03-06-2023, 03:13 PM | #1 |
Drives: 2015 Camaro 2SS/RS Join Date: Jan 2007
Trailing Arms and Toe Rods
Looking for advice. After some searching i am finding mixed reviews if upgrading trailing arms and toe rods are worth it.
Stock 2015 SS M6 with mods in sig. Car is mainly a street car with some 1/4 track time. I will be upgrading to Rear solid cradle bushings and 3:91/Trutrac and looking for a few more upgrades while the rear end is being worked on. I was going to put in Differential bushings but I think I am going to stick with factory rubber as i don't want added noise. I am thinking about BMR non adjustable Trailing and Toe rods. Car will maintain stock ride height. Or should I try and find z28 trailing arms and toe rods? feedback appreicated!
2015 2SS/RS 6spd
Rotofab CAI,MGW Shifter, DSP Tune Kooks LT/HFC/Xpipe/NPP Mufflers 4:10's, Trutrac Solid Cradle Bushings, BMR Toe and Trailing arms |
03-06-2023, 05:03 PM | #2 |
Drives: 2010 camaro ss Join Date: Aug 2021
I have a spare set of adjustable toe rods still brand new in the box if you do decide to go that route. I can’t really comment on the improvement since I did so much to the car at once.
Sent from my iPhone using Tapatalk |
03-06-2023, 05:37 PM | #3 |
Z/28 toe rods and trailing arms are the same as the SS 1LE and ZL1
03-06-2023, 07:03 PM | #4 | |
Drives: 2015 Z/22 Join Date: Aug 2015
In any case, stiffer rear components will help keep the rear planted and reduce dynamic alignment changes when accelerating/braking hard which is useful for launching the car/having fun. I say dooo iiit! Noticed a difference in my V6 so I can imagine the difference will be even more noticeable in a V8.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
03-06-2023, 07:45 PM | #5 |
Drives: 15 Camaro 2SS M6 Join Date: Jan 2020
your worried about noise so ur putting in solid cradle bushings but keeping stock diff bushings?
if that's the case don't go solid and just get the bmr complete poly bushing kit or at least cradle and diff. |
03-06-2023, 09:45 PM | #6 | |
Trailing Arms: Z/28 (FE6) 23104900 All others (FE2, FE3, FE4, FE5) 92246140 The toe rods are the same between the Z/28, ZL1 and SS 1LE: 22845487
03-07-2023, 05:32 AM | #7 | |
You definitely won't regret doing the solid cradle bushings. Again, was a noticeable difference in the V6 so I'm sure the benefits on a V8 will be that much better.
03-07-2023, 08:08 AM | #8 |
If you are spending money on toe rods and trailing arms, go with aftermarket as there is not much difference with the Z28 units. They don't add NVH and are way stronger.
Did not see a lot of NVH from solid cradle bushings, but did see a lot of NVH with Delrin diff bushings. The Delrin diff bushings did allow my deaf ass to hear the diff whining on acceleration, so now I know the pinion bearings are going.
03-07-2023, 10:38 AM | #9 | |
for ~$300, i think aftermarket trailing and toe rods are the way to go while the cradle is dropped on the car.
2015 2SS/RS 6spd
03-07-2023, 12:22 PM | #10 |
Drives: 2013 ZL1 Join Date: Nov 2018
I put the Dorman replacement toe rods on my ZL1 4 years and 30K miles ago, they have been solid.
2013 ZL1 M6, 2.4 pulley and a few bolt ons. 590 wheel and 11.70@122 on a hard tire.
03-07-2023, 03:11 PM | #11 |
Go aftermarket toe, trailing and lower control arms an call it the day lots of adjustability that you wont get with OEM crap. As far as cradle go solid AFE, Hendricks or DSE all great products that wont cause NVH. Leave you diff bushings alone unless you want to fill t he voids with a dense RTV. If you can find a OEM rear Z knuckle switch to those the jave better bushings (but they are no longer made). Get the front Z28 Tension rods (I think thats what they are will make steering more precise. Then get some good shocks Bilstien B-6's or a set of Koni's deending on what you are using the car for.
Orange Krush II
11-06-2023, 10:42 AM | #12 | |
Drives: 2014 Camaro 1SS (A6 Ashen Gray) Join Date: Sep 2019
To add to this, I've got BMR delrin rear cradle bushings and Hendrix offset poly differential bushings. The cradle bushings were installed several years before the differential bushings. My auto Camaro is a daily driver. In my opinion, the cradle bushings added little to no noise (I'm leaning towards none). The ride quality feels like almost stock, though it might be slightly more stiff. I'd personally recommend them even for a daily driver. On the other hand, the differential bushings definitely made noises and vibrations more noticeable. Coasting from around 45 mph or higher is usually accompanied by clunking (not super loud) noises and sometimes shaking backward/forward. A friend helped me confirm that my driveshaft is properly secured. The noises and shaking stop with any amount of pressure on the gas pedal. I spoke with someone at a local performance shop that noticed the same thing with aftermarket diff bushings on their... Corvette? I only bought the bushings because my car is lowered quite a bit on coilovers (fixing the resulting suspension geometry) and I was having a GPI SS3 cam installed.
Mod list: GPI SS3 camshaft (VVT delete), ZL1 Fuel Pump, FIC 60 lb injectors, Tru-Cool 40k tranny cooler, Circle D 3600 triple disc (billet flexplate), GPI Rod Mod, Bo White ported TB, Variant Helium wheels, Continental ECS 02 tires, CAI cold air intake, Kooks 1 7/8" LTH w/ high flow cats, Ridetech HQ coilovers, BMR sway bars, BMR delrin subframe bushings, Hendrix offset poly diff bushings, Borla S-Type axle-back exhaust, Holley EFI Fuel Rails, Elite Engineering E2 catch can, Umbra LED Taillights, Kenwood DMX9707S head unit, some minor interior/exterior appearance mods.
