dave@hennessey
Old 07-18-2023, 02:37 PM   #1
finatic
Drives: 2010 Camaro SS 2SS
Should I mill them?
I just put 295/40r20 tires on my 2010 SS with 10.5 rims. I ordered them with the correct factory back spacing but it didn't happen. These wheels are +15 offset and I believe factory SS wheels are +42. I can have these milled all the way to +42 per 2Crave. The question is...should I? I value the groups opinion.
finatic is offline   Reply With Quote
Old 07-18-2023, 02:46 PM   #2
RupertPupkin
Drives: 2014 Camaro SS 1Le
It looks like you're about to go off roading. If it was me I'd do it, and have the flush look, or have it stick out a little bit. It could be just the angle, but it seems like they stick out about an inch.
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 07-18-2023, 02:53 PM   #3
finatic
they do stick out about an inch. I can mill off almost that full inch.
Old 07-18-2023, 03:20 PM   #4
Risingson05
Risingson05's Avatar
Drives: 2015 zl1 m6
Learn something new everyday !! Didn’t know people were actually milling rims .
What does that do to the structural integrity of the rim? I mean taking out an inch is a lot ,no? . Maybe I’m overthinking it but if you take too much material won’t your wheel studs end up being too long to torque your rims down? If I’m not mistaken , the studs only have so much thread
791whp 699 ft lbs torque on E30 - ported sc /heads by boost mode racing - PAT G cam /Tune
PB:10.7 @133.9
Risingson05 is offline   Reply With Quote
Old 07-18-2023, 03:36 PM   #5
finatic
I called the wheel manufacturer today with that same concern. They tell me that +15 is where the rim starts life then they remove material based on the cars offset spec. They say that this wheel is sold all the way to +42 which means 27mm can be removed safely. 27mm is 1.0699 inches. There is a ton of material to work with. As far as the stud length is concerned, when asked that question they didn't give an opinion other than to say there are no changes recommended when purchasing the correct offset. I guess I'll find out. I likely wont take off the full 27mm.
Old 07-18-2023, 04:16 PM   #6
redcoats1976
actually it puts me into the wayback machine and drops me off in 1975,when it was cool to have a little bit of tire hanging out...i mean that in a good way,too.
Old 07-18-2023, 04:53 PM   #7
Eddymel1998
Eddymel1998's Avatar
Drives: 2010 Camaro 2SS L99
Last time I left my "tire" hanging out the cops got involved, times have definitely changed.
Behind every scratch is a story on what not to do, and my car has a lot of stories.
Eddymel1998 is offline   Reply With Quote
Old 07-18-2023, 05:27 PM   #8
JAFWF
Drives: 2010 2SS/RS 1994 Z/28 Convertible
Don't suppose you can return them for the proper offset?
JAFWF is offline   Reply With Quote
Old 07-18-2023, 06:12 PM   #9
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
Most of these wheel companies will not accept any returns/exchange once tires have been mounted.
InFiD3ViL is offline   Reply With Quote
Old 07-18-2023, 06:39 PM   #10
JAFWF
Yeah, understand that, but how was he to know that the offset was so far off without installing?
Old 07-18-2023, 07:05 PM   #11
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
You mean like this??
Old 07-18-2023, 07:38 PM   #12
InFiD3ViL
InFiD3ViL's Avatar
Oh I totally agree. Its BS if they sent the wrong wheel from what he ordered and refuse to allow an exchange, but he hasn't confirmed that yet. If it was me I would be mighty pissed and would be pressing for an exchange or refund. I just couldn't justify having to have machine work done on brand new wheels through no fault of my own.
If I was unable to return or exchange I would likely sell them to recoup money and buy the correct offset wheels...elsewhere.
Old 07-18-2023, 07:44 PM   #13
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
^^ And yep. This for sure. No way I would have kept them being the wrong offset. I myself wouldn't even be comfortable with even having them milled..
Old 07-18-2023, 08:35 PM   #14
finatic
It wasn't 2Crave that made the error is was the shop I ordered them from. Milling the offset is pretty standard and I just waited to long. The 275/40r20 tires didn't hang out like this but were small for the rim size. I talked to a machine shop today. If I dismount the tires and bring them to him he will cut them down as far as I want for $100. No bid deal. I and a product of the 70's when we let those N50's hand way out. That look is not something I minded way back then.
