05-09-2023, 11:11 PM | #1 |
Drives: Chevrolet Camaro Zl1 Join Date: Jul 2022
AutoMeter 2-1/16" Vac/Boost/Fluid Pressure, PSI/BAR,Cobalt Elite Digital 6758-CB
Installed this on my ZL1 and decided to go in another direction. Included is the gauge itself, MAP sensor for Vac/Boost feature, sending senor for the fuel pressure feature, wiring harness for the gauge, and a EARLS 3/8 fuel line quick connect pressure port. If you don't know what any of those things are, I would recommend installation by a qualified mechanic who does. I had to cut the pigtail off of the harness from the fluid pressure sending unit to fit through the firewall, but it can easily be re-attached.
$125 Sent from my SM-S901U1 using Tapatalk |
