View our official forum sponsors list. |
Thread Tools |
01-27-2023, 04:47 PM | #1 | |
Drives: Camaro Z28 Join Date: Jan 2017
APEX Wheels | Forged Sprint™ Line - Our Lightest Wheels, When Milliseconds Matter
Your Fastest Lap is Calling! Our forged Sprint™ line was built to be extremely light while still offering a meaningful strength increase over our flow formed wheels. For those looking to shed as much weight as possible to improve lap times. ➡︎ 10K ton forged 6061-T6 aluminum ➡︎ Stronger Sprint™ spec inner lip ➡︎ Side-milled spokes for reduced weight ➡︎ Massive brake clearance ➡︎ Unmatched replacement program ➡︎ Lifetime structural warranty ➡︎ Independently tested and certified Finishes 10K Tons Of Pressure Our new forgings weigh as much as 120 pounds before machining. To form such a thick blank we require special equipment capable of 10,000 metric tons of pressure. This extreme pressure increases the strength of the aluminum by eliminating porosity and improving the grain structure. True Motorsport Blanks One of the most significant upgrades to our Sprint wheels is the addition of wider and deeper side-milled spokes. Any excess material that doesn’t add strength is carved out using a precision CNC ball cutter. Side-milling is often deemed cost-prohibitive by others, but for true performance without compromise we believe it's essential.Many companies use 3rd-party blanks intended for non-motorsport wheels which can severely limit sizes, concavity, spoke design, and critical brake clearance. We designed our very own blank profiles from scratch which gives us total control over the final product, resulting in exceptionally deep spokes and stronger designs. Learn more our true motorsport blanks. Side-milled Spokes A Stronger Lightweight Wheel Our forged Sprint™ wheels are lightweight without the strength compromises found on typical lightweight wheels. First, we carved out as much material as possible, then we purposefully added one pound back to reinforce critical areas, creating a stronger inner lip and a higher load rating.¹ What’s the point of a lightweight wheel if it’s fragile? Weight Optimized We conducted extensive Finite Element Analysis (FEA) to reinforce high-stress areas and to remove material where it didn’t improve strength. The result is a wheel that is exceptionally light without the strength compromises found on typical lightweight wheels. Independently Tested We don't rely solely on computer simulations or unverifiable in-house testing. We believe independent testing is critical to protect consumers in this unregulated industry. We chose STL, an independent lab in Ohio, to test our Sprint™ wheels far above JWL standards, including increases in testing duration, impact drop height, and total load. Learn more about our rigorous independent testing. Tough Inner Lip Introducing the Sprint™ spec inner lip, with a unique channel profile that makes it even stronger than our previous designs. So even though our Sprint™ wheels are pounds lighter than comparable flow formed wheels, the inner lip is 32% stronger. Learn more about our Sprint™ spec inner lip. Big Brake Clearance From day one, APEX has been on a mission to build wheels that clear big brakes. Our new forged wheels are the product of everything we’ve developed over the past 10+ years, including an innovative high-clearance barrel design and vehicle-specific spoke profiles. Deeper Concavity Our new forgings were redesigned to create extra deep, concave spoke profiles. Their new shape allows us to make any profile, from flat to deep and everything in between. Each one is optimized for a specific application using 3D laser scans of factory and aftermarket brake kits. Paintless Knurled Beads Whether it's a day at the track or months of street driving, repeated hard braking and acceleration can make a tire slip along the bead seat and go out of balance, causing vibration. Knurled beads help, but are less effective when painted over. Our forged line features unpainted knurled beads that stay sharp and maximize grip. Learn more about why our forged wheels have unpainted knurled beads. Built for impact sockets Track wheels need track tools. Don’t settle for wheels that require undersized tuner lugs or thin walled sockets. All APEX wheels