01-11-2023, 11:39 AM | #1 |
Drives: 1SS Summit White 6 speed Join Date: Jul 2017
Does anyone have a Camaro specific JMS fuel pump booster write up ?
Hey guys
I'm going to be installing the JMS fuel pump booster soon and was wondering anyone had a more Camaro specific write up available. Or maybe some tips on where you mounted yours, etc. Thanks alot!
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
01-11-2023, 11:54 AM | #2 |
Drives: Chevrolet Camaro Join Date: Apr 2022
I just finished mine up over the weekend. Referenced this thread: https://www.camaro6.com/forums/showthread.php?t=552426 and Jannetty's directions here: https://jannettyracing.com/pages/jms...er-gen-6-guide
PM me if you have any issues and I can try to help.
Procharger P1X, CSP Big Boy Cam, CSP Headers, LT4 HPFP, LT4 Injectors, JMS BAP - 722WHP
01-11-2023, 12:01 PM | #3 |
Here is a slightly more detailed writeup with many photos, courtesy Kris G @ Jannetty Racing.
01-11-2023, 12:09 PM | #4 |
Head to the store first and pick up a 30A micro fuse, the JMS comes with a mini fuse that is too large.
01-11-2023, 12:30 PM | #5 |
Drives: 2022 Camaro 2SS A10 Join Date: Jul 2022
I have a quick question regarding the JMS fuel voltage booster... I am installing the DSX aux fuel kit, and inquired with my speed shop about this unit as well. They recommended the DSX kit only, and not the JMS unit. I do see some shops use both the DSX and JMS units together. (for under 1000 whp of course) Not sure if there is any advantage to using both together, but it seems like most on the forum is using one or the other. Thoughts?
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods |
01-11-2023, 01:33 PM | #6 | |
Yes! I saw that in SteelRob's video I appreciate the links and offer
16 1SS M6 White
01-11-2023, 01:44 PM | #7 | |
Drives: 2020 LT1 M6 Join Date: Jan 2016
[SBE] ECS NOVI 1500 supercharger, 2" Longtube headers, flex fuel, LT4 injectors, LT4 HPFP, baro breakout
Tune date and results to be determined |
01-11-2023, 01:54 PM | #8 | |
01-11-2023, 02:42 PM | #9 |
The advantage of the dsx kit is the additional volume of fuel it can draw. The advantage of the JMS pump booster is that it can provide a little extra fuel in a more OEM style of fuel delivery.
01-11-2023, 03:05 PM | #10 |
My brother runs JMS on stock pump a long with Cordes Auxiliary on his C7Z. It works fine on his car which is over 1k whp on E60. For anything 900 ish or lower just the Aux pump is likely fine on its own. Long as the pressure doesn't drop then you have enough fuel. My guess is those running JMS and Aux likely started with JMS and ended up needing more fuel as they increased power(as my Bro did), then added the Aux pump.
2016 NFG 1SS A8
01-11-2023, 06:02 PM | #11 |
Drives: 98 Camaro Join Date: Apr 2022
So is this to regulate voltage or should you just get a bigger in tank pump than lt4 and skip the jms?
01-11-2023, 09:06 PM | #12 |
The answer to your question depends on your end goals, fuel type and your set up.
01-12-2023, 07:41 AM | #13 |
we used to always just put a bigger intank pump in. Most recently on my 4th Gen I had 1 450 walboro in tank and then went turbo and added another. In this car people want you to add a lt4 in tank (don’t know rating) and then add a jms booster on top of that. Why not just do a 450 or 525 in tank?
01-12-2023, 07:58 AM | #14 | |
