Catback, Full DSE suspension, Bilstein B6 shocks/struts, Yukon 4.11 gears/TrueTrac, 1.25" drop Dyno Tuned by Brian Turner of Dyno Tune Motorsports |
08-21-2023, 09:26 AM | #2 |
Drives: 2013 1SS Join Date: Dec 2012
Haven't done these yet myself but heating the area of the knuckle that the control arm connects to and hitting it with a big effing hammer seems to be the way to go. You'll likely have to use something bigger than the brass hammer you're currently using. You can also try putting a jack under the threaded end of the ball joint and applying a little upward pressure in addition to heating and hammering.
08-21-2023, 09:46 AM | #3 | |
08-21-2023, 10:21 AM | #4 | |
08-21-2023, 12:50 PM | #5 |
That's my worry, and what I'd love to avoid, is having to replace the entire knuckle. I wouldn't mind so much getting a new control arm if the doggone thing would just come out one way or another. Rear arm came out with the first tap, no issues there.
09-07-2023, 03:44 AM | #6 |
I used a 4lb brass hammer. Came out in one big swing.
TSP 229/244 .629"/615" CAM w/ a bunch of goodies 465whp/443tq tuned by MayhemMotorsports-NC
