05-26-2023, 09:08 AM | #1 |
Drives: 700 rwhp 2010 SS Join Date: Sep 2010
Turbo guys what's your oil pressure?
Just seeing what you guys have for oil pressure on a hot day. My twin turbo set up is about 18psi @ idle with oil temps around 220-230 degrees. Cruising its about 32psi. I run Valvoline 20w-50 full syn as that's what I was told to run from the previous owner of the car. It does have a built / forged motor in it, I don't have any issues and the car does have AN lines for the turbos (feed and return lines) and a scavenge pump so its expected to lose some pressure through all of that.
What are you guys at?
05-26-2023, 09:31 AM | #2 |
Drives: 2014 SS 1LE Join Date: Apr 2014
My old ls3 block ran around 26-28 psi when warmed up at idle. Cruising was mid 30s. Turbo oil feed is right off the oil pressure sensor so I’m assuming that affects the reading a bit? I’m not sure.
I would watch it and see if it consistently idles at 18 psi. Or if it lowers over time.
05-26-2023, 09:41 AM | #3 | |
05-26-2023, 11:25 AM | #4 | |
Drives: 2015 Camaro SS 1LE Join Date: Feb 2017
Things to consider, what oil pump is in the car? How often do you change the Oil? What fuel your running? (Ethanol Will Dilute) What pressure on cold start? Also, Oring on Pick Up Tube could be something there. Tons of things it could be. But something I'd recommend getting checked out before you hurt the motor. Just for Reference Cold Start on my Built Motor Single Turbo Car is 48PSI Cold Start. Fully Warm seeing 36PSI. We run Ethanol for fuel as well as VR1 SAE 40 For Oil |
05-26-2023, 07:50 PM | #5 |
Drives: Red Jewel Camaro SS Join Date: Mar 2014
30-35psi at idle, 45-50psi at highway speed and 70-75psi at 6500RPM(log from a 1 mile track run) 20W50 oil
No oil cooler,LSX block with Melling hi-volume pump w/stock pressure spring.
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
05-27-2023, 12:47 AM | #6 |
Boosted Moderator
Dry sump, so probably not any help… 35 psi warm idle, 45 psi at 5500 and about 50-55 psi at 9k rpm… Amsoil,
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
