02-02-2023, 11:43 AM | #1 |
Drives: 2010 Camaro Ss/Rs Join Date: Nov 2019
Service Stabilitrak after new tires…
Yes I know now, my tires are too far apart. I put on nitto nt555 g2’s, fronts(255/35/20) and rears(295/40/20). Threw the code and turned on all the lights just a few hundred feet from the tire place. Any easy fixes? Recommend front size so that it doesn’t throw the code? I’m not very experienced or knowledgeable with tire sizes so i really need some assistance. Thanks in advance.
02-02-2023, 12:04 PM | #2 |
A legend in his own mind
Drives: 2010 2SS/RS M6 Join Date: May 2013
The difference in overall height between the front and rear tire is my guess. Thats an 8.5% difference and I believe the max difference it can be is like 4-5%. You essentially have a 27" tire on the front and over a 29" rear tire. Either go taller on the front or shorter on the rear. A 275/40 on the front would probably fix your issues.
2010 2SS/RS "The Mistress"
Color matched OEM GFX / VIS Carbon Fiber Hood (absolute trash quality and customer service ) / Heritage Grille / 5% Windows / 30% Windshield tint with 5% visor strip / Tinted Exterior Lights / Streetfighter LA Spoiler / Morimoto XB LED fogs / LED sidemarkers / Airaid CAI / Hurst Short Throw / TSP LT's / No cats / No resonator / Corsa Xtreme Catback / Trifecta Tune / Factory amp replaced / 2 JL Audio 12's in the trunk / MRR 228 Wheels / BMR Springs / Moog Endlinks / R1 Concepts Rotors & Pads |
02-02-2023, 01:51 PM | #3 | |
Whl1(275/40) Whl2(295/40) Diameter 28.7” 29.3” +2.1% Width 10.8” 11.6” +7.4% Sidewall 4.3” 4.6” +7% Circumference 90” 92” +2.1% Revs/Mile 704 689 -15 |
02-02-2023, 01:53 PM | #4 |
I think you should be good. 2% should be within the threshold. If I remember correctly, those are the exact tire sizes I have on my car with the Nitto NT555 as well.
02-02-2023, 02:05 PM | #5 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
For Nitto G2s: 255/35/20 = 27.01" diameter. 295/40/20 = 29.29" diameter. Don't know if your lowered, suspension has sagged, different rims or ???? So I'd replace front and rear with something close to the factory diameter, ~28.7" front and rear. You could roll the dice and install 255/45/20, 29.06" G2s on the front. They shouldn't rub. Did the tire shop recommend your current sizes? Larger tire will mean your going faster than your displayed speed.
02-02-2023, 02:54 PM | #6 |
Play with the tire size calculator. Like I said, you want them close in size but you dont want taller sidewalls on the front than the rear, that would look terrible. Im pretty sure im running 275/40/20 and 295/40/20 on my lowered SS
02-07-2023, 02:34 PM | #7 |
Drives: 2018 Chevrolet Camaro Join Date: Jan 2023
To fix the issue with the tires being too far apart, you can try reducing the tire diameter by selecting a tire with a lower aspect ratio, which is the relationship between the tire's sidewall height and its width. Alternatively, you can try reducing the overall tire diameter by choosing a tire with a smaller overall diameter. For a front tire size, a 255/40/20 might be a good option, as it has a similar width but a lower aspect ratio.
02-07-2023, 03:45 PM | #8 |
I would make sure the code is even relevant to the tires,it's possible it's something else.
If you want to keep the tires, someone with HPTuners can adjust your tune to accept the tires you want and your ABS and speedo will be happy again
02-07-2023, 03:53 PM | #9 |
Its definitely the tires. Look at the sizes he posted. Way too far apart in size front to back
02-07-2023, 09:30 PM | #10 |
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