accommodate over-sized race lugs and impact sockets to make swapping wheels lightning fast. Laser-Engraved Specs As track enthusiasts ourselves, we know how frustrating it is to try to locate and decipher wheel specs that have been hastily hammered into the rim or become unreadable over time. With our new Sprint™ wheels, we chose to invest a little extra and laser-engrave the specs on the barrel, in plain sight, making them easy to find and read. (You’re welcome.) Additional Features Hub Centric - All APEX wheels with a 5x120mm bolt pattern are purpose built featuring a 67.1mm center bore. No centering rings required. Center Caps - We don't charge extra for caps and we design our wheels to be interchangeable with the OE roundel cap for enthusiasts seeking a clean factory look. All wheels come with our gloss Black APEX caps included. We also offer optional gloss red or gloss blue APEX caps. Hardware - APEX wheels can be used with all OEM mounting hardware, proper aftermarket hardware and wheel spacers. Wheel locks and stud conversion kits also work perfectly. TPMS - All APEX wheels accept OEM and aftermarket Tire Pressure Monitoring Sensors and standard fit valve stems. If your vehicle isn’t equipped with sensors or you choose to bypass them for your track/race car, then select from our metal stems available in multiple finishes. Lifetime Warranty All APEX wheels come with a lifetime structural warranty against defects in workmanship and materials, plus a 1 year finish warranty. Exchanges are fast, easy, and hassle-free. Curb rash or pothole damage on the street? Make an oopsie at the track? We’ve all been there. APEX is proud to offer 50% off replacement wheels, no matter the damage. A Fitment For You We’ve tirelessly test-fitted hundreds of setup combinations in order to provide direct-fit, spacer-free wheel packages for everything from showroom-fresh cars to all-out race builds. Our detailed fitment guides help you avoid costly trial-and-error and walk you through every step of finding your perfect setup. The Weight is Over
EC-7RS VS-5RS APEX Forged Sprint Line Wheel Gallery VS-5RS Gallery EC-7RS Gallery Questions? Call: 925-245-0773 Email: expert@apexraceparts.com Web: www.apexraceparts.com Hours: M-F 9a-5p PST
Cory - Fitment Specialist | Phone: 925.245.0773 | expert@apexwheels.com
Website | Instagram | Facebook | Blog [url=https://www.surveymonkey.com/r/APEXML10F][url=https://www.surveymonkey.com/r/APEXML10F] |
01-27-2023, 04:48 PM | #2 |
The New Look Of Fast - A new Sprint™ Line design is coming soon.
Exciting news - the next member of our Forged Sprint line family is on the way! Sign up at the link below to be the first to know about fitments, finishes, and Group Buy discounts. https://apexwheels.com/coming-soon?&...tm_term=camaro
01-31-2023, 07:01 PM | #3 |
03-08-2023, 06:44 PM | #4 | |
With the launch of our new SM-10RS Sprint Line wheel, we’ve had quite a few people asking why they might choose one design over another. To help answer that question, our Sales Director Ryan March sat down to take a deeper dive into the new design, as well as provide more information about the engineering that goes into all of our Sprint Line wheels.
The video highlights some awesome features that might not be apparent at a glance - from how we design the most weight efficient and high-clearance spokes, to how we test our wheels to ensure that they can withstand the rigors of motorsport abuse. Find out what separates our Forged SM-10RS from other 10 spoke wheels on the market!
Website | Instagram | Facebook | Blog [url=https://www.surveymonkey.com/r/APEXML10F][url=https://www.surveymonkey.com/r/APEXML10F] Last edited by Apex Wheels; 03-08-2023 at 06:54 PM. |
03-14-2023, 06:51 PM | #5 |
Our Group Buys are coming to an end!
With just a few hours left in both our 18 and 19” Group Buys, what are you waiting for? Don’t miss your chances to lock in the deepest discounts of the year on our Forged Sprint Line wheels. Pledge before midnight tonight PST to secure your new set of APEX wheels. Pledge Today
10-18-2023, 06:49 PM | #6 |
A new look from Apex! We've recently undergone a lengthy rebranding process that sees our name change from APEX Race Parts to Apex Wheels, new logos, and many more exciting things along the way.
Our website address has also changed, apexwheels.com, with an all new user interface which allows for more info, easier ordering, and an extensive vehicle gallery to help you decide on that perfect setup. Please note all wheels and merchandise will still be shipping with the original branding for the next few months. **If you're looking to buy 1 or 2 spare wheels to complete a set, have for backups, etc, now is the time to do so to ensure they match. Waiting until the new year could mean we're out, and old logo products won't be returning!**
11-21-2023, 07:27 PM | #7 |
Our biggest sale of the year is now live! Don’t miss your chance to lock in a deep discount on sets of our Forged and Flow Formed wheels as the holiday season kicks off. All our wheels are on sale with huge discounts available sitewide. Free shipping will also be available for all orders during the sale.* Buy Now 20% off Sprint Line Forged Wheels Our popular Forged offerings at an even more affordable price. Save 20% on the lightest wheels we make including our VS-5RS, SM-10RS, and EC-7RS. 25% Off Flow Formed Wheels A better value than ever, our Flow Formed Camaro wheels are 25% off across the board. Between our classic ARC-8s to our Evolution Line SM-10s, there's a perfect fitment out there for every car. Accessories Caps, Spacers, and Lug Nuts. No matter what you need to get your fitment dialed in, our sale has you covered with a 20% discount on these extras for your Camaro. With a variety of options on offer be sure to consult our Fitment Guides before ordering. If you still have questions, our fitment experts are standing by to help with inquiries, but will be overwhelmed as we near the sale’s end. Beat the procrastinators and reach out early for help with your next set of Apex wheels. Buy Now Need time before you buy? This sale ends on November 30th at midnight PST. *Free shipping to the lower 48 US states Questions? Call: (925) 245-0773 Email: expert@apexwheels.com Web: www.apexwheels.com Hours: M-F 9a-5p PST
11-27-2023, 06:45 PM | #8 |
Our largest sale of the year is already halfway over, don’t miss out on these savings. We have all of our wheels on sale along with accessories like spacers, lug nuts, and center caps If you have any questions take a look through our chassis specific Fitment Guide or shoot us an message using our Fitment Form. We may be overwhelmed with questions as we near the sale’s end so beat the procrastinators and reach out early for help with your next set of Apex wheels. Buy Now Need time before you buy? This sale ends on November 30th at midnight PST. *Free shipping to the lower 48 US states Questions? Call: (925) 245-0773 Email: expert@apexwheels.com Web: www.apexwheels.com Hours: M-F 9a-5p PST
04-02-2024, 10:05 AM | #9 | |||
Put that refund to work with our Tax Season Sale going on now. Save up to 25% off + Free Shipping* on a huge variety of in-stock fitments. Every Sprint Line Forged and Flow Formed wheel we offer is on sale. This sale ends on April 22nd, but discounts apply while supplies last. Get your order in today! Learn More Apex Flow Formed: Up to 25% off Our most popular wheels. Our original Flow Formed classic ARC-8 and Evolution line SM-10 designs are all heavily represented in this sale. All Apex Flow Formed wheels we currently produce are discounted bringing even more value to our most affordable wheel lines. Buy Now Apex Sprint Line Forged: Up to 15% off The Lightest Wheels We Make. Deep discounts on all of our Fully Forged EC-7RS, SM-10RS, and VS-5RS are available making our high-performance lightweight wheels an even better value. Buy Now Apex Accessories: 15% off All Apex branded accessories are discounted and get free shipping. Get your car ready for the track season today. Buy Now [/left] *Free Shipping to the 48 Contiguous States only. Questions? Call: 925-245-0773 Email: expert@apexwheels.com Web: www.apexwheels.com Hours: M-F 9a-5p PST
04-22-2024, 01:29 PM | #10 |
Shop Now
Tax Refund sale ends Today. You don’t want to miss out on a chance to secure a set of your new Apex Wheels at a great price and get Free Shipping*. With savings up to 25% off on a huge variety of fitments. Every Sprint Line Forged and Flow Formed wheel we offer is on sale. This sale ends on April 22nd, but discounts apply while supplies last. Get your order in today! Apex Flow Formed: Up to 25% off Apex Sprint Line Forged: Up to 15% off Camaro Fitment Guides: Find what fits your Camaro Buy Now Apex Accessories: 15% off All Apex Stud Kits, Lug Nuts, and Center Caps are discounted and get free shipping. Get your car ready for the track season today. Buy Now *Free Shipping to the 48 Contiguous States only. Questions? Call: 925-245-0773 Email: expert@apexwheels.com Web: www.apexwheels.com Hours: M-F 9a-5p PST
05-21-2024, 12:39 PM | #11 |
Some of you may have already seen the reveal of this project on our instagram, but we wanted to reach out to the Camaro community on the forums as well to collect feedback about the development of a new wheel design. Project ML-10 Background: After Josh, one of our Senior Product Engineers installed a widebody kit on his race car project, he had to design a custom set of wheels to fit his extreme application. Originally a one off project, when he showed the team what he created, we were floored. And our community was too when we shared a picture on Instagram and Facebook. We’ve made it an official project, but to make this wheel a reality, we need you to decide on some of the details by taking our survey. Need more information? Subscribe to our newsletter and check out project updates along with additional photos on our website.
